查看: 6548|回复: 2
新人求助,DEV中checkbox的多选问题!
发表于 2013-11-29 14:33:11 | 显示全部楼层 |阅读模式
新人请教:
Dev的gridview里面添加了checkbox列,但是不能多选,高手们给个具体的例子,因为新手不咋熟悉,谢谢了!!!
1905 小时
胡吹海聊
发表于 2013-11-30 14:40:09 | 显示全部楼层
数据源设置一个bit格式
480 小时
发表于 2013-12-1 16:24:32 | 显示全部楼层
写过的一个通用多记录选择器, 可以通过checkbox多选记录
public partial class frmMulitDataSelector : frmBase
        GridCheckMarksSelection selection = null;
        /// 返回的选中行
        public DataTable ResultDataTable
            get;
            private set;
        public frmMulitDataSelector(DataTable dataSource, DataSelectorColumnInfo[] columnInfos = null, bool allowEdit = false)
            InitializeComponent();
            if (dataSource == null) throw new Exception("未设置数据源!");
            //初始化GridControl
            gc.DataSource = dataSource.Copy();
            gv.OptionsBehavior.Editable = allowEdit;
            gv.BestFitColumns();
            gv.Columns.Clear();
            if (columnInfos == null || columnInfos.Length == 0)
                gv.PopulateColumns();
            else
                List<GridColumn> columns = new List<GridColumn>();
                foreach (var info in columnInfos)
                    GridColumn col = new GridColumn();
                    col.Caption = info.Caption;
                    col.FieldName = info.FieldName;
                    col.Visible = true;
                    col.VisibleIndex = info.VisibleIndex;
                    col.OptionsColumn.AllowEdit = info.AllowEdit;
                    columns.Add(col);
                    if (col.OptionsColumn.AllowEdit) continue;
                    Font f = new System.Drawing.Font(col.AppearanceCell.Font, FontStyle.Bold);
                    col.AppearanceCell.Font = f;
                    col.AppearanceCell.Options.UseFont = true;
                    col.AppearanceCell.ForeColor = Color.DarkGray;// Color.FromArgb(127, 127, 127, 127);
                    col.AppearanceCell.Options.UseForeColor = true;
                gv.Columns.AddRange(columns.ToArray());
            //设置每列的默认Filter为Contains而不是StartWith
            for (int i = 0; i < gv.Columns.Count; i++)
                gv.Columns[i].OptionsFilter.AutoFilterCondition = AutoFilterCondition.Contains;
            selection = new GridCheckMarksSelection(gv);
        private void gv_SelectionChanged(object sender, DevExpress.Data.SelectionChangedEventArgs e)
            var cells = gv.GetSelectedCells().Where(row => row.Column == gv.FocusedColumn);
            if (cells.Count() > 1)
                foreach (var cell in cells)
                    selection.SelectRow(cell.RowHandle, true);
        private void btOK_Click(object sender, EventArgs e)
            if (selection.SelectedCount == 0)
                Msg.ShowInformation("请至少选择一条记录!");
            else
                //构造datatable
                DataTable dataSource = gc.DataSource as DataTable;
                DataTable dtRet = dataSource.Clone();
                for (int i = 0; i < selection.SelectedCount; i++)
                    DataRow dr = (selection.GetSelectedRow(i) as DataRowView).Row;
                    dtRet.ImportRow(dr);
                ResultDataTable = dtRet;
                this.DialogResult = System.Windows.Forms.DialogResult.OK;
        private void btnAdjust_Click(object sender, EventArgs e)
        private void btnSelectAll_Click(object sender, EventArgs e)
            selection.SelectAll();
        private void btnInvertSelection_Click(object sender, EventArgs e)
            for(int i = 0;i<gv.DataRowCount;i++)
                selection.InvertRowSelection(i);
        private void gv_PopupMenuShowing(object sender, DevExpress.XtraGrid.Views.Grid.PopupMenuShowingEventArgs e)
            if (e.MenuType == GridMenuType.Row)
                if (gv.FocusedColumn != null)
                    if (cells.Count() > 1 )
                        DXMenuItem miSelect = new DXMenuItem("选择(&S)",
                            (pSender,pEventArgs) =>
                                foreach(var cell in cells)
                        DXMenuItem miUnSelect = new DXMenuItem("取消选择(&U)",
                            (pSender,pEventArgs)=>
                                    selection.SelectRow(cell.RowHandle, false);
                        e.Menu.Items.Add(miSelect);
                        e.Menu.Items.Add(miUnSelect);
                //fillzonevalue
                var column = gv.FocusedColumn;
                if (column.OptionsColumn.AllowEdit)
                    var cells = gv.GetSelectedCells().Where(row => row.Column == column).ToArray();
                    if (cells.Count() > 1 && gv.GetSelectedCells().GroupBy(row => row.Column).Count() == 1)
                        DXMenuItem miFillCellValue = new DXMenuItem("填充相同值到选中区域(&F)",
                            (pSender, pEventArgs) =>
                                object fillValue = gv.GetRowCellValue(cells[0].RowHandle, cells[0].Column);
                                for (int i = 1; i < cells.Length; i++)
