下面的示例展示了如何创建和定制一个 item 及其 links。
在本例中,创建了一个 BarButtonItem 项。 然后,此 item 的两个 links 被分别添加到 bar 和子菜单中。 为第二个 link 指定了自定义标题。 第一个 link 则使用 item 的默认标题。
//A bar manager providing the XtraBars functionality BarManager bManager; //Initialize the bManager object //...bManager = barManager1; //Create an item, add it to the bar manager's item collection BarItem item = new BarButtonItem(bManager, "New"); //Set the bar item's ID to allow the bar's layout to be saved and restored correctly item.Id = bManager.GetNewItemId(); //A bar to which the item will be added Bar bar1; //Initialize the bar1 object //...bar1 = toolBar1; //A submenu to which the item will be added BarSubItem subMenu1; //Initialize the subMenu1 object //...subMenu1 = mFile; //Create a link to the item within the bar BarItemLink link1 = bar1.AddItem(item); //Create another link to the item within the submenu BarItemLink link2 = subMenu1.AddItem(item); //Change the second link's caption link2.UserCaption = "Create File..."; |
'A bar manager providing the XtraBars functionality Dim bManager As BarManager 'Initialize the bManager object '...bManager = barManager1 'Create an item, add it to the bar manager's item collection Dim item As BarItem = New BarButtonItem(bManager, "New") 'Set the bar item's ID to allow the bar's layout to be saved and restored correctly item.Id = bManager.GetNewItemId() 'A bar to which the item will be added Dim bar1 As Bar 'Initialize the bar1 object '...bar1 = toolBar1 'A submenu to which the item will be added Dim subMenu1 As BarSubItem 'Initialize the subMenu1 object '...subMenu1 = mFile 'Create a link to the item within the bar Dim link1 As BarItemLink = bar1.AddItem(item) 'Create another link to the item within the submenu Dim link2 As BarItemLink = subMenu1.AddItem(item) 'Change the second link's caption link2.UserCaption = "Create File..." |
