下面的示例代码接管了 GridView.ShowGridMenu 事件,在 列标头的上下文菜单 被显示之前定制该菜单。 示例代码清除了默认的菜单项,并添加了一个用于确定在列标头面板中的列标头是否可以被移动的新菜单项。
using DevExpress.XtraGrid.Menu; using DevExpress.Utils.Menu; using DevExpress.XtraGrid.Columns; using DevExpress.XtraGrid.Views.Grid; // ... private void bandedGridView1_ShowGridMenu(object sender, GridMenuEventArgs e) { if(e.MenuType == GridMenuType.Column) { GridViewColumnMenu menu = e.Menu as GridViewColumnMenu; menu.Items.Clear(); if(menu.Column != null) { menu.Items.Add(CreateCheckItem("Can Moved", menu.Column, null)); } } } // Creates a menu item. DXMenuCheckItem CreateCheckItem(string caption, GridColumn column, Image image) { DXMenuCheckItem item = new DXMenuCheckItem(caption, column.IsOption(ColumnOptions.CanMoved), image, new EventHandler(OnCanMovedItemClick)); item.Tag = new MenuColumnInfo(column); return item; } // Menu item click handler. void OnCanMovedItemClick(object sender, EventArgs e) { DXMenuCheckItem item = sender as DXMenuCheckItem; MenuColumnInfo info = item.Tag as MenuColumnInfo; if(info == null) return; if(!item.Checked) info.Column.Options &= ~ColumnOptions.CanMoved; else info.Column.Options |= ColumnOptions.CanMoved; } // The class that stores menu specific information. class MenuColumnInfo { public MenuColumnInfo(GridColumn column) { this.Column = column; } public GridColumn Column; } |
Imports DevExpress.XtraGrid.Menu Imports DevExpress.XtraGrid.Columns Imports DevExpress.Utils.Menu Imports DevExpress.XtraGrid.Views.Grid ' ... Private Sub bandedGridView1_ShowGridMenu(ByVal sender As Object, _ ByVal e As GridMenuEventArgs) Handles bandedGridView1.ShowGridMenu If e.MenuType = GridMenuType.Column Then Dim menu As GridViewColumnMenu = e.Menu menu.Items.Clear() If Not Menu.Column Is Nothing Then Menu.Items.Add(CreateCheckItem("Can Moved", Menu.Column, Nothing)) End If End If End Sub ' Creates a menu item. Function CreateCheckItem(ByVal caption As String, ByVal column As GridColumn, _ ByVal image As Image) As DXMenuCheckItem Dim item As DXMenuCheckItem = New DXMenuCheckItem(caption, _ column.IsOption(ColumnOptions.CanMoved), image, _ New EventHandler(AddressOf OnCanMovedItemClick)) item.Tag = New MenuColumnInfo(column) Return item End Function ' Menu item click handler. Sub OnCanMovedItemClick(ByVal sender As Object, ByVal e As EventArgs) Dim item As DXMenuCheckItem = sender Dim info As MenuColumnInfo = CType(item.Tag, MenuColumnInfo) If info Is Nothing Then Return If Not item.Checked Then info.Column.Options = info.Column.Options And Not ColumnOptions.CanMoved Else info.Column.Options = info.Column.Options Or ColumnOptions.CanMoved End If End Sub ' The class that stores menu specific information. Class MenuColumnInfo Public Sub New(ByVal column As GridColumn) Me.Column = column End Sub Public Column As GridColumn End Class |
