查看: 5876|回复: 0
Eziriz.NET.Reactor.v4.6.0.0
62 小时
发表于 2013-6-26 16:57:14 | 显示全部楼层 |阅读模式
下载:http://pan.baidu.com/share/link?shareid=3786922326&uk=2486438309
官方:http://www.eziriz.com/
.NET Reactor is a powerful .NET code protection & licensing system which assists developers in
protecting their .NET software. Developers are able to protect their software in a safe and simple
way now. This way developers can focus more on development than on worrying how to protect
their intellectual property.
In contrast to obfuscators .NET Reactor completely stops any decompiling by mixing any pure .NET
assembly (written in C#, VB.NET, Delphi.NET, J#, MSIL...) with native machine code. In detail,
.NET Reactor builds a native wall between potential hackers and your .NET code. The result is a
standard Windows based, not MSIL compatible, file. The original .NET code remains intact, well protected
by native code and invisible for prying eyes. The original .NET code is not copied on harddisk at any time.
There is no tool which is able to decompile .NET Reactor protected assemblies.
Features
.NET code & resource protection
.NET code encryption
.NET 1.1, 2.0, 3.0, 3.5 & 4.0 (Beta) assembly support
.NET Compact Framework 1.0, 2.0 & 3.5 protection support
ASP.NET support
Anti ILDASM
Mono assembly support
Advanced licensing system
String encryption
Merge assemblies into one executable or library
Removes IL code
Native Exe file generation
Compression support for executable files
Protection against disassembling and hacking
Protects any kind of .NET assembly
ShareIt Module Generator
Command Line support
Intuitive GUI (Graphical User Interface)
hangouts + 1 Thanks
GMT+8, 2025-4-3 04:11
