- 8
- 8 小时
- 7
- 2013-12-24
- 10
- 2023-12-16
- 10
- 152
- 8 小时
- 2013-12-24
http://downloads.devexpress.com/Share/DXP/140110/DevExpressComponents-13.2.6.14010.exe
http://downloads.devexpress.com/Share/IDE/140110/DevExpressCodeRush-13.2.6.14010.exe
Fixed issues and enhancements:- WinExplorerView - MoveFirst, MoveLast, MoveLastVisible, MoveNext, MoveNextPage, MovePrev, MovePrevPage methods are not working
- Grid - First click on a editor's button does not trigger the ButtonClick event
- ComboBox doesn't load data if LoadDropDownOnDemand property is set to true in Large Data base mode
- RichEdit freezes on removing columns from table
- Parsing - Viewer crashes if a document contains lines with a negative width
- ViewVariants - The "Operation is not valid due to the current state of the object" error may occur at CustomizeNavigationItemsController.GetVariants
- Visual Studio 2013 hangs when starting a project with DevExpress references
- A theme applied via the smart tag in designer may be applied to a wrong control
- UI.Web - The Search field is not focused after opening the lookup editor's popup
- Number value in a cell stored as text with currency formating is displayed as currency
- ASPxGridView - ASPxMenu has incorrect width inside DataItemTemplate
- Reminder Alert is not working with DevExpress.XtraScheduler.v12.1, Version=12.1.11.0
- ASPxGridView - The grid isn't correctly rendered in IE8 Compatibility mode if the horizontal scrollbar is used
- A top row is not selected with right mouse click when a grid is filtered and the MultiSelect option is on
- Export - XLSX files cannot be viewed on iOS and Android
- The "\r\n" characters are removed from the grid caption during printing
- The ArgumentException is raised when expanding detail records in the GridControl
- An AV occurs when closing an application with a statically linked DLL file that contains one or more DevExpress controls if the native painting style is applied
- MVC views editing is very slow in 13.2
- CheckedComboBoxEdit's popup items are not located when playing back a test
- WPF DXDocking: Panel goes to background when undocked
- ASPxFormLayout- Content is printed with spaces in FireFox 26
- Example Runner does not detect VS2013
- RiaInstantFeedbackDataSource vs LoadOperation
- NavBarControl - New groups are not shown when GroupDescription is in use
- The XPaint.MultiColorDrawString method does not work in version 13.2.6
- LayoutControl - The LayoutControlItem.ControlMinSize property is changed for CheckEdit when re-open a form at design time
