我们考虑一个通过 ColumnView.CustomColumnDisplayText 事件定制单元格显示文本的示例。 假设网格的视图中包含 CurrencyType 和 Price 列。 如果货币类型等于 0,则以美元格式显示价格。 如果货币类型等于 1,则以欧元格式显示价格。 在 ColumnView.CustomColumnDisplayText 事件处理程序中,获取了 CurrencyType 和 Price 列的取值。 然后根据货币类型设置价格的格式,并把已设置格式的字符串指派到事件的 DisplayText 参数。
using DevExpress.XtraGrid.Views.Base;
using System.Globalization;
// The cultures used to format the values for the two different currencies.
CultureInfo ciUSA = new CultureInfo("en-US");
CultureInfo ciEUR = new CultureInfo("fr-FR", false);
private void gridView1_CustomColumnDisplayText(object sender,
CustomColumnDisplayTextEventArgs e) {
   ColumnView View = sender as ColumnView;
   if(e.Column.FieldName == "Price") {
      int currencyType = (int)view.GetRowCellValue(e.RowHandle, View.Columns["CurrencyType"]);
      decimal price = (decimal)view.GetRowCellValue(e.RowHandle, View.Columns["Price"]);
      // Conditional formatting:
      switch(currencyType) {
         case 0: e.DisplayText = string.Format(ciUSA, "{0:c}", price); break;
         case 1: e.DisplayText = string.Format(ciEUR, "{0:c}", price); break;
Imports DevExpress.XtraGrid.Views.Base
Imports System.Globalization
' The cultures used to format the values for the two different currencies.
Dim ciUSA As CultureInfo = New CultureInfo("en-US")
Dim ciEUR As CultureInfo = New CultureInfo("fr-FR", False)
Private Sub GridView1_CustomColumnDisplayText(ByVal sender As Object, _
ByVal e As CustomColumnDisplayTextEventArgs) _
Handles GridView1.CustomColumnDisplayText
   Dim View As ColumnView = sender
      If e.Column.FieldName = "Price" Then
         Dim currencyType As Integer = View.GetRowCellValue(e.RowHandle, _
             View.Columns("CurrencyType"))
         Dim price As Decimal = View.GetRowCellValue(e.RowHandle, View.Columns("Price"))
         ' Conditional formatting:
         Select Case currencyType
            Case 0 : e.DisplayText = String.Format(ciUSA, "{0:c}", price)
            Case 1 : e.DisplayText = String.Format(ciEUR, "{0:c}", price)
         End Select
      End If
结果显示如下:
