查看: 3392|回复: 1
.NET 4.5 并行编程经典技巧实例
1122 小时
发表于 2013-11-30 11:58:08 | 显示全部楼层 |阅读模式
.NET 4.5 并行编程经典技巧实例
.NET 4.5 Parallel Extensions Cookbook
80 recipes to create scalable, task-based parallel programs using .NET 4.5
Overview
Create multithreaded applications using .NET Framework 4.5
Get introduced to .NET 4.5 parallel extensions and familiarized with .NET parallel loops
Use new data structures introduced by .NET Framework 4.5 to simplify complex synchronisation problems
Practical recipes on everything you will need to create task-based parallel programs
.NET 4.5 Parallel Extensions Cookbook.pdf (3.12 MB, 下载次数: 148)
vshaka + 1 很给力
GMT+8, 2025-4-2 02:33