                                    gv.SetRowCellValue(cells[i].RowHandle, cells[i].Column, fillValue);
                        e.Menu.Items.Add(miFillCellValue);
        private void gv_RowCellClick(object sender, RowCellClickEventArgs e)
            if (e.Column != selection.CheckMarkColumn && e.Column.OptionsColumn.AllowEdit == false && gv.GetSelectedCells().Length == 1)
                selection.InvertRowSelection(e.RowHandle);
        private void gv_RowCellStyle(object sender, RowCellStyleEventArgs e)
    public class GridCheckMarksSelection
        protected GridView _view;
        protected ArrayList selection;
        GridColumn column;
        RepositoryItemCheckEdit edit;
        const int CheckboxIndent = 4;
        public GridCheckMarksSelection()
            selection = new ArrayList();
        public GridCheckMarksSelection(GridView view)
            : this()
            View = view;
        public GridView View
            get { return _view; }
            set
                if (_view != value)
                    Detach();
                    Attach(value);
        public GridColumn CheckMarkColumn { get { return column; } }
        public int SelectedCount { get { return selection.Count; } }
        public object GetSelectedRow(int index)
            return selection[index];
        public int GetSelectedIndex(object row)
            return selection.IndexOf(row);
        public void ClearSelection()
            selection.Clear();
            Invalidate();
        public void SelectAll()
            selection.Clear();
            // fast (won't work if the grid is filtered)
            //if(_view.DataSource is ICollection)
            //        selection.AddRange(((ICollection)_view.DataSource));
            //else
            // slow:
            for (int i = 0; i < _view.DataRowCount; i++)
                selection.Add(_view.GetRow(i));
            Invalidate();
        public void SelectGroup(int rowHandle, bool select)
            if (IsGroupRowSelected(rowHandle) && select) return;
            for (int i = 0; i < _view.GetChildRowCount(rowHandle); i++)
                int childRowHandle = _view.GetChildRowHandle(rowHandle, i);
                if (_view.IsGroupRow(childRowHandle))
                    SelectGroup(childRowHandle, select);
                else
                    SelectRow(childRowHandle, select, false);
            Invalidate();
        public void SelectRow(int rowHandle, bool select)
            SelectRow(rowHandle, select, true);
        public void InvertRowSelection(int rowHandle)
            if (View.IsDataRow(rowHandle))
                SelectRow(rowHandle, !IsRowSelected(rowHandle));
            if (View.IsGroupRow(rowHandle))
                SelectGroup(rowHandle, !IsGroupRowSelected(rowHandle));
        public bool IsGroupRowSelected(int rowHandle)
                int row = _view.GetChildRowHandle(rowHandle, i);
                if (_view.IsGroupRow(row))
                    if (!IsGroupRowSelected(row)) return false;
                else
                    if (!IsRowSelected(row)) return false;
            return true;
        public bool IsRowSelected(int rowHandle)
            if (_view.IsGroupRow(rowHandle))
                return IsGroupRowSelected(rowHandle);
            object row = _view.GetRow(rowHandle);
            return GetSelectedIndex(row) != -1;
        protected virtual void Attach(GridView view)
            if (view == null) return;
            selection.Clear();
            this._view = view;
            view.BeginUpdate();
            try
                edit = view.GridControl.RepositoryItems.Add("CheckEdit") as RepositoryItemCheckEdit;
                column = view.Columns.Add();
                column.OptionsColumn.AllowSort = DevExpress.Utils.DefaultBoolean.False;
                column.Visible = true;
                column.VisibleIndex = 0;
                column.FieldName = "CheckMarkSelection";
                column.Caption = "Mark";
                column.OptionsColumn.ShowCaption = false;
                column.OptionsColumn.AllowEdit = false;
                column.OptionsColumn.AllowSize = false;
                column.OptionsFilter.AllowFilter = false;
                column.OptionsFilter.AllowAutoFilter = false;
                column.UnboundType = DevExpress.Data.UnboundColumnType.Boolean;
                column.Width = GetCheckBoxWidth();
                column.ColumnEdit = edit;
                view.Click += new EventHandler(View_Click);
                view.CustomDrawColumnHeader += new ColumnHeaderCustomDrawEventHandler(View_CustomDrawColumnHeader);
                view.CustomDrawGroupRow += new RowObjectCustomDrawEventHandler(View_CustomDrawGroupRow);
                view.CustomUnboundColumnData += new CustomColumnDataEventHandler(view_CustomUnboundColumnData);
                view.KeyDown += new KeyEventHandler(view_KeyDown);
                view.RowStyle += new RowStyleEventHandler(view_RowStyle);
            finally
