下列代码列示了一个 ColumnView.CustomDrawEmptyForeground 事件处理程序, 当没有记录在视图中呈现之时执行视图区域的自定义绘制。 在本例中,在视图的空白区域绘制一个字符串。
下面的插图展示了自定义绘制的结果。
using DevExpress.XtraGrid.Views.Base; using System.Drawing; private void gridView1_CustomDrawEmptyForeground(object sender, CustomDrawEventArgs e) { string s; ColumnView view = sender as ColumnView; // Get the number of records in the underlying data source. DataView dataSource = view.DataSource as DataView; if(dataSource.Count == 0) //the data source is empty s = "Press Insert to add a new record"; else //no records meet the filter criteria s = "No records match the current filter criteria"; Font font = new Font("Tahoma", 10, FontStyle.Bold); Rectangle r = new Rectangle(e.Bounds.Left + 5, e.Bounds.Top + 5, e.Bounds.Width - 5, e.Bounds.Height - 5); e.Graphics.DrawString(s, font, Brushes.Black, r); } |
Imports DevExpress.XtraGrid.Views.Base Private Sub GridView1_CustomDrawEmptyForeground(ByVal sender As Object, _ ByVal e As CustomDrawEventArgs) Handles GridView1.CustomDrawEmptyForeground Dim s As String Dim view As ColumnView = CType(sender, ColumnView) ' Get the number of records in the underlying data source. Dim dataSource As DataView = View.DataSource If dataSource.Count = 0 Then 'the data source is empty s = "Press Insert to add a new record" Else 'no records meet the filter criteria s = "No records match the current filter criteria" End If Dim font As Font = New Font("Tahoma", 10, FontStyle.Bold) Dim r As RectangleF = New RectangleF(e.Bounds.Left + 5, e.Bounds.Top + 5, _ e.Bounds.Width - 5, e.Bounds.Height - 5) e.Graphics.DrawString(s, font, Brushes.Black, r) End Sub |
