- 18
- 814 小时
- 12
- 2013-7-4
- 174
- 2021-1-22
- 174
- 4587
- 814 小时
- 2013-7-4
官方下载:
http://download.allroundautomations.com/plsqldev1005.exe
注册机同9.x 注册机一样
Enhancements in PL/SQL Developer 10.0.5
* Test Window editor could not undo changes that were made before the last save
* You can now use an Excel=<filename> directive in a comment section of the SQL Window to set the filename for Excel export. Supports environment variables (e.g. %date%)
* Compare Table Data would generate a script with CR/LF pairs for single LF characters in the source table
* Double-clicking on the tab of a docked tool would undock it
* Breaking debugger execution on Oracle11g could cause a hang-up
* Table Definition Editor storage properties did not work correctly in combination with a language pack
* Test Window vertical splitter size was too small
