- 76
- 96 小时
- 14
- 2013-8-21
- 271
- 2018-7-13
- 271
- 941
- 96 小时
- 2013-8-21
名称: Netsarang-Xmanager-Enterprise-v5-1243-Incl-Keygen-AMPED.7z
大小: 56432723 字节 (53 MB)
SHA1: E2A9531E7BFC13D3929D7FC640672D6BE5969384
名称: XmanagerEnterprise-5.0.1243.exe
大小: 57458240 字节 (54 MB)
SHA1: 582AD78849A01423B98459C4D588555495A4BB69
Update History
Xmanager Enterprise 5 Build 1243, Oct 13, 2017- FIX: [Xmanager] Screen blinks when started in fullscreen
- FIX: [Xshell] Auto-update incorrectly states user is using the latest version
- FIX: [Xshell] Cursor is not reset when terminal is reset
- FIX: [Xshell] Renaming a tab sometimes applies the name to a different tab
- FIX: [Xshell] Reverse video terminal escape sequence ignored
- FIX: [Xshell] When open in a New Window is selected, a new tab name from the -newtab option is applied to an existing tab
- FIX: [Xftp] User is prompted for password when opening new terminal from a connected session
- FIX: [Xftp] Calling Xftp from a session`s context menu always defaults to TCP 22
- FIX: [Xlpd] resources clean up
Xmanager Enterprise 5 Build 1242, Aug 25, 2017- MOD: [Common] Modified and upgraded session file's password encryption
- MOD: [Common] Seperated packages by license type
- FIX: [Xshell/Xftp] Unable to import sessions from Xshell 4 and Xftp 4
Xmanager Enterprise 5 Build 1236, Aug 05, 2017- FIX: [Xmanager] Timer miscalculation causes Xmanager to hang
- FIX: [Common] Unnecessary SSH channel trace messages
- FIX: Patched an exploit related to nssock2.dll
Xmanager Enterprise 5 Build 1232, Jul 18, 2017- ADD: [Xmanager] Xmanager is now able to listen in on TCP Ports below 6000
- ADD: [Xshell] Enhanced tracing capabilities
- ADD: [Common] Enhanced tracing capabilities
- MOD: [Xshell] Enhanced encryption of session information (Anti BothanSpy)
- MOD: [Xshell] Xftp sessions initiated from Xshell open in a new tab, not window
- MOD: [Xlpd] Resources cleanup
- FIX: [Xshell] Only VBS files displayed when selecting script
- FIX: [Xshell] MessageBox popups displayed behind main window
- FIX: [Xshell] localhost forced to use IPv6
- FIX: [Xshell] Wrapped lines not properly logged
- FIX: [Xftp] Local file names not shown properly in the log when uploading
- FIX: [Common] At times unable to import session files from previous versions
Xmanager Enterprise 5 Build 1179, Apr 12, 2017- ADD: [Common] ED25519 encryption algorithm
- MOD: [Xftp] Command line executes to existing window
- MOD: [Common] Changed Dialog Window's default font
- MOD: [Common] OpenSSL upgraded to v1.0.2k
- FIX: [Common] Compression does not function if compression options is set to delayed
- FIX: [Common] Unexpected packet 80
- FIX: [Xshell] "+" character not processed in command line
- FIX: [Xshell] Find is not applied to other tabs
- FIX: [Xshell] Internal SFTP command line history support
- FIX: [Xshell] Multipane Full Screen mode unselectable from Context Menu when in Full Screen mode
- FIX: [Xshell] While in single process mode even if set to open in new window, new session opens in current window
- FIX: [Xlpd] Duplicate messages for non-duplicate queue names
- FIX: [Xlpd] Help cannot be clicked while Xlpd is in the notification area
Xmanager Enterprise 5 Build 1104, Feb 16, 2017- ADD: [Xmanager] RandR extension can now be used in Multiple Window Mode
- MOD: [Xshell] Removed Xactivator program
- FIX: [Xmanager] Certain option files missing during migration
- FIX: [Xshell] Status of selected sessions changes after opening session properties in the tree view
- FIX: [Xftp] Status of selected sessions changes after opening session properties in the tree view
Xmanager Enterprise 5 Build 1042, Dec 28, 2016- ADD: [Xshell] Font quality option
- ADD: [Xshell] Ability to set background image
- ADD: [Xshell] Warning message when wrong or no master password is inputted
- MOD: [common] Copyright renewal for 2017
- FIX: [Xshell] Cannot map numpad keys in certain languages
- FIX: [Xftp] Link Bar incorrect locking/unlocking behavior
Xmanager Enterprise 5 Build 1037, Dec 13, 2016- ADD: [Xmanager] Can set delay time when Xmanager exits after all connections are closed
- ADD: [Xshell] Keyboard Interactive authentication now allows for terminal based authentication
- FIX: [Xshell] Passphrase of a session's properties is disabled at times.
