查看: 5596|回复: 4
BaseForm 基类窗体,所有子窗体继承它
53 小时
发表于 2013-9-1 14:47:41 | 显示全部楼层 |阅读模式
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using DevExpress.Utils;
using DevExpress.XtraEditors;
using DevExpress.XtraGrid;
using DevExpress.XtraGrid.Columns;
using DevExpress.XtraGrid.Views.Base;
using DevExpress.XtraGrid.Views.Grid;
using DevExpress.XtraGrid.Views.Grid.ViewInfo;
using DevExpress.XtraPrinting;
namespace Nbjjy
    public partial class BaseForm : DevExpress.XtraEditors.XtraForm
        public BaseForm()
            InitializeComponent();
        #region 系统功能
        /// 系统初始载入
        /// <param name="e"></param>
        private void BaseForm_Load(object sender, EventArgs e)
            if (!base.DesignMode)
                this.Cursor = Cursors.WaitCursor; //等待状态
                try
                    this.FormOnLoad();
                catch (Exception ex)
                    this.ProcessException(ex);
                finally
                    this.Cursor = Cursors.Default;
        /// 初始化载入
        public virtual void FormOnLoad(){}
        /// 写入错误信息
        /// <param name="ex"></param>
        public void WriteException(Exception ex)
           //未写,后期再写
            DictItemUtil.AddLog(ex.Message);
        /// 错误处理
        public void ProcessException(Exception ex)
            this.WriteException(ex);
            MessageUtil.ShowError(ex.Message);
        /// TAB切换
        private void BaseForm_KeyUp(object sender, KeyEventArgs e)
            Keys keyCode = e.KeyCode;
            if (keyCode == Keys.F5)
                this.FormOnLoad();
            else if (((e.KeyCode == Keys.Return) || (e.KeyCode == Keys.Return)) && (((base.ActiveControl is TextEdit) || (base.ActiveControl is MemoEdit) || (base.ActiveControl is DevExpress.XtraEditors.ComboBoxEdit)) || (base.ActiveControl is CheckEdit)))
                if (base.ActiveControl is TextEdit)
                    return;
                SendKeys.Send("{TAB}");
        #endregion
        #region 复制行信息
        /// 复制行信息
        /// <param name="gridView1">GridView</param>
        public void CopyData(DevExpress.XtraGrid.Views.Grid.GridView gridView1)
            StringBuilder stringBuilder = new StringBuilder();
            StringBuilder stringBuilder2 = new StringBuilder();
            foreach (GridColumn gridColumn in gridView1.Columns)
                if (gridColumn.Visible)
                    stringBuilder.AppendFormat("{0} ", gridColumn.Caption);
            int[] selectedRows = gridView1.GetSelectedRows();
            int[] array = selectedRows;
            for (int i = 0; i < array.Length; i++)
                int rowHandle = array[i];
                        stringBuilder2.AppendFormat("{0} ", gridView1.GetRowCellDisplayText(rowHandle, gridColumn.FieldName));
                stringBuilder2.AppendLine();
            Clipboard.SetText(stringBuilder.ToString() + "\r\n" + stringBuilder2.ToString());
        #endregion
        #region 自定义显示列
        /// 自定义显示列
        public void CustomColumn(DevExpress.XtraGrid.Views.Grid.GridView gridView1)
            new CustomColumnDialog(gridView1.Columns).ShowDialog();
        #endregion
        #region 导出Excel
        /// 导出Excel
        /// <param name="gridControl">GridControl</param>
        /// <param name="fileName">导出文件名</param>
        public void ExportExcel(DevExpress.XtraGrid.GridControl gridControl, string fileName)
            if (gridControl.DataSource != null)
                SaveFileDialog saveFileDialog = new SaveFileDialog();
                saveFileDialog.Title = "导出Excel";
                saveFileDialog.Filter = "Excel文件(*.xls)|*.xls";
                saveFileDialog.FileName = fileName;
                DialogResult dialogResult = saveFileDialog.ShowDialog(this);
                if (dialogResult == DialogResult.OK)
                    gridControl.ExportToXls(saveFileDialog.FileName);
                    MessageUtil.ShowTips("保存成功!");
            else
                MessageUtil.ShowError("没有数据,系统无法为你导出信息!");
        #endregion
        #region 打印功能
        /// 打印功能
        /// <param name="PrintTitle">打印标题</param>
        public void ExportPrint(DevExpress.XtraGrid.GridControl gridControl, string PrintTitle)
            PrintingSystem printingSystem = new PrintingSystem();
            PrintableComponentLink printableComponentLink = new PrintableComponentLink();
            string[] value = new string[]
