本示例展示了如何使用 CardView.CustomDrawCardFieldCaption 事件来定制 卡片字段标题。 对获得焦点的和没有获得焦点的字段绘制不同的字段标题。
using DevExpress.XtraGrid.Views.Base; private void cardView1_CustomDrawCardFieldCaption(object sender, RowCellCustomDrawEventArgs e) { CardView cv = sender as CardView; bool isFocused = false; if(cv.FocusedColumn != null) isFocused = e.Column.AbsoluteIndex == cv.FocusedColumn.AbsoluteIndex && e.RowHandle == cv.FocusedRowHandle; //A brush to draw the background of the card field caption Brush backBrush; if (isFocused) backBrush = e.Cache.GetGradientBrush(e.Bounds, Color.LavenderBlush, Color.Navy, LinearGradientMode.Vertical); else backBrush = e.Cache.GetGradientBrush(e.Bounds, Color.Aquamarine, Color.DarkSeaGreen, LinearGradientMode.Vertical); Rectangle r = e.Bounds; //Draw a 3D border ControlPaint.DrawBorder3D(e.Graphics, r, Border3DStyle.RaisedInner); r.Inflate(-1, -1); //Fill the background e.Graphics.FillRectangle(backBrush, r); r.Y--; //Change the appearance for drawing the focused field's caption if(isFocused) { e.Appearance.ForeColor = Color.White; e.Appearance.TextOptions.HAlignment = HorzAlignment.Center; } e.Appearance.DrawString(e.Cache, e.DisplayText, r); //Prevent default painting e.Handled = true; } |
Imports DevExpress.XtraGrid.Views.Base Private Sub CardView1_CustomDrawCardFieldCaption(ByVal sender As Object, _ ByVal e As .RowCellCustomDrawEventArgs) Handles CardView1.CustomDrawCardFieldCaption Dim cv As CardView = CType(sender, CardView) Dim isFocused As Boolean = False If Not cv.FocusedColumn Is Nothing Then isFocused = e.Column.AbsoluteIndex = _ cv.FocusedColumn.AbsoluteIndex And e.RowHandle = cv.FocusedRowHandle 'A brush to draw the background of the card field caption Dim backBrush As Brush If isFocused Then backBrush = e.Cache.GetGradientBrush(e.Bounds, Color.LavenderBlush, Color.Navy, _ LinearGradientMode.Vertical) Else backBrush = e.Cache.GetGradientBrush(e.Bounds, Color.Aquamarine, Color.DarkSeaGreen, _ LinearGradientMode.Vertical) End If Dim r As Rectangle = e.Bounds 'Draw a 3D border ControlPaint.DrawBorder3D(e.Graphics, r, Border3DStyle.RaisedInner) r.Inflate(-1, -1) 'Fill the background e.Graphics.FillRectangle(backBrush, r) r.Y -= 1 'Change the appearance for drawing the focused field's caption If isFocused Then e.Appearance.ForeColor = Color.White e.Appearance.TextOptions.HAlignment = HorzAlignment.Center End If e.Appearance.DrawString(e.Cache, e.DisplayText, r) 'Prevent default painting e.Handled = True End Sub |
