下面的示例假设在网格控件中有一个主/从关系。 主表视图由 网格视图 呈现,细节视图由 卡片视图 类的实例呈现。 本示例展示了如何在细节视图间实现卡片拖动。
Control.MouseDown 事件用于识别被单击的卡片,并初始拖动操作。 然后 Control.DragOver 事件用于确定是否允许放落。 GridControl.GetViewAt 方法用于获取当前位于鼠标指针下面的视图。 如果获取的视图是一个细节视图 (卡片视图),则允许放落。
最后,Control.DragDrop 事件用于确定卡片已放落的视图 (再次使用 GridControl.GetViewAt 方法)。 接下来,通过修改指向主表记录的字段值,把被拖动的卡片移动到放落的视图。
注意,要允许放落操作,则应该把网格控件的 AllowDrop 属性值设置为 true。
using DevExpress.XtraGrid.Views.Base; using DevExpress.XtraGrid.Views.Card; using DevExpress.XtraGrid.Views.Grid; using DevExpress.XtraGrid; using DevExpress.XtraGrid.Views.Card.ViewInfo; // ... private void cvProducts_MouseDown(object sender, System.Windows.Forms.MouseEventArgs e) { CardView view = sender as CardView; GridView parentView = view.ParentView as GridView; // Obtain the clicked point. CardHitInfo hi = view.CalcHitInfo(new Point(e.X, e.Y)); // Determine if the clicked point belongs to a card caption. if (hi.HitTest == CardHitTest.CardCaption) { // Obtain the clicked card. string rowID = view.GetRowCellValue(hi.RowHandle, view.Columns["ProductID"]).ToString(); gridControl1.DoDragDrop(rowID, DragDropEffects.Move); } } // ... private void gridControl1_DragOver(object sender, System.Windows.Forms.DragEventArgs e) { GridControl grid = sender as GridControl; // Obtain the view over which the card is being dragged. Point pt = gridControl1.PointToClient(new Point(e.X, e.Y)); BaseView view = grid.GetViewAt(pt); if (view is CardView) e.Effect = DragDropEffects.Move; else e.Effect = DragDropEffects.None; } // ... private void gridControl1_DragDrop(object sender, System.Windows.Forms.DragEventArgs e) { GridControl grid = sender as GridControl; // Obtain the view to which the card has been dropped. Point pt = gridControl1.PointToClient(new Point(e.X, e.Y)); CardView view = grid.GetViewAt(pt) as CardView; string dragData = e.Data.GetData(DataFormats.Text).ToString(); int rowID = Convert.ToInt32(dragData); // Obtain the row owning the detail clone to which the card is dropped. GridView parentView = view.ParentView as GridView; object cellValue = parentView.GetRowCellValue(view.SourceRowHandle, parentView.Columns["CategoryID"]); int currentParentID = Convert.ToInt32(cellValue); // Change the parent row of the card results in moving this card to the specified parent row. dataSet11.Products.Rows.Find(rowID)[dataSet11.Products.Columns["CategoryID"]] = currentParentID; } |
Imports DevExpress.XtraGrid.Views.Base Imports DevExpress.XtraGrid.Views.Card Imports DevExpress.XtraGrid.Views.Grid Imports DevExpress.XtraGrid Imports DevExpress.XtraGrid.Views.Card.ViewInfo // ... Private Sub Form1_MouseDown(ByVal sender As Object, _ ByVal e As System.Windows.Forms.MouseEventArgs) Handles MyBase.MouseDown Dim View As CardView = sender Dim ParentView As GridView = View.ParentView ' Obtain the clicked point. Dim Hi As CardHitInfo = View.CalcHitInfo(New Point(e.X, e.Y)) ' Determine if the clicked point belongs to a card caption. If Hi.HitTest = CardHitTest.CardCaption Then ' Obtain the clicked card. Dim RowID As String = View.GetRowCellValue(Hi.RowHandle, _ View.Columns("ProductID")).ToString() GridControl1.DoDragDrop(RowID, DragDropEffects.Move) End If End Sub // ... Private Sub Form1_DragOver(ByVal sender As Object, _ ByVal e As System.Windows.Forms.DragEventArgs) Handles MyBase.DragOver Dim Grid As GridControl = sender ' Obtain the view over which the card is being dragged. Dim pt As Point = GridControl1.PointToClient(New Point(e.X, e.Y)); Dim View As BaseView = Grid.GetViewAt(pt) If TypeOf View Is CardView Then e.Effect = DragDropEffects.Move Else e.Effect = DragDropEffects.None End If End Sub // ... Private Sub Form1_DragDrop(ByVal sender As Object, _ ByVal e As System.Windows.Forms.DragEventArgs) Handles MyBase.DragDrop Dim Grid As GridControl = sender ' Obtain the view to which the card has been dropped. Dim pt As Point = GridControl1.PointToClient(New Point(e.X, e.Y)); Dim View As CardView = Grid.GetViewAt(pt) Dim dragData As String = e.Data.GetData(DataFormats.Text).ToString() Dim RowID As Integer = Convert.ToInt32(dragData) ' Obtain the row owning the detail clone to which the card is dropped. Dim parentView As GridView = View.ParentView Dim cellValue As Object = parentView.GetRowCellValue(view.SourceRowHandle, _ parentView.Columns("CategoryID")) Dim currentParentID As Integer = Convert.ToInt32(cellValue) ' Change the parent row of the card results in moving this card to specified parent row. DataSet11.Products.Rows.Find(RowID)(DataSet11.Products.Columns("CategoryID")) = _ currentParentID End Sub |
