查看: 3973|回复: 1
分享一个自己总结的session处理类
实习版主
发表于 2014-5-12 14:06:11 | 显示全部楼层 |阅读模式
using System;
using System.Web;
namespace OIFrameWork.Common
    public class SessionFunction
        #region "方法体入口"
        private static SessionFunction _instance;
        private static readonly object SessionFunctionLock = new object();
        public static SessionFunction GetInstance()
            if (_instance != null)
                return _instance;
            lock (SessionFunctionLock)
                return _instance ?? ( _instance = new SessionFunction() );
        #endregion
        #region "方法体"
        /// 获取当前Session的ID
        /// <returns></returns>
        public string GetSessionId()
            return HttpContext.Current.Session.SessionID;
        /// 添加Session'
        /// <param name="sessionName">session名称</param>
        /// <param name="sessionValue">session值</param>
        /// <param name="sessionTime">自动过期时间值,单位:分钟</param>
        public void AddSession(String sessionName, String[] sessionValue, String sessionTime)
            HttpContext.Current.Session[sessionName] = sessionValue;
            HttpContext.Current.Session.Timeout = Convert.ToInt32(sessionTime);
        /// 添加session
        /// <param name="sessionName"></param>
        /// <param name="sessionValue"></param>
        /// <param name="sessionTime"></param>
        public void AddSession(String sessionName, object sessionValue, String sessionTime)
        /// 获得Session
        /// <param name="sessionKey"></param>
        public object GetSession(String sessionKey)
            return HttpContext.Current.Session[sessionKey];
        /// 删除Session
        public void DelSession(String sessionName)
            HttpContext.Current.Session[sessionName] = null;
        /// 移除所有的Session
        public void RemoveSession()
            HttpContext.Current.Session.RemoveAll();
        /// 删除指定名称的Session
        public void RemoveSession(String sessionKey)
            HttpContext.Current.Session.Remove(sessionKey);
        #endregion
参与人数 3赞扬 +3 收起 理由
z26483770 + 1
maple + 1 赞一个
seamone + 1 赞一个
43 小时
发表于 2015-1-7 12:57:39 | 显示全部楼层
不错啊,谢了
GMT+8, 2025-4-2 02:34
