在下面的示例中,一个新面板被创建并且被浮动。 然后把一个属性网格添加到此停靠面板中,并且列出了此面板的属性。 为了把可视化控件添加到此面板中,使用了 DockPanel.ControlContainer 属性。 结果显示如下:
// Create a floating dock panel.
DockPanel panel1 = dockManager1.AddPanel(DockingStyle.Float);
panel1.Text = "Panel 1";
// Create a property grid and place it on the panel.
PropertyGrid pGrid = new PropertyGrid();
panel1.ControlContainer.Controls.Add(pGrid);
pGrid.Dock = DockStyle.Fill;
pGrid.SelectedObject = panel1;
' Create a floating dock panel.
Dim panel1 As DockPanel = DockManager1.AddPanel(DockingStyle.Float)
' Create a property grid and place it on the panel.
Dim pGrid As PropertyGrid = New PropertyGrid
