- 0
- 10 小时
- 6
- 2014-6-4
- 6
- 2014-8-7
- 6
- 158
- 10 小时
- 2014-6-4
5)初始化SDK
在AppDelegate.m文件中的- (BOOL)application:(UIApplication *)application didFinishLaunchingWithOptions:(NSDictionary *)launchOptions里添加如下代码
[FaceppAPI initWithApiKey:API_KEY andApiSecret:API_SECRET andRegion:APIServerRegionCN];
[FaceppAPI setDebugMode:YES];
6)创建一个imageView,从相册选择一张图片进行人脸检测
在.h文件
@interface ViewController : UIViewController<UINavigationControllerDelegate,UIImagePickerControllerDelegate>
UIImagePickerController *imagePicker;
@property (weak, nonatomic) IBOutlet UIImageView *imageView;
- (IBAction)PickFromPhoto:(id)sender;
在.m文件
01
- (IBAction)PickFromPhoto:(id)sender {
02
if ([UIImagePickerController isSourceTypeAvailable:UIImagePickerControllerSourceTypePhotoLibrary]) {
03
imagePicker.delegate = self;
04
imagePicker.sourceType = UIImagePickerControllerSourceTypePhotoLibrary;
05
[self presentModalViewController:imagePicker animated:YES];
06
07
08
-(void)imagePickerController:(UIImagePickerController *)picker didFinishPickingMediaWithInfo:(NSDictionary *)info
09
UIImage *sourceImage = info[UIImagePickerControllerOriginalImage];
[self performSelectorInBackground:@selector(detectWithImage:) withObject: sourceImage];
[picker dismissModalViewControllerAnimated:YES];
7)根据相册选择的图片进行人脸检测
- (void)detectWithImage:(UIImage *)image{
FaceppResult *result = [[FaceppAPI detection]detectWithURL:nil orImageData:UIImageJPEGRepresentation(image, 0.5) mode:FaceppDetectionModeNormal attribute:FaceppDetectionAttributeNone];
8)获取人脸的大小范围
01
if (result.success) {
02
double image_width = [[result content][@"img_width"]doubleValue]*0.01f;
03
double image_height = [[result content][@"img_height"]doubleValue]*0.01f;
04
int face_count = [[result content][@"face"]count];
05
for (int i = 0; i<face_count; i++) {
06
double width = [[result content][@"face"][i][@"position"][@"width"]doubleValue];
07
double height = [[result content][@"face"][i][@"position"][@"height"]doubleValue];
08
//获取到得人脸范围
09
CGRect rect = CGRectMake(([[result content][@"face"][i][@"position"][@"center"][@"x"]doubleValue]-width/2)*image_width, ([[result content][@"face"][i][@"position"][@"center"][@"y"]doubleValue]-height/2)*image_height, width*image_width, height*image_height);
9)管理Person列表
personNames = [NSArray arrayWithObjects:@"One", @"Two", @"Three", nil];
for (int i = 0; i<[personNames count]; i++) {
//根据personName删除对应一组Person
[[FaceppAPI person]deleteWithPersonName:[personNames objectAtIndex:i] orPersonId:nil];
//根据personName创建一个Person
[[FaceppAPI person]createWithPersonName:[personNames objectAtIndex:i] andFaceId:[NSArray arrayWithObject:face_id] andTag:nil andGroupId:nil orGroupName:nil];}
10)管理Faceset列表
01
//创建一个faceset
02
facesetName = @"sample_faceset";
03
[[FaceppAPI faceset]deleteWithFacesetName:facesetName orFacesetId:nil];
04
FaceppResult *createResult = [[FaceppAPI faceset]createWithFacesetName:facesetName andFaceId:faceIds andTag:nil];
05
if ([createResult success]) {
06
self.textView.text = [NSString stringWithFormat:@"成功在faceSet中添加%@个face,faceSetName:%@",[createResult content][@"added_face"],[createResult content][@"faceset_name"]];
07
08
09
在一个faceset内进行search之前,必须先对该faceset进行Train
当Faceset中的信息被修改之后(增加,删除了Face等),为了保证结果与最新数据一致,Faceset应当被重新train. /train/search
[[FaceppAPI train]trainSynchronouslyWithId:nil orName:facesetName andType:FaceppTrainSearch refreshDuration:1.0f timeout:10.0f];
11)在Faceset里搜索最相似的face
01
02
在faceset里搜索最相似的face
03
faceset_id或faceset_name
04
05
FaceppResult *searchResult = [[FaceppAPI recognition]searchWithKeyFaceId:face_id andFacesetId:nil orFacesetName:facesetName];
06
NSMutableArray *similarityArray = [NSMutableArray array];
07
if ([searchResult success]) {
08
for (int i=0; i<3; i++) {
09
NSString *similarity = [searchResult content][@"candidate"][i][@"similarity"];
[similarityArray addObject:similarity];
self.textView.text = [NSString stringWithFormat:@"与faceSet中三张图片的相似度分别为%@",similarityArray];
