查看: 6313|回复: 1
Xamarin.Android 4.10.01073 & Xamarin.iOS 1.8.365
562 小时
发表于 2014-3-21 10:18:37 | 显示全部楼层 |阅读模式
NEW support for Visual Studio 2013 & Portable Class Libraries
Download include
Xamarin.iOS 7.0.4.209 (OSX) & 1.8.361 , 1.8.365 (WIN)
Xamarin.Mac 1.6.19 (in downlaod archive you can find installer without licence check – pached mmp not included in installer)
Xamarin.Android 4.10.01068 (WIN/OSX) , 4.10.01073 WIN
change log
Code: Select all
http://docs.xamarin.com/releases ... arin.Android_4.10.1
http://docs.xamarin.com/releases/ios/xamarin.ios_7/xamarin.ios_for_vs_1.8/
http://docs.xamarin.com/releases/ios/xamarin.ios_7/xamarin.ios_7.0/#4
Installers
Code: Select all
http://dl.google.com/android/android-sdk_r22-macosx.zip
http://dl.google.com/android/ndk/android-ndk-r8d-darwin-x86.tar.bz2
http://download.xamarin.com/MonoFrameworkMDK/Macx86/MonoFramework-MDK-3.2.4.macos10.xamarin.x86.pkg
http://download.xamarin.com/studio/Mac/XamarinStudio-4.2.1-1.dmg
http://download.xamarin.com/MonoTouch/Mac/monotouch-7.0.4.209.pkg
http://download.xamarin.com/MonoforAndroid/Mac/mono-android-4.10.1-68.pkg
http://download.xamarin.com/XamarinforMac/Mac/xamarin.mac-1.6.19.pkg
http://download.xamarin.com/Installer/MonoForAndroid/jdk-6u39-windows-i586.exe
http://dl.google.com/android/installer_r22-windows.exe
http://dl.google.com/android/ndk/android-ndk-r8d-windows.zip
http://download.xamarin.com/GTKforWindows/Windows/gtk-sharp-2.12.22.msi
http://download.xamarin.com/studio/Windows/XamarinStudio-4.2-2.msi
http://download.xamarin.com/MonoforAndroid/Windows/mono-android-4.10.01073_signed.msi
http://download.xamarin.com/MonoTouchforVisualStudio/Windows/Xamarin.iOS_Setup-1.8.365.0_signed.msi
download Crack
Code: Select all
http://www.myuplbox.com/file/download/957725
WIN INSTRUCTIONS
replace mtouch.exe in C:\Program Files (x86)\MSBuild\Xamarin\iOS
replace mandroid.exe in C:\Program Files (x86)\MSBuild\Xamarin\Android
from command prompt run
Code: Select all
“C:\Program Files (x86)\MSBuild\Xamarin\Android\mandroid.exe” –activate –activation-name=b4a –activation-phone=q –activation-company=b4a –activation-code=q –activation-email=q
“C:\Program Files (x86)\MSBuild\Xamarin\iOS\mtouch.exe” –activate –activation-name=b4a –activation-phone=q –activation-company=b4a –activation-code=q –activation-email=q
run to check lic file creation
Code: Select all
“C:\Program Files (x86)\MSBuild\Xamarin\Android\mandroid.exe” –entitlements > %temp%\000.txt 1> %temp%\001.txt 2> %temp%\002.txt
“C:\Program Files (x86)\MSBuild\Xamarin\Android\mandroid.exe” –check >> %temp%\000.txt 1>> %temp%\001.txt 2>> %temp%\002.txt
“C:\Program Files (x86)\MSBuild\Xamarin\iOS\mtouch.exe” –entitlements >> %temp%\000.txt 1>> %temp%\001.txt 2>> %temp%\002.txt
“C:\Program Files (x86)\MSBuild\Xamarin\iOS\mtouch.exe” –check >> %temp%\000.txt 1>> %temp%\001.txt 2>> %temp%\002.txt
check in temp folder created files for results
OSX INSTRUCTIONS
replace mtouch in /Developer/MonoTouch/usr/bin/
replace mandroid in /Developer/MonoAndroid/usr/bin/
replace mmp in /Library/Frameworks/Xamarin.Mac.framework/Versions/1.4.22/bin/
from terminal run
Code: Select all
/Developer/MonoAndroid/usr/bin/mandroid –activate –activation-name=b4a –activation-phone=q –activation-company=b4a –activation-code=q –activation-email=q
/Developer/MonoTouch/usr/bin/mtouch –activate –activation-name=b4a –activation-phone=q –activation-company=b4a –activation-code=q –activation-email=q
/Library/Frameworks/Xamarin.Mac.framework/Versions/1.4.22/bin/mmp  –activate –activation-name=b4a –activation-phone=q –activation-company=b4a –activation-code=q –activation-email=q
/Developer/MonoAndroid/usr/bin/mandroid –entitlements
/Developer/MonoAndroid/usr/bin/mandroid –check
/Developer/MonoTouch/usr/bin/mtouch –entitlements
/Developer/MonoTouch/usr/bin/mtouch –check
/Library/Frameworks/Xamarin.Mac.framework/Versions/1.4.22/bin/mmp –entitlements
/Library/Frameworks/Xamarin.Mac.framework/Versions/1.4.22/bin/mmp –check
if you have executing problem start command “chmod a+x [file]” for each osx files
参与人数 2赞扬 +2 收起 理由
ZERO + 1 很给力
ssa521 + 1 感谢分享
562 小时
 楼主| 发表于 2014-3-23 18:24:07 | 显示全部楼层
【安装顺序】
1)jdk-6u45-windows-i586.exe
2)gtk-sharp-2.12.22.msi
3)XamarinStudio.msi
4)mono-android.msi
5)Xamarin.iOS_Setup.msi (如果不开发iOS,这个不需要安装)
6)破解相见主题
GMT+8, 2025-4-4 15:45
