用户名  找回密码
查看: 6182|回复: 2
Basic4Android 3.20 + keygen
发表于 2014-3-5 10:03:04 | 显示全部楼层 |阅读模式
This version includes many important improvements:
Visual designer◦Anchors feature - makes it easier to target multiple screen sizes. See this short video.
◦Copy & paste - work both inside the layout or between different layouts.
◦Undo / redo feature.
◦The views are organized in a tree for easier navigation.
◦AutoScaleAll keyword now works with all variants, not just the "standard" variant.
◦Colors fields can be copied and the colors values can be pasted or directly typed.
◦Designer script find / replace dialog.
◦The grid is saved in the layout file.
◦Landscape / Portrait designer keywords to test the current orientation.
◦UI Cloud threshold reduced to 10 seconds.
#AdditionalRes attribute - Makes it possible to wrap Android library projects (projects with resources). See this example: jfeinstein10 SlidingMenu library
Sync button in the Files tab - Syncs the project files with the Files folder.
Modules added to the Find Sub / Module tool (Ctrl + E).
Tabs order in the IDE is preserved.
Modules files that were not modified will not be saved thus preserving the correct time stamp.
DateTime.SetTimeZone now accepts a Double instead of Int.
Shortcuts: F11 - Restart (rapid debugger), F2 in the designer connects to the device.
JavaObject v1.00 - new RunMethodJO / GetFieldJO methods.
Bug fixes and other minor improvements.
zip password : www.board4allcz.eu
https://mega.co.nz/#!sBYBAQxB!JC24UFl0sPAmlC7a0TJOcxkrp6UiNbyKIdB5CIi6ckI
举报
382 小时
发表于 2014-3-23 20:59:09 | 显示全部楼层
用的IDEA进行开发,这个工具不知道如何
举报
发表于 2014-4-22 15:13:20 | 显示全部楼层
是不是vb4android啊?
举报
GMT+8, 2025-4-6 08:07
