查看: 4194|回复: 1
ASP.NET.Report.Maker.6.0(含注册机)
180 小时
发表于 2013-11-19 11:56:51 | 显示全部楼层 |阅读模式
ASP.NET Report Maker is a powerful reporting tool that can generate dynamic ASP.NET Web Pages (C# or VB.NET) from a Microsoft Access database or other ADO Data Source. You can instantly create live detail and summary reports or crosstabs reports (for Access, SQL Server, MySQL, PostgreSQL and Oracle) for your websites. Flash charting (column, bar, line, pie, area, doughnut, multi-series, stacked charts, Candlestick and Gantt) is also supported. The generated scripts are pure ASP.NET, no ActiveX control on the client side is required. ASP.NET Report Maker is designed for high flexibility, numerous options enable you to generate the reports that best suits your needs. The generated codes are clean and easy-to-customize. ASP.NET Report Maker can save you tons of time and is suitable for both beginners and experienced developers alike.
http://pan.baidu.com/s/1zi3tG
参与人数 4贡献 +4 赞扬 +4 收起 理由
冰河之刃 + 1 赞一个
grsmichael + 1 Thanks
羽叶 + 3 + 1 感谢分享
ssa521 + 1 + 1 感谢分享
83 小时
发表于 2015-6-27 21:02:52 | 显示全部楼层
研究一下看看。。。
GMT+8, 2025-4-4 17:42