    PrintTitle,
            string[] value2 = new string[]
    "[page # of pages #]",
    "[Date Printed][Time Printed]"
            PageHeaderFooter pageHeaderFooter = new PageHeaderFooter();
            pageHeaderFooter.Header.Content.AddRange(value);
            pageHeaderFooter.Header.Font = new Font("隶书", 18f);
            pageHeaderFooter.Header.LineAlignment = BrickAlignment.Center;
            pageHeaderFooter.Footer.Content.AddRange(value2);
            printableComponentLink.PaperKind = printingSystem.PageSettings.PaperKind;
            printableComponentLink.Landscape = printingSystem.PageSettings.Landscape;
            printableComponentLink.PageHeaderFooter = pageHeaderFooter;
            printableComponentLink.Component = gridControl;
            printableComponentLink.CreateDocument(printingSystem);
            printingSystem.PageSettings.TopMargin = 100;
            printingSystem.PageSettings.LeftMargin = 40;
            printingSystem.PageSettings.RightMargin = 40;
            printingSystem.PageSettings.BottomMargin = 80;
            printingSystem.SetCommandVisibility(PrintingSystemCommand.Customize, CommandVisibility.None);
            printingSystem.SetCommandVisibility(PrintingSystemCommand.PageLayout, CommandVisibility.None);
            printingSystem.SetCommandVisibility(PrintingSystemCommand.Watermark, CommandVisibility.None);
            printingSystem.SetCommandVisibility(PrintingSystemCommand.EditPageHF, CommandVisibility.None);
            printingSystem.SetCommandVisibility(PrintingSystemCommand.ExportFile, CommandVisibility.None);
            printingSystem.SetCommandVisibility(PrintingSystemCommand.SendFile, CommandVisibility.None);
            printingSystem.PreviewFormEx.Text = "打印预览";
            printingSystem.PreviewFormEx.Owner = gridControl.FindForm();
            printingSystem.PreviewFormEx.Show();
        #endregion
        #region GridControl常用属性
        /// GridControl常用属性
        /// <param name="gridControl">GridControl属性</param>
        /// <param name="gridView1">GridView属性</param>
        /// <param name="AutoWidth">是否自动列宽</param>
        /// <param name="ShowLineNumber">是否显示行号</param>
        /// <param name="ShowNavigator">是否显示自带的分页功能</param>
        public void GridControlOnLoad(DevExpress.XtraGrid.GridControl gridControl, DevExpress.XtraGrid.Views.Grid.GridView gridView1, bool AutoWidth, bool ShowLineNumber, bool ShowNavigator)
            gridView1.RowHeight = 20;
            gridView1.ColumnPanelRowHeight = 22;
            gridView1.FooterPanelHeight = 20;
            gridView1.OptionsMenu.EnableColumnMenu = false;
            gridView1.OptionsMenu.EnableFooterMenu = false;
            gridView1.OptionsMenu.EnableGroupPanelMenu = false;
            gridView1.OptionsNavigation.AutoFocusNewRow = true;
            gridView1.OptionsView.ColumnAutoWidth = AutoWidth;
            gridView1.OptionsView.ShowFilterPanelMode = DevExpress.XtraGrid.Views.Base.ShowFilterPanelMode.Never;
            gridView1.OptionsView.ShowFooter = false;
            gridView1.OptionsView.ShowGroupPanel = false;
            gridView1.OptionsView.EnableAppearanceEvenRow = true;
            gridView1.OptionsView.EnableAppearanceOddRow = true;
            gridView1.OptionsView.ShowGroupExpandCollapseButtons = false;
            gridView1.OptionsCustomization.AllowFilter = false;
            gridView1.OptionsCustomization.AllowGroup = false;
            gridView1.OptionsBehavior.Editable = false;
            gridView1.OptionsBehavior.AllowAddRows = DevExpress.Utils.DefaultBoolean.False;
            gridView1.OptionsBehavior.AllowDeleteRows = DevExpress.Utils.DefaultBoolean.False;
            gridView1.OptionsBehavior.ReadOnly = true;
            gridView1.OptionsSelection.EnableAppearanceFocusedCell = false;
            gridView1.OptionsSelection.MultiSelect = true;
            gridView1.OptionsDetail.EnableMasterViewMode = false;
            gridView1.OptionsPrint.AutoWidth = AutoWidth;
            gridView1.OptionsPrint.UsePrintStyles = true;
            gridView1.OptionsLayout.Columns.StoreAllOptions = true;
            gridView1.FocusRectStyle = DevExpress.XtraGrid.Views.Grid.DrawFocusRectStyle.None;
            gridView1.AppearancePrint.Preview.BackColor = Color.White;
            gridView1.AppearancePrint.HeaderPanel.BackColor = Color.White;
            gridView1.AppearancePrint.FooterPanel.BackColor = Color.White;
