下面的示例代码接管了 TreeList.CustomDrawNodeCell 事件。 此事件用于执行节点单元格的自定义绘制。 以相同的方式绘制所有节点单元格。 但是,可以根据节点设置执行不同的绘制。 请参阅 CustomDraw 演示获得更复杂的节点绘制示例。
下面的插图显示了示例代码的运行结果。
using System.Drawing; using System.Drawing.Drawing2D; using DevExpress.XtraTreeList; private void treeList1_CustomDrawNodeCell(object sender, CustomDrawNodeCellEventArgs e) { // obtaining brushes for cells of focused and unfocused nodes Brush backBrush, foreBrush; if (e.Node != (sender as TreeList).FocusedNode) { backBrush = new LinearGradientBrush(e.Bounds, Color.Orange, Color.PeachPuff, LinearGradientMode.Horizontal); foreBrush = new SolidBrush(Color.Black); } else { backBrush = new SolidBrush(Color.DarkBlue); foreBrush = new SolidBrush(Color.PeachPuff); } // filling the background e.Graphics.FillRectangle(backBrush, e.Bounds); // painting node value e.Graphics.DrawString(e.CellText, e.Appearance.Font, foreBrush, e.Bounds, e.Appearance.GetStringFormat()); // prohibiting default painting e.Handled = true; } |
Imports System.Drawing Imports System.Drawing.Drawing2D Imports DevExpress.XtraTreeList Private Sub TreeList1_CustomDrawNodeCell(ByVal sender As Object, _ ByVal e As CustomDrawNodeCellEventArgs) Handles TreeList1.CustomDrawNodeCell ' obtaining brushes for cells of focused and unfocused nodes Dim BackBrush, ForeBrush As Brush If e.Node.Id <> sender.FocusedNode.Id Then BackBrush = New LinearGradientBrush(e.Bounds, Color.Orange, Color.PeachPuff, _ LinearGradientMode.Horizontal) ForeBrush = New SolidBrush(Color.Black) Else BackBrush = New SolidBrush(Color.DarkBlue) ForeBrush = New SolidBrush(Color.PeachPuff) End If ' filling the background e.Graphics.FillRectangle(BackBrush, e.Bounds) ' painting node value Dim ValueRect As New RectangleF(e.Bounds.X, e.Bounds.Y, e.Bounds.Width, _ e.Bounds.Height) e.Graphics.DrawString(e.CellText, e.Appearance.Font, ForeBrush, ValueRect, _ e.Appearance.GetStringFormat()) ' prohibiting default painting e.Handled = True End Sub |
