用户名  找回密码
查看: 3353|回复: 0
分享一个字符串处理类
实习版主
发表于 2014-5-12 14:06:53 | 显示全部楼层 |阅读模式
using System;
using System.Configuration;
using System.Globalization;
using System.Linq;
using System.Security.Cryptography;
using System.Text;
using System.Text.RegularExpressions;
using System.Web;
namespace OIFrameWork.Common
    public class StringFunction
        #region "方法体入口"
        private static StringFunction _instance;
        public static StringFunction GetInstance()
            return _instance ?? (_instance = new StringFunction());
        #endregion
        #region "方法体"
        /// 返回指定的字符串在文本中出现的次数
        /// <param name="chars">指定要查询的字符串</param>
        /// <param name="strings">需要查询的文本串</param>
        /// <returns>返回出现的次数</returns>
        public int GetStringCount(string chars, string strings)
            var str = strings.Replace(chars, "");
            return ( strings.Length - str.Length ) / chars.Length;
        /// 获取WebConfig中对应名称的键值信息
        /// <param name="appName">WebConfig应用程序名称</param>
        /// <returns>返回对应的键值</returns>
        public string GetConfigAppString(string appName)
            var cacheKey = "AppSetting-" + appName;
            var objModel = DataCache.GetInstance().GetCache(cacheKey);
            if (objModel != null) return objModel.ToString();
            objModel = ConfigurationManager.AppSettings[appName];
            if ( objModel != null )
                DataCache.GetInstance().AddCache(cacheKey, objModel, DateTime.Now.AddMinutes(180), TimeSpan.Zero);
            return objModel != null ? objModel.ToString() : string.Empty;
        /// 将日期字符串格式化,格式化类型为2000-00-00,2000/00/00,20000000
        /// <param name="dt">需要格式划的时间字符串</param>
        /// <param name="dType">需要格式化的类型</param>
        /// <returns>返回格式化后的时间字符串</returns>
        public string GetFormatDateString(DateTime dt, DateTimeType dType)
            if ( dType == DateTimeType.StandType )
                return String.Format("{0}-{1}-{2}", dt.Year, dt.Month, dt.Day);
            if ( dType == DateTimeType.ItalyType )
                return String.Format("{0}/{1}/{2}", dt.Year, dt.Month, dt.Day);
            if ( dType == DateTimeType.ShotType )
                return dt.Year + dt.Month.ToString(CultureInfo.InvariantCulture) + dt.Day;
            return string.Empty;
        /// 返回随机颜色值
        /// <returns>字符串表示的颜色值</returns>
        public string GetRandomColorString()
            const int length = 6;
            var random = new Byte[length / 6];
            var rg = new RNGCryptoServiceProvider();
            rg.GetNonZeroBytes(random);
            var sb = new StringBuilder(length);
            int i;
            for ( i = 0; i < random.Length; i++ )
                sb.Append(String.Format("{0:X2}", random[i]));
            return sb.ToString();
        /// 返回指定长度的随机字符串
        /// <param name="rLength">需要返回的长度</param>
        /// <returns>返回指定长度的随机字符串</returns>
        public string GetRandomString(int rLength)
            var random = new Byte[rLength / 2];
            var rng = new RNGCryptoServiceProvider();
            rng.GetNonZeroBytes(random);
            var sb = new StringBuilder(rLength);
            int i;
        /// 获取ip地址
        /// <returns>返回获取的Ip地址</returns>
        public string GetIpAddress()
            return HttpContext.Current.Request.UserHostAddress;
        /// 隐藏IP地址显示的最后一段地址“172.16.1.*”
        /// <param name="ipString">需要隐藏的IP地址</param>
        /// <returns>返回隐藏后的IP地址段</returns>
        public string HiddenIpAddress(string ipString)
            return ipString.Substring(0, ipString.LastIndexOf(".", StringComparison.Ordinal)) + ".*";
        /// 获取当前的Url地址
        /// <returns>返回地址</returns>
        public string GetUrlAddress()
            return HttpContext.Current.Request.ServerVariables["SCRIPT_NAME"];
        /// 返回文件的扩展名
        /// <param name="fileName">文件名</param>
        /// <returns>返回文件的扩展名</returns>
        public string GetFileExpenseName(string fileName)
            return fileName.Substring(fileName.LastIndexOf(".", StringComparison.Ordinal) + 1);
        /// 获取全局唯一的字符串Guid
        /// <returns></returns>
        public string GetGuidString()
            var guids = Guid.NewGuid().ToString().Split('-');
            return guids.Aggregate(string.Empty, (current, t) => current + t.ToUpper().Trim());
        /// 计算字符串的字符长度,一个汉字字符将被计算为两个字符
        /// <param name="input">需要计算的字符串</param>
        /// <returns>返回字符串的长度</returns>
        public int GetCount(string input)
            return Regex.Replace(input, @"[\一-\龥/g]", "aa").Length;
        /// 从输入字符串中的第一个字符开始,用替换字符串替换指定的正则表达式模式的所有匹配项。
        /// <param name="pattern">模式字符串</param>
        /// <param name="input">输入字符串</param>
        /// <param name="replacement">用于替换的字符串</param>
        /// <returns>返回被替换后的结果</returns>
        public string Replace(string pattern, string input, string replacement)
            var regex = new Regex(pattern);
            return regex.Replace(input, replacement);
        /// 在由正则表达式模式定义的位置拆分输入字符串。
        /// <returns>被拆分后的字符串数组</returns>
        public string[] Split(string pattern, string input)
            return regex.Split(input);
        public string SplitStringLen(string s, int len, char b)
            if (string.IsNullOrEmpty(s))
                return "";
            return s.Length >= len ? s.Substring(0, len) : s.PadRight(len, b);
        #endregion
maple + 1 赞一个
举报
GMT+8, 2025-4-2 21:06
