本示例展示了如何使用一个 XtraTabbedMdiManager 组件在 MDI 应用程序中实现标签式界面。
当主窗体 (MDI 父窗体) 被加载时,通过设置 XtraTabbedMdiManager.MdiParent 属性,把一个 XtraTabbedMdiManager 对象绑定到此窗体。 另外,在主窗体顶部创建了一个工具栏,它包含一个 New 命令。 按下 New 命令将创建一个 MDI 子窗体,并且自动通过 XtraTabbedMdiManager 而把它显示为一个标签页。
创建两个子窗体的结果显示在下面:
using System; using System.Windows.Forms; using DevExpress.XtraTabbedMdi; using DevExpress.XtraBars; namespace WindowsFormsApplication59 { public partial class Form1 : Form { public Form1() { InitializeComponent(); } private void Form1_Load(object sender, EventArgs e) { // Create a BarManager that will display a bar of commands at the top of the main form. BarManager barManager = new BarManager(); barManager.Form = this; // Create a bar with a New button. barManager.BeginUpdate(); Bar bar = new Bar(barManager, "My Bar"); bar.DockStyle = BarDockStyle.Top; barManager.MainMenu = bar; BarItem barItem = new BarButtonItem(barManager, "New"); barItem.ItemClick += new ItemClickEventHandler(barItem_ItemClick); bar.ItemLinks.Add(barItem); barManager.EndUpdate(); // Create an XtraTabbedMdiManager that will manage MDI child windows. XtraTabbedMdiManager mdiManager = new XtraTabbedMdiManager(); mdiManager.MdiParent = this; } int ctr = 0; void barItem_ItemClick(object sender, ItemClickEventArgs e) { // Create an MDI child form. Form2 f = new Form2(); f.Text = "Child Form " + (++ctr).ToString(); f.MdiParent = this; f.Show(); } } } |
Imports DevExpress.XtraBars Imports DevExpress.XtraTabbedMdi Public Class Form1 Private Sub Form1_Load(ByVal sender As System.Object, _ ByVal e As System.EventArgs) Handles MyBase.Load ' Create a BarManager that will display a bar of commands at the top of the main form. Dim barManager As BarManager = New BarManager() barManager.Form = Me ' Create a bar with a New button. barManager.BeginUpdate() Dim bar As Bar = New Bar(barManager, "My Bar") bar.DockStyle = BarDockStyle.Top barManager.MainMenu = bar Dim barItem As BarItem = New BarButtonItem(barManager, "New") AddHandler barItem.ItemClick, AddressOf barItem_ItemClick bar.ItemLinks.Add(barItem) barManager.EndUpdate() ' Create an XtraTabbedMdiManager that will manage MDI child windows. Dim mdiManager As XtraTabbedMdiManager = New XtraTabbedMdiManager() mdiManager.MdiParent = Me End Sub Private ctr As Integer = 0 Private Sub barItem_ItemClick(ByVal sender As Object, ByVal e As ItemClickEventArgs) ' Create an MDI child form. Dim f As Form2 = New Form2() ctr = ctr + 1 f.Text = "Child Form " & ctr.ToString() f.MdiParent = Me f.Show() End Sub End Class |
