查看: 10413|回复: 4
【教程】取消RibbonPageGroup文字+PageGroup居右显示
4789 小时
黄马甲
发表于 2014-7-8 11:02:19 | 显示全部楼层 |阅读模式
新增一个类,继承RibbonControl
using System;
using System.Drawing;
using DevExpress.XtraBars.Ribbon;
using DevExpress.XtraBars.Ribbon.ViewInfo;
using DevExpress.Utils;
using System.ComponentModel;
namespace testSpace
    public class Mribbon : RibbonControl
        public Mribbon() : base() { }
        protected override RibbonViewInfo CreateViewInfo() { return new MribbonViewInfo(this); }
        #region 属性
        private HorzAlignment _FormCaptionAlignment = HorzAlignment.Default;
        [CategoryAttribute("MribbonSettings"), Description("窗体标题对齐方式"), DefaultValue(typeof(HorzAlignment), "Default")]
        public HorzAlignment FormCaptionAlignment
            get { return _FormCaptionAlignment; }
            set { _FormCaptionAlignment = value; LayoutChanged(); }
        bool _ShowGroupCaption = true;
        [CategoryAttribute("MribbonSettings"), Description("是否显示Group标题"), DefaultValue(true)]
        public bool ShowGroupCaption
            get { return _ShowGroupCaption; }
            set { if (_ShowGroupCaption != value) _ShowGroupCaption = value; }
        #endregion
    public class MribbonViewInfo : RibbonViewInfo
        public MribbonViewInfo(RibbonControl ribbon) : base(ribbon) { }
        protected override RibbonCaptionViewInfo CreateCaptionInfo()
            return new MribbonCaptionViewInfo(this);
        protected override RibbonPanelViewInfo CreatePanelInfo()
            return new MribbonPanelViewInfo(this);
    #region 设置窗体标题对其模式
    public class MribbonCaptionViewInfo : RibbonCaptionViewInfo
        public MribbonCaptionViewInfo(RibbonViewInfo viewInfo)
            : base(viewInfo)
            get { return (ViewInfo.Ribbon as Mribbon).FormCaptionAlignment; }
        protected override Rectangle CalcTextBounds()
            var centerTextBounds = base.CalcTextBounds();
            if (FormCaptionAlignment == HorzAlignment.Near)
                centerTextBounds.Offset(ContentBounds.X - centerTextBounds.X, 0);
            if (FormCaptionAlignment == HorzAlignment.Far)
                centerTextBounds.Offset(ContentBounds.Right - centerTextBounds.Right, 0);
            return centerTextBounds;
    #endregion
    public class MribbonPageGroupViewInfo : RibbonPageGroupViewInfo
        public MribbonPageGroupViewInfo(RibbonViewInfo viewInfo, RibbonPageGroup group) : base(viewInfo, group) { }
        //设置Group右对齐
        public override void CalcViewInfo(Rectangle bounds)
            if (object.Equals(PageGroup.Tag, "AlignRight"))
                int offset = ViewInfo.Bounds.Right - bounds.Right;
                if (offset > 5)
                    bounds.Offset(offset, 0);
            base.CalcViewInfo(bounds);
        //是否显示群组标题
        protected override DevExpress.Utils.Drawing.GroupObjectInfoArgs SetupDrawArgs()
            DevExpress.Utils.Drawing.GroupObjectInfoArgs args = base.SetupDrawArgs();
            args.ShowCaption = (base.Ribbon as Mribbon).ShowGroupCaption;
            return args;
    public class MribbonPanelViewInfo : RibbonPanelViewInfo
        public MribbonPanelViewInfo(RibbonViewInfo viewInfo) : base(viewInfo) { }
        protected override RibbonPageGroupViewInfo CreateGroupViewInfo(RibbonPageGroup group)
            return new MribbonPageGroupViewInfo(ViewInfo, group);
参与人数 2软币 +1 赞扬 +2 收起 理由
maple + 1 感谢分享
Cactus_CC + 1 + 1 赞一个
头像被屏蔽
禁止发言
18 小时
发表于 2014-10-17 12:17:53 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2026-3-6 11:57
