- 33
- 53 小时
- 28
- 2013-8-31
- 132
- 2019-10-21
- 132
- 3320
- 53 小时
- 2013-8-31
客官请骚等......
代码奉上
private void BtnOpen_Click(object sender, EventArgs e)
OpenFileDialog ofd = new OpenFileDialog();
ofd.Title = "Excel文件";
ofd.FileName = "";
ofd.InitialDirectory = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments);//为了获取特定的系统文件夹,可以使用System.Environment类的静态方法GetFolderPath()。该方法接受一个Environment.SpecialFolder枚举,其中可以定义要返回路径的哪个系统目录
ofd.Filter = "所有文件(*.*)|*.*|Excel2003文件(*.xls)|*.xls|Excel2007文件(*.xlsx)|*.xlsx"; //获取或设置筛选器字符串,该字符串确定在 SaveFileDialog 中显示的文件类型
ofd.ValidateNames = true; //文件有效性验证ValidateNames,验证用户输入是否是一个有效的Windows文件名
ofd.CheckFileExists = true; //验证路径有效性
ofd.CheckPathExists = true; //验证文件有效性
string strName = string.Empty;
if (ofd.ShowDialog() == DialogResult.OK)
strName = ofd.FileName;
if (strName == "")
MessageBox.Show("没有选择Excel文件!无法进行数据导入");
return;
DataSet ds = GetDataFromExcel(strName);
this.gridControl1.DataSource = ds.Tables[0].DefaultView;
public static DataSet GetDataFromExcel(string ExcelFileName)
string strConn;
DataSet myDataSet = new DataSet();
try
strConn = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + ExcelFileName + ";Extended Properties='Excel 8.0;HDR=Yes;IMEX=1'";
OleDbConnection conn = new OleDbConnection(strConn);
OleDbDataAdapter myCommand = new OleDbDataAdapter("SELECT * FROM [Sheet1$] ", strConn);
myCommand.Fill(myDataSet);
conn.Close();
catch (Exception ee)
XtraMessageBox.Show("从电子表格文件中装载数据异常!", ee.Message);
finally
GC.Collect();
return myDataSet;
private void BtnOut_Click(object sender, EventArgs e)
SaveFileDialog saveFileDialog = new SaveFileDialog();
saveFileDialog.Title = "导出Excel";
saveFileDialog.FileName = "导出的文件";
saveFileDialog.Filter = "Excel文件(*.pdf)|*.pdf";
DialogResult dialogResult = saveFileDialog.ShowDialog(this);
if (dialogResult == DialogResult.OK)
gridControl1.ExportToPdf(saveFileDialog.FileName);
DevExpress.XtraEditors.XtraMessageBox.Show("保存成功!", "提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
前台页面只需二个按钮和一个gridControl就可以了
当导出的PDF是乱码的解决办法
using System;
using System.Linq;
using System.Windows.Forms;
namespace CntpyCopy
static class Program
/// 应用程序的主入口点。
[STAThread]
static void Main()
DevExpress.Utils.AppearanceObject.DefaultFont = new System.Drawing.Font("宋体", 9);
Application.EnableVisualStyles();
Application.SetCompatibleTextRenderingDefault(false);
Application.Run(new WinFrom());
DevExpress.Utils.AppearanceObject.DefaultFont = new System.Drawing.Font("宋体", 9); //在程序入口地方加上这行就能实现导出不是乱码的问题
