下面的示例演示了如何打印 TreeList,或者显示其打印预览。 为了执行此任务,使用了 TreeList.Print 和 TreeList.ShowPrintPreview 方法。
仅当 XtraPrinting 库可用时,才能打印和预览树状列表。 因此,为了验证是否可以打印树状列表,在打印控件之前检查了 TreeList.IsPrintingAvailable 属性。
下面的插图展示了预览中的树状列表。
using DevExpress.XtraTreeList; // ... private void ShowTreeListPreview(TreeList treeList) { // Check whether the TreeList can be previewed. if (!treeList.IsPrintingAvailable) { MessageBox.Show("The XtraPrinting Library is not found", "Error"); return; } // Open the Preview window. treeList.ShowPrintPreview(); } private void PrintTreeList(TreeList treeList) { // Check whether the TreeList can be printed. if (!treeList.IsPrintingAvailable) { MessageBox.Show("The XtraPrinting Library is not found", "Error"); return; } // Print. treeList.Print(); } | |
Imports DevExpress.XtraTreeList ' ... Sub ShowTreeListPreview(ByVal treeList As TreeList) ' Check whether the TreeList can be previewed. If Not treeList.IsPrintingAvailable Then MessageBox.Show("The XtraPrinting Library is not found", "Error") Return End If ' Opens the Preview window. treeList.ShowPrintPreview() End Sub Sub PrintTreeList(ByVal treeList As TreeList) ' Check whether the TreeList can be printed. If Not treeList.IsPrintingAvailable Then MessageBox.Show("The XtraPrinting Library is not found", "Error") Return End If ' Print. treeList.Print() End Sub | |
