用户名  找回密码
查看: 5581|回复: 4
ASP.NET.Maker_10.1.0(含注册机)
180 小时
发表于 2013-11-18 21:36:13 | 显示全部楼层 |阅读模式
ASP.NET Maker is a powerful automation tool that can generate a full set of ASP.NET Web Pages quickly from a Microsoft Access, SQL Server, Mysql, Oracle, PostgreSQL or other ODBC Data Source. Using ASP.NET Maker, you can instantly create Web sites that allow users to view, edit, search, add and delete records on the Web. ASP.NET Maker is designed for high flexibility, numerous options enable you to generate ASP.NET applications that best suits your needs. The generated codes are clean, straightforward and easy-to-customize. ASP.NET Maker can save you tons of time and is suitable for both beginners and experienced developers alike.
http://pan.baidu.com/s/19rSRH
参与人数 3赞扬 +3 收起 理由
grsmichael + 1 感谢分享
ssa521 + 1 感谢分享
ynyuxiang + 1 Thanks
举报
发表于 2014-1-26 02:29:17 | 显示全部楼层
支持一下,不错的软件!
举报
67 小时
发表于 2014-6-1 00:07:33 | 显示全部楼层
thanks+thanks
举报
13 小时
发表于 2016-6-9 22:16:53 | 显示全部楼层
支持一下,不错的软件!
举报
13 小时
发表于 2016-7-16 15:45:12 | 显示全部楼层
不知道做什么用的  下载研究研究
举报
GMT+8, 2025-4-2 21:43
