下面的示例演示了如何在代码中创建 RibbonControl 内的上下文标签页面。
在本示例中,创建了一个 RibbonControl 控件,它包含了一个固定被显示的页面 (“Home”) 和两个上下文页面 (“Format” 和 “Clipboard”)。 这两个上下文页面被组合在一个自定义页面类别 (“Selection”) 中。
在创建上下文页面时,它们被隐藏。 稍后通过该类别的 RibbonPageCategory.Visible 属性来使上下文页面可视。
下面的插图展示了代码执行结果:
using DevExpress.XtraBars.Ribbon; using DevExpress.XtraBars; // Create a RibbonControl. RibbonControl ribbon = new RibbonControl(); // Assign a collection of images that will be used by bar items. ribbon.Images = imageCollection1; // Create a page and associate it with the default category. RibbonPage pageHome = new RibbonPage("Home"); ribbon.Pages.Add(pageHome); // Create a custom Selection page category. RibbonPageCategory catSelection = new RibbonPageCategory("Selection", Color.LightPink, false); ribbon.PageCategories.Add(catSelection); // Create two contextual pages (Format an Clipboard)in the Selection category. RibbonPage contextPageFormat = new RibbonPage("Format"); RibbonPage contextPageClipboard = new RibbonPage("Clipboard"); catSelection.Pages.AddRange(new RibbonPage[] {contextPageFormat, contextPageClipboard}); // Customize the Format page by adding a Format group with two bar items to it. RibbonPageGroup groupFormat = new RibbonPageGroup("Format"); groupFormat.AllowTextClipping = false; // Add two items to the Format group BarButtonItem itemCopy = new BarButtonItem(ribbon.Manager, "Copy", 0); BarButtonItem itemCut = new BarButtonItem(ribbon.Manager, "Cut", 1); groupFormat.ItemLinks.AddRange(new BarItem[] {itemCopy, itemCut}); contextPageFormat.Groups.Add(groupFormat); // Subscribe to an event which fires when any item is clicked. ribbon.ItemClick += new ItemClickEventHandler(ribbon_ItemClick); // Add the RibbonControl to the form. this.Controls.Add(ribbon); //... // Make the Selection category visible catSelection.Visible = true; // Activate the category's first page. ribbon.SelectedPage = catSelection.Pages[0]; // Respond to item clicking. void ribbon_ItemClick(object sender, ItemClickEventArgs e) { //... } |
Imports DevExpress.XtraBars.Ribbon Imports DevExpress.XtraBars ' Create a RibbonControl. Dim ribbon As RibbonControl = New RibbonControl() ' Assign a collection of images that will be used by bar items. ribbon.Images = imageCollection1 ' Create a page and associate it with the default category. Dim pageHome As RibbonPage = New RibbonPage("Home") ribbon.Pages.Add(pageHome) ' Create a custom Selection page category. Dim catSelection As RibbonPageCategory = New RibbonPageCategory("Selection", Color.LightPink, False) ribbon.PageCategories.Add(catSelection) ' Create two contextual pages (Format an Clipboard)in the Selection category. Dim contextPageFormat As RibbonPage = New RibbonPage("Format") Dim contextPageClipboard As RibbonPage = New RibbonPage("Clipboard") catSelection.Pages.AddRange(New RibbonPage() {contextPageFormat, contextPageClipboard}) ' Customize the Format page by adding a Format group with two bar items to it. Dim groupFormat As RibbonPageGroup = New RibbonPageGroup("Format") groupFormat.AllowTextClipping = False ' Add two items to the Format group Dim itemCopy As BarButtonItem = New BarButtonItem(ribbon.Manager, "Copy", 0) Dim itemCut As BarButtonItem = New BarButtonItem(ribbon.Manager, "Cut", 1) groupFormat.ItemLinks.AddRange(New BarItem() {itemCopy, itemCut}) contextPageFormat.Groups.Add(groupFormat) ' Subscribe to an event which fires when any item is clicked. AddHandler ribbon.ItemClick, AddressOf ribbon_ItemClick 'ribbon.ItemClick += New ItemClickEventHandler(ribbon_ItemClick) ' Add the RibbonControl to the form. Me.Controls.Add(ribbon) '... ' Make the Selection category visible catSelection.Visible = True ' Activate the category's first page. ribbon.SelectedPage = catSelection.Pages(0) ' Respond to item clicking. Sub ribbon_ItemClick(ByVal sender As Object, ByVal e As ItemClickEventArgs) '... End Sub |
