下面的示例展示了当 Ribbon 合并机制被调用时,如何在一个 MDI 应用程序中合并 RibbonStatusBar 对象。 假设父/子 MDI 窗体中都包含了 RibbonStatusBar 对象。 为了合并它们,RibbonStatusBar.MergeStatusBar 方法在 RibbonControl.Merge 事件处理程序中被调用。 为了取消合并状态栏,RibbonStatusBar.UnMerge 方法在 RibbonControl.UnMerge 事件处理程序中被调用。
C# | 复制代码 |
using DevExpress.XtraBars.Ribbon;
ribbonControl1.MdiMergeStyle = DevExpress.XtraBars.Ribbon.RibbonMdiMergeStyle.OnlyWhenMaximized;
private void ribbonControl1_Merge(object sender, RibbonMergeEventArgs e) {
RibbonControl parentRribbon = sender as RibbonControl;
RibbonControl childRibbon = e.MergedChild;
parentRribbon.StatusBar.MergeStatusBar(childRibbon.StatusBar);
private void ribbonControl1_UnMerge(object sender, RibbonMergeEventArgs e) {
parentRribbon.StatusBar.UnMergeStatusBar();
Visual Basic | 复制代码 |
Imports DevExpress.XtraBars.Ribbon
Private ribbonControl1.MdiMergeStyle = _
Private Sub RibbonControl1_Merge(ByVal sender As System.Object, _
ByVal e As RibbonMergeEventArgs) Handles RibbonControl1.Merge
Dim parentRribbon As RibbonControl = TryCast(sender, RibbonControl)
Dim childRibbon As RibbonControl = e.MergedChild
Private Sub RibbonControl1_UnMerge(ByVal sender As System.Object, _
ByVal e As RibbonMergeEventArgs) Handles RibbonControl1.UnMerge
