- 33
- 53 小时
- 28
- 2013-8-31
- 回帖
- 104
- 2019-10-21
- 回帖
- 104
- 3330
- 53 小时
- 2013-8-31
private void simpleButton1_Click(object sender, EventArgs e)
OpenFileDialog ofd = new OpenFileDialog();
ofd.Title = "Excel文件";
ofd.FileName = "";
ofd.InitialDirectory = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments);
ofd.Filter = "所有文件(*.*)|*.*|Excel2003文件(*.xls)|*.xls|Excel2007文件(*.xlsx)|*.xlsx";
ofd.ValidateNames = true;
ofd.CheckFileExists = true;
ofd.CheckPathExists = true;
string strName = string.Empty;
if (ofd.ShowDialog() == DialogResult.OK)
strName = ofd.FileName;
if (strName == "")
XtraMessageBox.Show("没有选择Excel文件!无法进行数据导入");
return;
else
try
DataSet myDs = new DataSet();
string text = string.Format("Provider = Microsoft.Jet.OLEDB.4.0 ; Data Source = '{0}';Extended Properties=Excel 8.0", strName);
string excelFirstTableName = GetExcelFirstTableName(text);
myDs.Tables.Clear();
myDs.Clear();
this.gridControl1.DataSource = null;
OleDbConnection selectConnection = new OleDbConnection(text);
OleDbDataAdapter oleDbDataAdapter = new OleDbDataAdapter(string.Format("select * from [{0}]", excelFirstTableName), selectConnection);
oleDbDataAdapter.Fill(myDs);
this.gridControl1.DataSource = myDs.Tables[0];
this.gridView1.PopulateColumns();
catch (Exception ex)
XtraMessageBox.Show("从电子表格文件中装载数据异常!", ex.Message);
} /// <summary>
/// 返回Excel第一个工作表表名
/// <param name="connectstring">excel连接字符串</param>
/// <returns></returns>
public static string GetExcelFirstTableName(string connectstring)
using (OleDbConnection connection = new OleDbConnection(connectstring))
string tableName = string.Empty;
if (connection.State == ConnectionState.Closed)
connection.Open();
DataTable dt = connection.GetOleDbSchemaTable(OleDbSchemaGuid.Tables, null);
if (dt != null && dt.Rows.Count > 0)
tableName = ConvertTo<string>(dt.Rows[0][2]);
return tableName;
/// 将数据转换为指定类型
/// <typeparam name="T">转换的目标类型</typeparam>
/// <param name="data">转换的数据</param>
public static T ConvertTo<T>(object data)
if (data == null || Convert.IsDBNull(data))
return default(T);
object obj = ConvertTo(data, typeof(T));
if (obj == null)
return default(T);
return (T)obj;
/// 将数据转换为指定类型
/// <param name="targetType">转换的目标类型</param>
public static object ConvertTo(object data, Type targetType)
return null;
Type type2 = data.GetType();
if (targetType == type2)
return data;
if (((targetType == typeof(Guid)) || (targetType == typeof(Guid?))) && (type2 == typeof(string)))
if (string.IsNullOrEmpty(data.ToString()))
return null;
return new Guid(data.ToString());
if (targetType.IsEnum)
try
return Enum.Parse(targetType, data.ToString(), true);
catch
return Enum.ToObject(targetType, data);
if (targetType.IsGenericType)
targetType = targetType.GetGenericArguments()[0];
return Convert.ChangeType(data, targetType);
