查看: 5486|回复: 2
[源码] C# SqlBulkCopy使用心得
53 小时
发表于 2013-9-2 21:59:30 | 显示全部楼层 |阅读模式
方法一:
            string constring = System.Configuration.ConfigurationManager.ConnectionStrings["DB"].ConnectionString;
            string sql = "SELECT s_saledt,branch,f_execamt from cntpy order by branch";
            long sLocct = 0;
            DataTable dt = Common.SqlServerHelper.ExecuteTable(sql); //获取解析日志数据
            if (dt != null)
                System.Diagnostics.Stopwatch sw01 = new System.Diagnostics.Stopwatch();
                sw01.Start();
                ExecuteSqlBulkCopy(dt, "cntpy_do", constring); //批量插入(本人一次插入20万,30万没有试过,有兴趣自己研究)
                sw01.Stop();
                sLocct = sw01.ElapsedMilliseconds; //这里是自己加的 用来记录插入数据所花时间
            this.label1.Text = "用时:" + sLocct.ToString() + "秒";
        public void ExecuteSqlBulkCopy(DataTable dt, string strTableName, string strConn)
            using (SqlConnection conn = new SqlConnection(strConn))
                conn.Open();
                try
                    SqlBulkCopy bulk = new SqlBulkCopy(conn);
                    bulk.DestinationTableName = strTableName;  //表名
                    bulk.BatchSize = dt.Rows.Count;
                    bulk.BulkCopyTimeout = 180;
                    bulk.ColumnMappings.Add("s_saledt", "s_saledt"); //本地表和目标表列名
                    bulk.ColumnMappings.Add("branch", "branch");   //如果表有多个字段,下面继续添加
                    bulk.ColumnMappings.Add("f_execamt", "f_execamt");   //如果表有多个字段,下面继续添加
                    bulk.WriteToServer(dt);
                    bulk.Close();
                catch (Exception ex)
                    throw new Exception(ex.Message);
                finally
                    if (conn.State != ConnectionState.Closed) conn.Close();
方法二:
private void Main_Load(object sender, EventArgs e)
            string sql = "SELECT s_saledt,f_execamt,branch from cntpy order by branch";
            this.dataGridView1.DataSource = dt;
        private void button2_Click(object sender, EventArgs e)
            if (this.dataGridView1.DataSource != null)
                long sLocct = 0;
                sw01.Start();
                for (int i = 0; i < dataGridView1.Rows.Count - 1; i++)
                    string cmdInsert = String.Empty;
                    cmdInsert = "insert into cntpy_do(s_saledt,f_execamt,branch)";
                    cmdInsert += "VALUES('" + this.dataGridView1.Rows.Cells[0].Value + "'";
                    cmdInsert += ",'" + this.dataGridView1.Rows.Cells[1].Value + "'";
                    cmdInsert += ",'" + this.dataGridView1.Rows.Cells[2].Value + "')";
                    Common.SqlServerHelper.ExecuteSql(cmdInsert);
                sw01.Stop();
第二种方法执行的太慢了没有第一种方法好用,但第二种可以自由变换数据.
比如:
                string str="百货集团";
                long sLocct = 0;
                sw01.Start();
                    cmdInsert += ",'" + str+ "')";
                sw01.Stop();
那这样第三列就是你想要得到的名称.
参与人数 2赞扬 +2 收起 理由
rakehell + 1 Thanks
aolongxue + 1 Thanks
发表于 2013-9-28 14:26:53 | 显示全部楼层
我用过,确实速度很快,那你知道怎样快速批量更新吗?
27 小时
发表于 2013-9-30 11:41:23 | 显示全部楼层
很好的文章分享!!!
GMT+8, 2025-3-12 19:17
