查看: 3848|回复: 1
分享一个自己总结的数据加密类
实习版主
发表于 2014-5-12 14:02:10 | 显示全部楼层 |阅读模式
using System;
using System.IO;
using System.Security.Cryptography;
using System.Text;
using System.Web.Security;
namespace OIFrameWork.Common
    public class EncryptString
        private static EncryptString _instance;
        private  static  readonly  object EncryptLock=new object();
        public static EncryptString GetInstance()
            if (_instance != null) return _instance;
            lock (EncryptLock)
                return _instance ?? (_instance = new EncryptString());
        #region "方法主体"
        ///  加密字符,防止敏感信息外泄.
        /// <param name="str">加密字符串</param>
        /// <returns></returns>
        public string StringEncodeBase(string str)
            var strResult = "";
            if (!string.IsNullOrEmpty(str))
                strResult = Convert.ToBase64String(Encoding.Default.GetBytes(str));
            return strResult;
        /// 解密字符,防止敏感信息外泄.
        /// <param name="str">解密字符串</param>
        public string StringDecodeBase(string str)
            var strResult = "";
                strResult = Encoding.Default.GetString(Convert.FromBase64String(str));
            return strResult;
        /// 用到了GenerateSalt和EncodePassword方法,这两个方法用于完成salt值的生成和密码的加salt散列
        /// <param name="password"></param>
        /// <param name="salt"></param>
        public string EncodeString(string password, string salt)
            var src = Encoding.Unicode.GetBytes(password);
            var saltbuf = Convert.FromBase64String(salt);
            var dst = new byte[saltbuf.Length + src.Length];
            byte[] inArray = null;
            Buffer.BlockCopy(saltbuf, 0, dst, 0, saltbuf.Length);
            Buffer.BlockCopy(src, 0, dst, saltbuf.Length, src.Length);
            var algorithm = HashAlgorithm.Create("SHA1");
            if (algorithm != null) inArray = algorithm.ComputeHash(dst);
            return inArray == null ? string.Empty : Convert.ToBase64String(inArray);
        public string GenerateSalt()
            var data = new byte[0x10];
            new RNGCryptoServiceProvider().GetBytes(data);
            return Convert.ToBase64String(data);
        /// MD5加密字符串,返回8\16位和32位两种
        /// <param name="str">需要加密的字符串</param>
        /// <param name="mType">加密返回的长度类型 8,16,32</param>
        /// <returns>返回加密后的字符串</returns>
        public string Md5String(string str, EncryptType  mType)
            var encyString = string.Empty;
            switch (mType)
                case EncryptType.Eight:
                    var hashPasswordForStoringInConfigFile = FormsAuthentication.HashPasswordForStoringInConfigFile(str, "MD5");
                    if (hashPasswordForStoringInConfigFile != null)
                        encyString = hashPasswordForStoringInConfigFile.Substring(8, 8);
                    break;
                case EncryptType.Sixteen:
                    var passwordForStoringInConfigFile = FormsAuthentication.HashPasswordForStoringInConfigFile(str, "MD5");
                    if (passwordForStoringInConfigFile != null)
                        encyString = passwordForStoringInConfigFile.Substring(8, 16);
                    break;
                case EncryptType.ThrityTwo:
                    encyString = FormsAuthentication.HashPasswordForStoringInConfigFile(str, "MD5");
                    break;
            return encyString;
        /// 3des加密函数(ECB加密模式,PaddingMode.PKCS7,无IV)
        /// <param name="encryptValue">加密字符</param>
        /// <param name="key">加密key(24字符)</param>
        /// <returns>加密后Base64字符</returns>
        public string DesEncrypt(string encryptValue, string key)
            var des3 = SymmetricAlgorithm.Create("OpenIdearDes");
            des3.Mode = CipherMode.ECB;
            des3.Key = Encoding.UTF8.GetBytes(StringFunction.GetInstance().SplitStringLen(key, 24, '0'));
            des3.Padding = PaddingMode.PKCS7;
            var ct = des3.CreateEncryptor();
            var byt = Encoding.UTF8.GetBytes(encryptValue);
            var ms = new MemoryStream();
            var cs = new CryptoStream(ms, ct, CryptoStreamMode.Write);
            try
                cs.Write(byt, 0, byt.Length);
                cs.FlushFinalBlock();
                return Convert.ToBase64String(ms.ToArray());
            catch (Exception ex)
                return ex.ToString();
            finally
                cs.Close();
                cs.Dispose();
                ms.Close();
                ms.Dispose();
                des3.Clear();
                ct.Dispose();
        #region "3des解密字符串"
        /// 3des解密函数(ECB加密模式,PaddingMode.PKCS7,无IV)
        /// <param name="decryptString">解密字符</param>
        /// <param name="key">解密key(24字符)</param>
        /// <returns>解密后字符</returns>
        public string DecryptString(string decryptString, string key)
            var ct = des3.CreateDecryptor();
            var byt = Convert.FromBase64String(decryptString);
            try
                return Encoding.UTF8.GetString(ms.ToArray());
            finally
                ms.Close();
                cs.Close();
                ms.Dispose();
                cs.Dispose();
                ct.Dispose();
                des3.Clear();
        #endregion
        #endregion
        public enum EncryptType
            /// 8位密码
            Eight,
            /// 16位加密
            Sixteen,
            /// 32位加密
            ThrityTwo
参与人数 2赞扬 +2 收起 理由
maple + 1 感谢分享
seamone + 1 很给力
GMT+8, 2025-4-2 02:33
