假设网格视图的“Order Sum”列包含数值。 当按照该列进行分组时,该列中取值介于 0 至 99 之间的行应被组合为一个组,取值介于 100 至 199 之间的行应被组合为另一个组,等等。 为了提供自定义分组逻辑,应该把列的 GridColumn.SortMode 属性设置为 ColumnSortMode.Custom ,并接管 GridView.CustomColumnGroup 事件来实现算法。 在下面的示例中,如果应放置在相同组中的两行被比较,则事件的 Result 参数被设置为 0。
接管了 GridView.CustomDrawGroupRow 事件来替换在分组行中显示的默认文本。
数据的自定义分组结果在下面显示:
C# | 复制代码 |
using DevExpress.XtraGrid; using DevExpress.XtraGrid.Views.Base; using DevExpress.XtraGrid.Views.Grid; using DevExpress.XtraGrid.Views.Grid.ViewInfo; // ... gridView1.Columns["Order Sum"].SortMode = ColumnSortMode.Custom; private void gridView1_CustomColumnGroup(object sender, CustomColumnSortEventArgs e) { if(e.Column.FieldName == "Order Sum") { double x = Math.Floor(Convert.ToDouble(e.Value1) / 100); double y = Math.Floor(Convert.ToDouble(e.Value2) / 100); int res = Comparer.Default.Compare(x, y); if(x > 14 && y > 14) res = 0; e.Result = res; e.Handled = true; } } private void gridView1_CustomDrawGroupRow(object sender, RowObjectCustomDrawEventArgs e) { GridGroupRowInfo info = e.Info as GridGroupRowInfo; if(info == null) return; if(info.Column.FieldName == "Order Sum") { string interval = IntervalByValue(gridView1.GetGroupRowValue(info.RowHandle)); // Gets the summary text. string sumText = gridView1.GetGroupSummaryText(info.RowHandle); // Replace the group row's default text. info.GroupText = "Order Sum: " + interval + sumText; } } // Gets the text representing the interval that contains the specified value. string IntervalByValue(object val) { double d = Math.Floor(Convert.ToDouble(val) / 100); string ret = string.Format("{0:c} - {1:c} ", d * 100, (d + 1) * 100); if(d > 14) ret = string.Format(">= {0:c} ", d * 100); return ret; } |
Visual Basic | 复制代码 |
Imports DevExpress.XtraGrid Imports DevExpress.XtraGrid.Views.Base Imports DevExpress.XtraGrid.Views.Grid Imports DevExpress.XtraGrid.Views.Grid.ViewInfo ' ... GridView1.Columns("Order Sum").SortMode = ColumnSortMode.Custom Private Sub GridView1_CustomColumnGroup(ByVal sender As Object, _ ByVal e As CustomColumnSortEventArgs) Handles GridView1.CustomColumnGroup If e.Column.FieldName = "Order Sum" Then Dim x As Double = Math.Floor(Convert.ToDouble(e.Value1) / 100) Dim y As Double = Math.Floor(Convert.ToDouble(e.Value2) / 100) Dim res As Integer = Comparer.Default.Compare(x, y) If x > 14 And y > 14 Then res = 0 e.Result = res e.Handled = True End If End Sub Private Sub GridView1_CustomDrawGroupRow(ByVal sender As Object, _ ByVal e As RowObjectCustomDrawEventArgs) Handles GridView1.CustomDrawGroupRow Dim info As GridGroupRowInfo = CType(e.Info, GridGroupRowInfo) If info Is Nothing Then Return If info.Column.FieldName = "Order Sum" Then Dim interval As String = IntervalByValue(GridView1.GetGroupRowValue(info.RowHandle)) ' Get the summary text. Dim sumText As String = GridView1.GetGroupSummaryText(info.RowHandle) ' Replace the group row's default text. info.GroupText = "Order Sum: " + interval + sumText End If End Sub ' Gets the text representing the interval that contains the specified value. Function IntervalByValue(ByVal val As Object) As String Dim d As Double = Math.Floor(Convert.ToDouble(val) / 100) Dim ret As String = String.Format("{0:c} - {1:c} ", d * 100, (d + 1) * 100) If d > 14 Then ret = String.Format(">= {0:c} ", d * 100) Return ret End Function |
