在本例中,我们以特定的方式绘制 分组面板 —— 通过接管 GridView.CustomDrawGroupPanel 事件来实现。 首先,使用渐变刷填充面板。 然后,在面板的右侧绘制一幅自定义图像。
using System.Reflection; using DevExpress.XtraGrid.Views.Base; Bitmap groupPanelImage; private void frmMain_Load(object sender, System.EventArgs e) { //... groupPanelImage = (Bitmap)Bitmap.FromStream( Assembly.GetExecutingAssembly().GetManifestResourceStream( "GridCustomDraw.Images.logo_c.gif")); groupPanelImage.MakeTransparent(); } private void advBandedGridView1_CustomDrawGroupPanel(object sender, CustomDrawEventArgs e) { //Define a linear gradient brush Brush brush = e.Cache.GetGradientBrush(e.Bounds, Color.Sienna, Color.Bisque, System.Drawing.Drawing2D.LinearGradientMode.Horizontal); //Fill the group panel e.Graphics.FillRectangle(brush, e.Bounds); //Draw a glyph at the right edge of the panel Image img = groupPanelImage; Rectangle r = new Rectangle(e.Bounds.X + e.Bounds.Width - img.Size.Width - 5, e.Bounds.Y + (e.Bounds.Height - img.Size.Height) / 2, img.Width, img.Height); e.Graphics.DrawImageUnscaled(img, r); e.Handled = true; } |
Imports System.Reflection Imports DevExpress.XtraGrid.Views.Base Dim groupPanelImage As Bitmap Private Sub frmMain_Load(ByVal sender As Object, ByVal e As System.EventArgs) _ Handles MyBase.Load '... groupPanelImage = CType(Bitmap.FromStream( _ Assembly.GetExecutingAssembly().GetManifestResourceStream( _ "GridCustomDraw.logo_c.gif")), Bitmap) groupPanelImage.MakeTransparent() End Sub Private Sub advBandedGridView1_CustomDrawGroupPanel(ByVal sender As Object, _ ByVal e As CustomDrawEventArgs) Handles advBandedGridView1.CustomDrawGroupPanel 'Define a linear gradient brush Dim brush As Brush = e.Cache.GetGradientBrush(e.Bounds, Color.Sienna, Color.Bisque, _ System.Drawing.Drawing2D.LinearGradientMode.Horizontal) 'Fill the group panel e.Graphics.FillRectangle(brush, e.Bounds) 'Draw a glyph at the right edge of the panel Dim img As Image = groupPanelImage Dim r As Rectangle = New Rectangle(e.Bounds.X + e.Bounds.Width - img.Size.Width - 5, _ e.Bounds.Y + (e.Bounds.Height - img.Size.Height) / 2, img.Width, img.Height) e.Graphics.DrawImageUnscaled(img, r) e.Handled = True End Sub |
