下面的示例代码接管了 TreeList.NodeCellStyle 事件来修改“Budget”列中取值大于 500,000 的单元格的外观。
下面的插图展示了运行结果。
using DevExpress.XtraTreeList; private void treeList1_NodeCellStyle(object sender, GetCustomNodeCellStyleEventArgs e) { // Modifying the appearance settings used to paint the "Budget" column's cells // whose values are greater than 500,000 . if (e.Column.FieldName != "Budget") return; if (Convert.ToInt32(e.Node.GetValue(e.Column.AbsoluteIndex)) > 500000) { e.Appearance.BackColor = Color.FromArgb(80, 255, 0, 255); e.Appearance.ForeColor = Color.White; e.Appearance.Font = new Font(e.Appearance.Font, FontStyle.Bold); } } | |
Imports DevExpress.XtraTreeList Private Sub TreeList1_NodeCellStyle(ByVal sender As Object, _ ByVal e As GetCustomNodeCellStyleEventArgs) Handles TreeList1.CustomNodeCellStyle ' Modifying the appearance settings used to paint the "Budget" column's cells ' whose values are greater than 500,000 . If e.Column.FieldValue <> "Budget" Exit Sub If Convert.ToInt32(e.Node.GetValue(BudgetColumnID)) > 500000 Then e.Appearance.BackColor = Color.FromArgb(80, 255, 0, 255) e.Appearance.ForeColor = Color.White e.Appearance.Font = New Font(e.Appearance.Font, FontStyle.Bold) End If End Sub | |