- FIX: [Xshell] Session mistakenly opens in current window when open in new window is selected
- FIX: [Xshell] Unclickable Quick Command bar buttons
- FIX: [Xshell] User key mappings not functioning in certain languages
- FIX: [Xftp] Folder tree view displays incorrectly after closing the program from the minimized state
Xmanager Enterprise 5 Build 1026, Nov 06, 2016- MOD: [Xshell] Keyboard input by user no longer triggers a new message flag in tabs
- FIX: [Xmanager] Unable to input certain keys with the Spanish keyboard
- FIX: [Xshell] Crash when wrong WaitForStrings type is used
- FIX: [Xshell] The default port number is displayed when the dynamic forwarding port is edited
- FIX: [Common] New type of evaluation keys not registering correctly in older versions
Xmanager Enterprise 5 Build 1015, Oct 07, 2016- ADD: [Xshell] Left/Right Alt keys can be mapped as separate Meta keys
- ADD: [Xftp] Automatic remote directory refresh
- MOD: Temporary product keys can now be set to a daily limit
- FIX: [Xftp] Ambiguous expression concerning changing file sync times in transfer options
- FIX: [Xftp] Folder sync fails at times when several sub folders exist
- FIX: [Xmanager] Copy selection process causes Xmanager to crash at times
- FIX: [Xmanager] Name column can be disabled in Xbrowser
- FIX: [Xmanager] [Xconfig] Help button not functioning in profile registration information
- FIX: [Xshell] Alt(Meta) + PgUp, PgDn keys not functioning
- FIX: [Xshell] Focus directed away from script prompt dialog window
- FIX: [Xshell] Incorrect session information when clicking X button of session tabs
- FIX: [Xshell] Logging incorrectly stops when a session disconnect is cancelled
- FIX: [Xshell] Opening an Xshell sessopm from cmd with password embedded URL prompts for a password
Xmanager Enterprise 5 Build 1001, Sep 07, 2016- FIX: [Xbrowser, Xshell] Issues using Xshell in Windows 10 RS1
- FIX: [Xbrowser, Xshell] Unable to control Xshell after pressing Alt+space keys
- FIX: [Xshell] Pointless timeout message in VBS
- FIX: [Xshell] Simple mode turns off regardless of the view setting
- FIX: [Xshell] Cannot save font size when editing multiple sessions
Xmanager Enterprise 5 Build 0987, Aug 08, 2016- ADD: [Xshell] Font size direct input function
- MOD: [Xshell] SSH banner message now prints out directly after user ID is entered
- FIX: [Xmanager] Session sharing not working in Xbrowser
- FIX: [Xshell] Exiting the session while running a script crashes Xshell
- FIX: [Xshell] Issue with JS Script WaitForString function
- FIX: [Xshell] Unable to authenticate passwords with Unicode characters
- FIX: [Xftp] Unable to view transfer information area when high rate scaling is applied
- FIX: [Xftp] Xftp crashes if a folder of the same name exists when downloading a folder from the folder tree
Xmanager Enterprise 5 Build 0973, Jul 05, 2016- ADD: [Xshell] Ability to display session name in pin bar of Full Screen Mode
- MOD: [Xmanager] Explicit access permission no longer required when initializing Xstart sessions
- FIX: [Xshell] Confirm password field ignored in rare circumstances
- FIX: [Xshell] Frame issue when switching to Multipane Full Screen Mode
- FIX: [Xshell] Window able to be dragged in Multipane Full Screen Mode
- FIX: [Xshell] Irrelevant search results highlighted
Xmanager Enterprise 5 Build 0965, Jun 03, 2016- ADD: [Xshell] Script function for importing current session name
- MOD: [Xftp] Hidden files now display a dimmed icon
- MOD: [Common] Changes to error message shown when installation files unable to be located
- FIX: [Xshell] Exit prompt displayed even if mouse click was not on the X (close) button
- FIX: [Xshell] Focus remains in Address Bar after connecting via Address Bar
- FIX: [Xshell] Special characters rejected during password authentication
- FIX: [Xshell] Unable to highlight words preceded by a Tab character
- FIX: [Xshell] Unable to paste in prompt mode during an SSH connection
