查看: 3846|回复: 0
GridControl 绑定显示列
53 小时
发表于 2013-9-1 14:43:32 | 显示全部楼层 |阅读模式
        /// 绑定显示列
        private void gridView1_CustomColumnDisplayText(object sender, DevExpress.XtraGrid.Views.Base.CustomColumnDisplayTextEventArgs e)
            if (e.Column.FieldName == "Sex")
                switch (e.Value.ToString().Trim())
                    default:
                    case "1":
                        e.DisplayText = "男";
                        break;
                    case "0":
                        e.DisplayText = "女";
                        break;
            if (e.Column.FieldName == "Enabled")
                    default:
                    case "1":
                        e.DisplayText = "在用";
                        break;
                    case "0":
                        e.DisplayText = "已停用";
                        break;
GMT+8, 2025-4-4 01:12
