下面的示例演示了如何把一个自定义菜单项添加到标准的上下文菜单中,并且为此菜单项订阅了单击事件。 TreeList.ShowTreeListMenu 事件被接管,以便于把 Clear All 菜单项添加到 汇总脚注菜单 中。 单击此菜单项则取消所有树状列表列的汇总计算。
下面的插图展示了运行结果。
using DevExpress.Utils.Menu; using DevExpress.XtraTreeList; using DevExpress.XtraTreeList.Columns; //... private void treeList1_ShowTreeListMenu(object sender, DevExpress.XtraTreeList.TreeListMenuEventArgs e) { TreeListHitInfo hitInfo = treeList1.CalcHitInfo(e.Point); if(hitInfo.HitInfoType == HitInfoType.SummaryFooter) e.Menu.Items.Add(new DXMenuItem("Clear All", new EventHandler(this.clearAllMenuItemClick))); } private void clearAllMenuItemClick(object sender, EventArgs e) { foreach (TreeListColumn column in treeList1.Columns) column.SummaryFooter = SummaryItemType.None; } |
Imports DevExpress.Utils.Menu Imports DevExpress.XtraTreeList Imports DevExpress.XtraTreeList.Columns '... Private Sub TreeList1_ShowTreeListMenu(ByVal sender As Object, ByVal e As DevExpress.XtraTreeList.TreeListMenuEventArgs) Handles TreeList1.ShowTreeListMenu Dim HitInfo As TreeListHitInfo = TreeList1.CalcHitInfo(e.Point) If HitInfo.HitInfoType = HitInfoType.SummaryFooter Then e.Menu.Items.Add(New DXMenuItem("Clear All", AddressOf Me.clearAllMenuItemClick)) End If End Sub Private Sub clearAllMenuItemClick(ByVal sender As Object, ByVal e As EventArgs) Dim Column As TreeListColumn For Each Column In TreeList1.Columns Column.SummaryFooter = SummaryItemType.None Next End Sub |