                view.EndUpdate();
        protected virtual void Detach()
            if (_view == null) return;
            if (column != null)
                column.Dispose();
            if (edit != null)
                _view.GridControl.RepositoryItems.Remove(edit);
                edit.Dispose();
            _view.Click -= new EventHandler(View_Click);
            _view.CustomDrawColumnHeader -= new ColumnHeaderCustomDrawEventHandler(View_CustomDrawColumnHeader);
            _view.CustomDrawGroupRow -= new RowObjectCustomDrawEventHandler(View_CustomDrawGroupRow);
            _view.CustomUnboundColumnData -= new CustomColumnDataEventHandler(view_CustomUnboundColumnData);
            _view.KeyDown -= new KeyEventHandler(view_KeyDown);
            _view.RowStyle -= new RowStyleEventHandler(view_RowStyle);
            _view = null;
        protected int GetCheckBoxWidth()
            DevExpress.XtraEditors.ViewInfo.CheckEditViewInfo info = edit.CreateViewInfo() as DevExpress.XtraEditors.ViewInfo.CheckEditViewInfo;
            int width = 0;
            GraphicsInfo.Default.AddGraphics(null);
            try
                width = info.CalcBestFit(GraphicsInfo.Default.Graphics).Width;
            finally
                GraphicsInfo.Default.ReleaseGraphics();
            return width + CheckboxIndent * 2;
        protected void DrawCheckBox(Graphics g, Rectangle r, bool Checked)
            DevExpress.XtraEditors.ViewInfo.CheckEditViewInfo info;
            DevExpress.XtraEditors.Drawing.CheckEditPainter painter;
            DevExpress.XtraEditors.Drawing.ControlGraphicsInfoArgs args;
            painter = edit.CreatePainter() as DevExpress.XtraEditors.Drawing.CheckEditPainter;
            info.EditValue = Checked;
            info.Bounds = r;
            info.CalcViewInfo(g);
            args = new DevExpress.XtraEditors.Drawing.ControlGraphicsInfoArgs(info, new DevExpress.Utils.Drawing.GraphicsCache(g), r);
            painter.Draw(args);
            args.Cache.Dispose();
        void Invalidate()
            _view.CloseEditor();
            _view.BeginUpdate();
            _view.EndUpdate();
        void SelectRow(int rowHandle, bool select, bool invalidate)
            if (IsRowSelected(rowHandle) == select) return;
            if (select)
                selection.Add(row);
            else
                selection.Remove(row);
            if (invalidate)
                Invalidate();
        void view_CustomUnboundColumnData(object sender, CustomColumnDataEventArgs e)
            if (e.Column == CheckMarkColumn)
                if (e.IsGetData)
                    e.Value = IsRowSelected(View.GetRowHandle(e.ListSourceRowIndex));
                else
                    SelectRow(View.GetRowHandle(e.ListSourceRowIndex), (bool)e.Value);
        void view_KeyDown(object sender, KeyEventArgs e)
            if (View.FocusedColumn != column || e.KeyCode != Keys.Space) return;
            InvertRowSelection(View.FocusedRowHandle);
        void View_Click(object sender, EventArgs e)
            GridHitInfo info;
            Point pt = _view.GridControl.PointToClient(Control.MousePosition);
            info = _view.CalcHitInfo(pt);
            if (info.Column == column)
                if (info.InColumn)
                    if (SelectedCount == _view.DataRowCount)
                        ClearSelection();
                    else
                        SelectAll();
                if (info.InRowCell)
                    InvertRowSelection(info.RowHandle);
            if (info.InRow && _view.IsGroupRow(info.RowHandle) && info.HitTest != GridHitTest.RowGroupButton)
        void View_CustomDrawColumnHeader(object sender, ColumnHeaderCustomDrawEventArgs e)
            if (e.Column == column)
                e.Info.InnerElements.Clear();
                e.Painter.DrawObject(e.Info);
                DrawCheckBox(e.Graphics, e.Bounds, SelectedCount == _view.DataRowCount);
                e.Handled = true;
        void View_CustomDrawGroupRow(object sender, RowObjectCustomDrawEventArgs e)
            DevExpress.XtraGrid.Views.Grid.ViewInfo.GridGroupRowInfo info;
            info = e.Info as DevExpress.XtraGrid.Views.Grid.ViewInfo.GridGroupRowInfo;
            info.GroupText = "         " + info.GroupText.TrimStart();
            e.Info.Paint.FillRectangle(e.Graphics, e.Appearance.GetBackBrush(e.Cache), e.Bounds);
            Rectangle r = info.ButtonBounds;
            r.Offset(r.Width + CheckboxIndent * 2 - 1, 0);
            DrawCheckBox(e.Graphics, r, IsGroupRowSelected(e.RowHandle));
            e.Handled = true;
        void view_RowStyle(object sender, RowStyleEventArgs e)
            //if (IsRowSelected(e.RowHandle))
            //    e.Appearance.BackColor = SystemColors.Highlight;
            //    e.Appearance.ForeColor = SystemColors.HighlightText;
其实GridCheckMarksSelection是devexpress官方提供的帮助类, 可以在google里搜索相应的例子
rocks + 1 很给力 http://www.devexpress.com/Support.
GMT+8, 2025-2-23 18:38