- FIX: [Xshell] Unable to use Quick Commands during terminal-based authentication
- FIX: [Common] Unnecessary Restart Needed prompt during live update
Xmanager Enterprise 5 Build 0959, Apr 22, 2016- FIX: [Xmanager] After exiting Xmanager, an icon remains in the system tray
- FIX: [Xshell] Unable to parse the password of a URI in local shell
- FIX: [Xshell] Crash related to the keep alive message
- FIX: [Xshell] Crash related to some IMEs
- FIX: [Xshell] Crash when exiting Xshell
- FIX: [Xshell] Crash when opening properties of multiple sessions from tree view
- FIX: [Xshell] Reconnect button is disabled after several failed reconnection attempts
- FIX: [Xshell] Unable to copy brace character ({) as RTF
- FIX: [Xshell] Unable to use %d, %t env of script log files
- FIX: [Xftp] Unable to change permission of subdirectories
- FIX: [Xftp] Tree view status not saved when called from Xshell
- FIX: [Common] Crash in Import window
Xmanager Enterprise 5 Build 0946, Apr 01, 2016- ADD: [Xshell] Close all tabs feature
- ADD: [Xshell] Scroll pause feature
- MOD: [Xshell/Xftp] Removed license notification when closing Free Versions
- MOD: [Common] Restart time changed after changing program language
- FIX: [Common] Import from CSV file errors
- FIX: [Xmanager] Xmanager crashes when opening session properties
- FIX: [Xshell] Hovering over Quick Commands containing long values causes Xshell to freeze
- FIX: [Xshell] Strings not copied when using Copy as RTF
- FIX: [Xftp] Transfer window unintentionally disappears at times
- FIX: [Xftp] Unable to copy to Desktop using Drag&Drop ([size=1em]more...)
Xmanager Enterprise 5 Build 0928, Mar 11, 2016- FIX: [Xshell] Multibyte characters are not displayed properly in the previous build 0922
Xmanager Enterprise 5 Build 0922, Mar 09, 2016- ADD: [Xshell] Expanded logging format
- ADD: [Xshell] Can now open the log file and folder directly from the terminal's context menu
- ADD: [Xshell] Can now open the log/script folders directly from Xshell's menus
- ADD: [Xshell] Shortcut keys for several session properties, e.g., enabling meta key, switching to Unicode, scroll to bottom upon terminal input/output
- ADD: [Common] Added Extended ValIDAtion (EV) code signing to package
- MOD: [Xmanager] Access control is now enabled by default
- MOD: [Xshell] Default session version upgraded to 5.2
- FIX: [Xmanager] Creating a session when user folder does not have access rights causes Xstart to crash
- FIX: [Xshell] Context menu of hostless sessions show "Open in New Window" and "Open with Xftp" as available options
- FIX: [Xshell] Keep-alive packet breaks prompt in FTP connections
- FIX: [Xshell] List box of "Session to open at startup" not functioning properly
- FIX: [Xshell] Master Password not applied to Expect/Send session rules
- FIX: [Xshell] Not all results highlighted when using Find
- FIX: [Xshell] Some UNICODE characters not displaying properly, especially emojis
- FIX: [Xshell] Terminal ceases function when opening context menu of Tunneling Pane
- FIX: [Xshell] When restoring color scheme to default, all color schemes change to "New Black"
- FIX: [Xshell] Zmodem dialog box re-opens after selecting cancel
- FIX: [Xftp] Transmission ceases when opening the context menu of the transfer queue
- FIX: [Xftp] Unable to access special local paths
- FIX: [Xshell, Xftp, Xlpd] Visit Website link of Help menu not functioning properly
- FIX: [Common] Language selected during installation not applied to the program
Xmanager Enterprise 5 Build 0878, Feb 04, 2016- ADD: [Xbrowser/Xftp] Start Xagent manually from menu
- MOD: [Xshell] User files now stored in %APPDATA% when Documents folder does not exist
- FIX: [Xmanager] In Xstart the key passphrase of Public Key Authentication is not saved
- FIX: [Xmanager] Copy and Paste on Changing Focus option does not function when using Open in New Tab
- FIX: [Xshell] %d is not parsed correctly in the logging path of a session file.
