查看: 4805|回复: 0
[源码] C#执行存储过程通用类
740 小时
QQ
发表于 2013-10-29 16:30:19 | 显示全部楼层 |阅读模式
网上看到的,整理整齐有用的童鞋拿去.
using System.Data.SqlClient;
using System.Collections;
using System.Data;
namespace RunStoreProcedure
    /// 调用存储过程通用类
    public class StoreProcedure
        private string _name; // 存储过程名称。
        private string _conStr; // 数据库连接字符串。
        /// 构造函数
        /// <param name="sprocName">存储过程名称</param>
        /// <param name="conStr">数据库连接字符串</param>
        public StoreProcedure(string sprocName, string conStr)
            _conStr = conStr;
            _name = sprocName;
        /// 执行存储过程,不返回值
        /// <param name="paraValues"> 参数值列表</param>
        public void ExecuteNoQuery(params object[] paraValues)
            using (SqlConnection con = new SqlConnection(_conStr))
                SqlCommand comm = new SqlCommand(_name, con);
                comm.CommandType = CommandType.StoredProcedure;
                AddInParaValues(comm, paraValues);
                con.Open();
                comm.ExecuteNonQuery();
                con.Close();
        /// 执行存储过程,返回表
        /// <param name="paraValues">参数列表</param>
        /// <returns>DataTable</returns>
        public DataTable ExecuteDataTable(params object[] paraValues)
            SqlCommand comm = new SqlCommand(_name, new SqlConnection(_conStr));
            SqlDataAdapter sda = new SqlDataAdapter(comm);
            DataTable dt = new DataTable();
            sda.Fill(dt);
            return dt;
        /// 执行存储过程,返回SqlDataReader
        /// <returns>SqlDataReader</returns>
        public SqlDataReader ExecuteDataReader(params object[] paraValues)
            SqlConnection con = new SqlConnection(_conStr);
            con.Open();
            return comm.ExecuteReader(CommandBehavior.CloseConnection);
        /// 添加参数及赋值.
        /// <param name="comm">SqlCommand</param>
        private void AddInParaValues(SqlCommand comm, params object[] paraValues)
            comm.Parameters.Add(new SqlParameter("@RETURN_VALUE", SqlDbType.Int));
            comm.Parameters["@RETURN_VALUE"].Direction = ParameterDirection.ReturnValue;
            if (paraValues != null)
                ArrayList al = GetParas();
                for (int i = 0; i < paraValues.Length; i++)
                    comm.Parameters.AddWithValue(al[i + 1].ToString(), paraValues);
        ///  获取存储过程的参数列表
        /// <returns>ArrayList</returns>
        private ArrayList GetParas()
            SqlCommand comm = new SqlCommand("dbo.sp_sproc_columns_90", new SqlConnection(_conStr));
            comm.Parameters.AddWithValue("@procedure_name", (object) _name);
            sda.Fill(dt);
            ArrayList al = new ArrayList();
            for (int i = 0; i < dt.Rows.Count; i++)
                al.Add(dt.Rows[3].ToString());
            return al;
GMT+8, 2025-3-12 19:02
