假设网格控件显示了在两个表之间的主/从关系。 此关系被命名为“Orders”。 下面的示例展示了如何把现有的呈现“Orders”关系的视图,替换为一个新的带区视图。
首先,在 GridControl.LevelTree 中查找呈现“Orders”关系的节点。 然后,现有的视图被销毁,并且把一个新的带区视图指派到此关系。
using DevExpress.XtraGrid; using DevExpress.XtraGrid.Views.Base; using DevExpress.XtraGrid.Views.Grid; using DevExpress.XtraGrid.Views.BandedGrid; // Collapse all the details opened for the master rows in the main view. (gridControl1.MainView as GridView).CollapseAllDetails(); // Get the node at the first nesting level that stores a view for the "Orders" relation. GridLevelNode node = gridControl1.LevelTree.Nodes["Orders"]; if(node == null) return; // The old view which represents the "Orders" relation. BaseView oldView = node.LevelTemplate; // Dispose of this view. oldView.Dispose(); // Create a new view. BandedGridView bandedView = new BandedGridView(gridControl1); // Associate this view with the "Orders" relation. node.LevelTemplate = bandedView; // Customize the new view. GridBand band = bandedView.Bands.Add("Orders"); BandedGridColumn column = (BandedGridColumn)bandedView.Columns.Add("ID"); column.OwnerBand = band; column.Visible = true; column = (BandedGridColumn)bandedView.Columns.AddField("ProductID"); column.OwnerBand = band; column.Visible = true; |
Imports DevExpress.XtraGrid Imports DevExpress.XtraGrid.Views.Base Imports DevExpress.XtraGrid.Views.Grid Imports DevExpress.XtraGrid.Views.BandedGrid ' Collapse all the details opened for the master rows in the main view. CType(GridControl1.MainView, GridView).CollapseAllDetails() ' Get the node at the first nesting level that stores a view for the "Orders" relation. Dim node As GridLevelNode = GridControl1.LevelTree.Nodes("Orders") If node Is Nothing Then Return ' The old view which represents the "Orders" relation. Dim oldView As BaseView = node.LevelTemplate ' Dispose of this view. oldView.Dispose() ' Create a new view. Dim bandedView As BandedGridView = New BandedGridView(GridControl1) ' Associate this view with the "Orders" relation. node.LevelTemplate = bandedView ' Customize the new view. Dim band As GridBand = bandedView.Bands.Add("Orders") Dim column As BandedGridColumn = bandedView.Columns.Add("ID") column.OwnerBand = band column.Visible = True column = bandedView.Columns.AddField("ProductID") column.OwnerBand = band column.Visible = True |
