查看: 2955|回复: 0
Lookupedit使用求助,跪求帮助
发表于 2017-9-20 17:26:14 | 显示全部楼层 |阅读模式
lookupEdit,绑定数据源后,无论选择哪一行数据,鼠标单击完之后,都是显示第一行数据,怎么都调整不好
绑定数据源代码
#region//添加lookup数据源
            Public_class.LookUpEdit_Tools.InitLookUpEdit(lookUpEdit_distributor,
                new string[] { "en_name", "distributor" },
                new string[] { "客户名称", "分销商" },
                new int[] { 50, 80 },
                dictionart_fxs, "en_name", "distributor", 5);
            #endregion
使用的方法:
#region//初始化LookUpEdit控件 (加载数据表中的一列或多列,且显示下拉列标题,可以设置下拉列的宽度)
        /// 初始化LookUpEdit控件 (加载数据表中的一列或多列,且显示下拉列标题,可以设置下拉列的宽度)
        /// <param name="lookUpEdit">空间名称</param>
        /// <param name="fields">下拉要显示的列</param>
        /// <param name="captions">下拉要显示的列标题</param>
        /// <param name="widths">下拉显示列的宽度  如果null 宽度为系统默认 </param>
        /// <param name="dt">绑定的数据表</param>
        /// <param name="valueMember">绑定列</param>
        /// <param name="displayMember">显示列</param>
        /// <param name="dropDownRows">下拉最多显示个数 如果为0,显示全部</param>
        public static void InitLookUpEdit(DevExpress.XtraEditors.LookUpEdit lookUpEdit,
           string[] fields, string[] captions, int[] widths,
           DataTable dt, string valueMember, string displayMember, int dropDownRows)
            lookUpEdit.Properties.NullText = "---请选择---";
            lookUpEdit.Properties.Columns.Clear();
            if (fields.Length != captions.Length)
                return;
            for (int i = 0; i < fields.Length; i++)
                if (widths != null)
                    if (fields.Length != widths.Length)
                        return;
                    lookUpEdit.Properties.Columns.Add(new DevExpress.XtraEditors.Controls.LookUpColumnInfo(fields, widths, captions));
                    lookUpEdit.Properties.Columns.Visible = widths == 0 ? false : true;
                else
                    lookUpEdit.Properties.Columns.Add(new DevExpress.XtraEditors.Controls.LookUpColumnInfo(fields, captions));
                lookUpEdit.Properties.Columns.Alignment = DevExpress.Utils.HorzAlignment.Center;
            if (widths == null)
                lookUpEdit.Properties.Columns[valueMember].Visible = false;
            lookUpEdit.Properties.DataSource = dt;
            lookUpEdit.Properties.ValueMember = valueMember;
            lookUpEdit.Properties.DisplayMember = displayMember;
            lookUpEdit.Properties.ShowHeader = true;
            lookUpEdit.Properties.ShowFooter = false;
            if (dropDownRows == 0)
                lookUpEdit.Properties.DropDownRows = dt.Rows.Count + 1;
            else
                lookUpEdit.Properties.DropDownRows = dt.Rows.Count > dropDownRows ? dropDownRows : dt.Rows.Count;
        #endregion
GMT+8, 2025-4-20 19:34