- FIX: [Xshell] Adjusted focused and non-focused tab colors to be more aesthetic
- FIX: [Xshell] Crash when deleting multiple sessions from the tree view of the Sessions Dialog Box
- FIX: [Xshell] Crash when using the ls command within certain directories while utilizing ftp within Xshell
- FIX: [Xshell] German translation errors
- FIX: [Xshell] Output is scrolled when no scrolling should occur
- FIX: [Xshell] Performance issues when pasting to selected area
- FIX: [Xshell] Resource cleanup
- FIX: [Xshell] Resource error in exporting User Keys
- FIX: [Xshell] SSH security settings not changed when modifying multiple sessions
- FIX: [Xshell] lcd command does not function properly at times
- FIX: [Xftp] CLS user information is not displayed correctly
- FIX: [Xftp] Crash when opening Windows Home Group folders from within the local tab
- FIX: [Xftp] Error when Documents folder does not exist
- FIX: [Xftp] Session properties resource cleanup
- FIX: [Xftp] Unable to change the name of a new file created in the user’s home folder within the local tab
Xmanager Enterprise 5 Build 0837, Jan 07, 2016- ADD: [Xftp] Ability to designate your own sftp-server
- ADD: [Xftp] Added a UTF-8 toggle button on the Standard Buttons toolbar
- ADD: [Common] Added hmac-sha2-512,hmac-sha2-512-etm@openssh.com MAC Algorithms
- ADD: [Common] Support for Elliptic curve Diffie-Hellman Key Exchange (ECDHE)
- MOD: [Common] About dialog box now includes more license information
- MOD: [Common] Description and email fields show by default when reporting a crash
- FIX: [Xmanager] Single window mode/multiple window mode mistakenly displays RANDR error message
- FIX: [Xshell] After disabling the Scroll bar, new tabs display the Scroll bar
- FIX: [Xshell] Crash when using certain IMEs
- FIX: [Xshell] Mouse cursor error in the address bar
- FIX: [Xshell] Non ASCII character path names are not transferred properly when inititating a new file transfer
- FIX: [Xshell] Parts of the UI are not visible when status bar is disabled
- FIX: [Xshell] Performance issues when copying large amounts of data
- FIX: [Xshell] Quick Command buttons and Compose Bar not displaying properly on high DPI monitors
- FIX: [Xshell] Sessions created from the toolbar do not inherit the default sessions properties
- FIX: [Xshell] Tab name not visible when tab color is set to white
- FIX: [Xshell] Touch screen scrolling of the terminal area not functioning properly
- FIX: [Xshell] Unable to initialize an SSH session in certain OS languages
- FIX: [Xshell] Xshell's viewer window title bar does not refresh after a session is closed
- FIX: [Xshell] Resource clean up
- FIX: [Xftp] Remote directories are unintentionally copied to C: when directory syncing
- FIX: [Xftp] Unused registry information remains after product uninstallation
- FIX: [Xlpd] Disabled queue tabs are automatically reverted to Enabled
- FIX: [Xlpd] Unable to save the Append FF(Form Feed) option
Xmanager Enterprise 5 Build 0815, Dec 08, 2015- FIX: [Xshell] Fail to duplicate session
Xmanager Enterprise 5 Build 0811, Dec 07, 2015- ADD: [Xbrowser] Ability to filter through session file list via search box
- ADD: [Xshell] Copy as RTF added to Smart Button menu and Edit menu
- ADD: [Xshell] Option to enable/disable automatic saving in layout management
- ADD: [Xshell] Script API, MessageBox
- ADD: [Xshell] Script API, Prompt
- ADD: [Xshell] Support for public key authentication when connecting via command line in CMD
