假设 XtraGrid 被绑定到 NWind 数据库中的 [Order Details] 表。 网格控件包含了“Quantity”、“UnitPrice”和“Discount"”列,这些列被绑定到数据库表中的相应字段。 下面的示例展示了如何把一个非绑定列添加到网格控件中,根据表达式 Quantity*UnitPrice*(1-Discount) 来显示每张订单的合计。
如果显示如下:
另一个演示了使用非绑定列的示例,请参阅 非绑定列 指南。
using DevExpress.XtraGrid.Views.Base; using DevExpress.XtraGrid.Columns; private void Form1_Load(object sender, System.EventArgs e) { // ... gridControl1.ForceInitialize(); // Create an unbound column. GridColumn unbColumn = gridView1.Columns.AddField("Total"); unbColumn.VisibleIndex = gridView1.Columns.Count; unbColumn.UnboundType = DevExpress.Data.UnboundColumnType.Decimal; // Disable editing. unbColumn.OptionsColumn.AllowEdit = false; // Specify format settings. unbColumn.DisplayFormat.FormatType = DevExpress.Utils.FormatType.Numeric; unbColumn.DisplayFormat.FormatString = "c"; // Customize the appearance settings. unbColumn.AppearanceCell.BackColor = Color.LemonChiffon; } // Returns the total amount for a specific row. decimal getTotalValue(ColumnView view, int listSourceRowIndex) { DataRow row = nwindDataSet.Tables["Order Details"].Rows[listSourceRowIndex]; decimal unitPrice = Convert.ToDecimal(row["UnitPrice"]); decimal quantity = Convert.ToDecimal(row["Quantity"]); decimal discount = Convert.ToDecimal(row["Discount"]); return unitPrice * quantity * (1 - discount); } // Provides data for the Total column. private void gridView1_CustomUnboundColumnData(object sender, CustomColumnDataEventArgs e) { if (e.Column.FieldName == "Total" && e.IsGetData) e.Value = getTotalValue(sender as ColumnView, e.ListSourceRowIndex); } |
Imports DevExpress.XtraGrid.Views.Base Imports DevExpress.XtraGrid.Columns Private Sub Form1_Load(ByVal sender As System.Object, _ ByVal e As System.EventArgs) Handles MyBase.Load ' ... gridControl1.ForceInitialize() ' Create an unbound column. Dim unbColumn As GridColumn = GridView1.Columns.AddField("Total") unbColumn.VisibleIndex = GridView1.Columns.Count unbColumn.UnboundType = DevExpress.Data.UnboundColumnType.Decimal ' Disable editing. unbColumn.OptionsColumn.AllowEdit = False ' Specify format settings. unbColumn.DisplayFormat.FormatType = DevExpress.Utils.FormatType.Numeric unbColumn.DisplayFormat.FormatString = "c" ' Customize the appearance settings. unbColumn.AppearanceCell.BackColor = Color.LemonChiffon End Sub ' Returns the total amount for a specific row. Private Function getTotalValue(ByVal view As ColumnView, _ ByVal listSourceRowIndex As Integer) As Decimal Dim row As DataRow = NwindDataSet.Tables("Order Details").Rows(listSourceRowIndex) Dim unitPrice As Decimal = Convert.ToDecimal(row("UnitPrice")) Dim quantity As Decimal = Convert.ToDecimal(row("Quantity")) Dim discount As Decimal = Convert.ToDecimal(row("Discount")) Return unitPrice * quantity * (1 - discount) End Function ' Provides data for the Total column. Private Sub GridView1_CustomUnboundColumnData(ByVal sender As Object, _ ByVal e As CustomColumnDataEventArgs) Handles GridView1.CustomUnboundColumnData If e.Column.FieldName = "Total" And e.IsGetData Then e.Value = _ getTotalValue(CType(sender, ColumnView), e.ListSourceRowIndex) End Sub |
