查看: 4341|回复: 1
ChartControl 常用方法
53 小时
发表于 2013-8-31 19:05:54 | 显示全部楼层 |阅读模式
一般常用的绑定方法
private void BtnQuery_Click(object sender, EventArgs e)
            string sql = @"SELECT codedevice.s_devid,issue.s_saledt,issue.f_execamt FROM issue,codedevice noholdlock
WHERE (issue.s_posid = codedevice.s_devid) and (issue.s_saledt = (select max(issue.s_saledt) from issue))";
            DataSet ds = Common.SybaseHelper.Query(sql);
            this.chartControl1.DataSource = ds.Tables[0];
            this.chartControl1.SeriesDataMember = "s_saledt";
            this.chartControl1.SeriesTemplate.ArgumentDataMember = "s_devid";
            this.chartControl1.SeriesTemplate.ValueDataMembers.AddRange(new string[] { "f_execamt" });
            this.chartControl1.SeriesTemplate.PointOptions.ValueNumericOptions.Format = NumericFormat.Currency;
            ChartTitle CT1 = new ChartTitle();
            CT1.Text = "POS实时销售图";
            chartControl1.Titles.Clear();
            chartControl1.Titles.Add(CT1);
            this.chartControl1.SeriesTemplate.View = new StackedBarSeriesView();
            this.chartControl1.SeriesNameTemplate.BeginText = "销售日期: ";
柱形图
            this.chartControl1.Series.Clear();
            Series S1 = new Series("柱状图", ViewType.Bar);
            S1.ArgumentScaleType = ScaleType.Qualitative;
            S1.DataSource = ds.Tables[0].DefaultView;
            S1.ArgumentDataMember = "s_devid";
            S1.ValueDataMembers[0] = "f_execamt";
            S1.PointOptions.ValueNumericOptions.Format = NumericFormat.Currency;
            this.chartControl1.Series.Add(S1);
            this.chartControl1.Legend.Visible = false;//不现实指示图
饼形图
            Series Serices1 = new Series("饼形图 ", ViewType.Pie3D);
            chartControl1.Series.Add(Serices1);
            Serices1.DataSource = ds.Tables[0].DefaultView; ;
            Serices1.ArgumentScaleType = ScaleType.Qualitative;
            Serices1.ArgumentDataMember = "s_devid";
            Serices1.ValueScaleType = ScaleType.Numerical;
            Serices1.ValueDataMembers.AddRange(new string[] { "f_execamt" });
            Serices1.PointOptions.PointView = PointView.ArgumentAndValues;
            Serices1.PointOptions.ValueNumericOptions.Format = NumericFormat.Percent;
            chartControl1.Visible = true;
53 小时
 楼主| 发表于 2013-8-31 19:17:28 | 显示全部楼层
今后如有更好的方法我再添加上去
GMT+8, 2025-4-4 01:12