- ADD: [Xshell] Tab notification for output generated when not scrolled to bottom
- ADD: [Xshell] You can run scripts simultaneously on multiple sessions
- MOD: [Xshell] Improvements to the UX of the quick command set options
- MOD: [Common] Default SSH user key generation algorithm changed from DSA to RSA
- FIX: [Xshell] Deleted quick command sets are re-created automatically
- FIX: [Xshell] Incorrect triple clicking behavior when selecting autowrapped lines
- FIX: [Xshell] Selecting the Serial Protocol in default session properties falsely requires integer input
- FIX: [Xshell] Unable to copy Unicode when copying as RTF
- FIX: [Xshell] Unable to execute Xshell from Windows `Run` dialog box
- FIX: [Common] DSA key length can be selected over 1024 bits
- FIX: [Common] User key length limited to 3072 bits
Xmanager Enterprise 5 Build 0787, Nov 09, 2015- ADD: [Xshell] Flash Taskbar bell option
- ADD: [Xshell] Support for Xmodem, Ymodem
- ADD: [Xshell] Status bar now displays session description
- ADD: [Xshell] Compose bar now contains visual icons to indicate where strings are being sent
- ADD: [Xshell] Xshell now allows for copying rich text format
- MOD: [Xshell] Changing the Host Key now produces a more straightforward warning
- FIX: [Common] Problems in the UI when magnifying the window to 200%
- FIX: [Common] When using the Classic Theme in Windows, the toolbar is is not displayed properly
- FIX: [Xmanager] When editing Xshell sessions from within Xbrowser, master password dialog box now appears first
- FIX: [Xmanager] When running an Xstart session using shortcuts, unable to connect to Xagent
- FIX: [Xshell] After enabling the "Push erased screen into Scroll Buffer" option, the reset command erases the scroll buffer
- FIX: [Xshell] Unable to use Agent forwarding with IPv6
- FIX: [Xshell] When intiating an Xftp session from Xshell, the current path is not communicated properly
- FIX: [Xshell] Selected area moves when using tmux, etc.
- FIX: [Xshell] Timeout applied to waitForString
- FIX: [Xshell] Regardless of the authentication option, Single Process mode only allows for dialog based authentication
- FIX: [Xshell] After a successful ftp connection from the Local Shell, commands such as ls, get, etc. do not function
- FIX: [Xshell] Error message does not appear when failing to save a session
- FIX: [Xshell] Able to create a session without inputting the required session information
- FIX: [Xshell] Connection fails when there is a string output in the startup script
- FIX: [Xshell] When tunneling is set to use loopback (127.0.0.1), Xshell listens for all devices (0.0.0.0)
- FIX: [Xftp] Automatic reconnection fails
- FIX: [Xftp] Crash after a transfer completes
- FIX: [Xftp] Session tab characters hidden behind the tab navigation arrows are visible
- FIX: [Xlpd] Resources clean up
Xmanager Enterprise 5 Build 0769, Oct 08, 2015- ADD: [Xshell] Ability to full screen only the selected tab from within a multi-tabbed environment
- ADD: [Xshell] aes256-gcm, aes128-gcm ciphers added
- ADD: [Xshell] Avoid accidental exit
- ADD: [Xshell] Bell Options(for more usages just type set command in the Local shell)
- ADD: [Xshell] File transfer button can open SFTP session
- ADD: [Xshell] Nagle's algorithm option for high latency rate
- ADD: [Common] Change the default folder of user data (Use Xtransport command with -move parameter)
- MOD: [Common] Improved save path for log and script files
- MOD: [Common] Resources clean up.