            gridView1.AppearancePrint.GroupRow.BackColor = Color.White;
            gridView1.AppearancePrint.GroupFooter.BackColor = Color.White;
            gridView1.Appearance.EvenRow.BackColor = System.Drawing.Color.LightCyan;
            gridView1.Appearance.EvenRow.Options.UseBackColor = true;
            if (ShowLineNumber)
                gridView1.IndicatorWidth = 42;
                gridView1.CustomDrawRowIndicator += new DevExpress.XtraGrid.Views.Grid.RowIndicatorCustomDrawEventHandler(gridView1_CustomDrawRowIndicator);
            if (ShowNavigator)
                gridControl.EmbeddedNavigator.Buttons.CancelEdit.Visible = false;
                gridControl.EmbeddedNavigator.Buttons.Edit.Visible = false;
                gridControl.EmbeddedNavigator.Buttons.EndEdit.Visible = false;
                gridControl.EmbeddedNavigator.Buttons.Append.Visible = false;
                gridControl.EmbeddedNavigator.Buttons.Remove.Visible = false;
                gridControl.UseEmbeddedNavigator = true;
        /// 显示行号
        private void gridView1_CustomDrawRowIndicator(object sender, DevExpress.XtraGrid.Views.Grid.RowIndicatorCustomDrawEventArgs e)
            e.Appearance.TextOptions.HAlignment = DevExpress.Utils.HorzAlignment.Far;
            if (e.Info.IsRowIndicator)
                if (e.RowHandle >= 0)
                    e.Info.DisplayText = (e.RowHandle + 1).ToString();
        #endregion
        #region TreeList的常用属性
        /// TreeList的常用属性
        /// <param name="treeList1">TreeList属性</param>
        public void TreeListOnLoad(DevExpress.XtraTreeList.TreeList treeList1,bool check)
            treeList1.OptionsMenu.EnableColumnMenu = false;
            treeList1.OptionsMenu.EnableFooterMenu = false;
            treeList1.OptionsView.ShowIndicator = false;
            treeList1.OptionsView.ShowHorzLines = false;
            treeList1.OptionsView.ShowVertLines = false;
            treeList1.OptionsBehavior.Editable = false;
            treeList1.OptionsBehavior.AutoFocusNewNode = true;
            treeList1.Appearance.FocusedCell.BackColor = System.Drawing.Color.LightCyan;
            treeList1.Appearance.FocusedCell.BackColor2 = System.Drawing.Color.LightCyan;
            treeList1.Appearance.FocusedCell.Options.UseBackColor = true;
            if (check)
                treeList1.OptionsView.ShowCheckBoxes = true;
                treeList1.OptionsBehavior.AllowIndeterminateCheckState = true;
                treeList1.BeforeCheckNode += new DevExpress.XtraTreeList.CheckNodeEventHandler(treeList1_BeforeCheckNode);
                treeList1.AfterCheckNode += new DevExpress.XtraTreeList.NodeEventHandler(treeList1_AfterCheckNode);
            treeList1.ExpandAll();
        /// 全选
        private void treeList1_AfterCheckNode(object sender, DevExpress.XtraTreeList.NodeEventArgs e)
            SetCheckedChildNodes(e.Node, e.Node.CheckState);
            SetCheckedParentNodes(e.Node, e.Node.CheckState);
        /// 反选
        private void treeList1_BeforeCheckNode(object sender, DevExpress.XtraTreeList.CheckNodeEventArgs e)
            e.State = (e.PrevState == CheckState.Checked ? CheckState.Unchecked : CheckState.Checked);
        /// 设置子节点的状态
        /// <param name="node"></param>
        /// <param name="check"></param>
        private void SetCheckedChildNodes(DevExpress.XtraTreeList.Nodes.TreeListNode node, CheckState check)
            for (int i = 0; i < node.Nodes.Count; i++)
                node.Nodes[i].CheckState = check;
                SetCheckedChildNodes(node.Nodes[i], check);
        /// 设置父节点的状态
        private void SetCheckedParentNodes(DevExpress.XtraTreeList.Nodes.TreeListNode node, CheckState check)
            if (node.ParentNode != null)
                bool b = false;
                for (int i = 0; i < node.ParentNode.Nodes.Count; i++)
                    CheckState state = (CheckState)node.ParentNode.Nodes[i].CheckState;
                    if (!check.Equals(state))
                        b = !b;
                        break;
                node.ParentNode.CheckState = b ? CheckState.Indeterminate : check;
                SetCheckedParentNodes(node.ParentNode, check);
        #endregion
发表于 2013-9-26 14:13:13 | 显示全部楼层
好东西啊.谢谢分享
130 小时
发表于 2013-9-26 15:02:37 | 显示全部楼层
确实是好东西,谢谢
29 小时
发表于 2013-9-27 10:12:03 | 显示全部楼层
17 小时
发表于 2013-9-27 17:22:55 | 显示全部楼层
好东西,收藏!感谢分享
GMT+8, 2025-4-5 04:31