- FIX: [Xmanager] After navigating away from a drop down menu in the menu bar, the menu title still shows as selected
- FIX: [Xmanager] When Xagent is activated, the user key input line is empty
- FIX: [Xshell] Changes to the log file not saved properly when editing multi-session files
- FIX: [Xshell] Create window command not forwarded to the terminal
- FIX: [Xshell] Delay when pasting with SOCKS tunneling
- FIX: [Xshell] diffie-hellman-group-exchange Kex not supported in OpenSSH 6.9 and higher
- FIX: [Xshell] Editing the session files of previous versions changes the password
- FIX: [Xshell] Empty space at the end of the line is removed when copying a column to the clipboard
- FIX: [Xshell] Input from the num keypad not recognized in local shell
- FIX: [Xshell] Multiple lines do not reflect the newline character when saving the log
- FIX: [Xshell] Some characters are truncated in certain fonts
- FIX: [Xshell] Unable to add quick commands in the German window
- FIX: [Xshell] User asked to input master password multiple times when running concurrent sessions
- FIX: [Xshell] While in simple mode, the session tab disappears when separating it into its own window
Xmanager Enterprise 5 Build 0738, Sep 07, 2015- ADD: [Xshell] Added the option to include new line character when selecting the entire last line
- ADD: [Xshell] Script to change tab names
- ADD: [Xftp] Suppress disconnection confirmation dialog box when exiting from Xftp
- ADD: [Common] Arcfour128, Arcfour256 Cipher Algorithm added
- ADD: [Common] Supports for encrypt-then-mac (EtM) MAC modes
- MOD: [Xmanager] XDMCP sessions now open in windowed mode by default
- MOD: [Xshell] Screen lock is disabled when the program restarts
- FIX: [Xmanager] Program stops responding when right clicking the title bar in full screen mode
- FIX: [Xshell] Prevent auto line wrap for logging
- FIX: [Xshell] Abnormal termination when closing a tab in single process mode
- FIX: [Xshell] Conflicts when running concurrent sessions
- FIX: [Xshell] Crash issue when migrating from older version
- FIX: [Xshell] Ctrl+Alt and Alt Gr option diable/enable issue
- FIX: [Xshell] Custom key map overwrite issue
- FIX: [Xshell] Font list doesn't appear when opening Xshell while the option window is open
- FIX: [Xshell] Full screen view controls not working properly
- FIX: [Xshell] Issue with pasting texts to duplicated channels
- FIX: [Xshell] Local only option does not work for Dynamic (SOCKS4/5) tunneling
- FIX: [Xshell] Old parameter used for user defined text editor does not work
- FIX: [Xshell] Problem using en command on Cisco equipment
- FIX: [Xshell] Uploading a Korean titled file when Xftp is running in English, the file name breaks
- FIX: [Xshell] When accessing the menu, the access key mark appears
- FIX: [Xshell] When in global input mode, direct input to terminal generates random characters
- FIX: [Xshell] When many sessions are open, the session dialog box takes a long time to appear
- FIX: [Xshell] Running a concurrent sessions outside of Xshell does not work properly
- FIX: [Xftp] After entering a folder created from the desktop view, you cannot navigate to the top
- FIX: [Xftp] Tab stops responding when creating a new file in a remote FTP connection
- FIX: [Xftp] Tree view does not work properly under remote folders
- FIX: [Xshell/Xftp] Permission issue for session folder
Xmanager Enterprise 5 Build 0730, Aug 26, 2015- FIX: Cannot connect to Xagent program
Xmanager Enterprise 5 Build 0716, Aug 20, 2015- ADD: [Xshell] https added as URL delimiter
- ADD: [Xshell] Interrupt with Ctrl-C in local shell
- ADD: [Common] Security module core updated to the latest OpenSSL 1.0.1p
- MOD: [Xshell] How terminal color is inverted when making selection with mouse drag
- FIX: [Xmanager] The concurrent session's address bar is not displaying
- FIX: [Xshell] After a tunneling rule has been removed, the rule remains on the server
- FIX: [Xshell] Cannot create connection to SSH servers that use banner
- FIX: [Xshell] Cannot input ASCII code using ALT and keypad combination
- FIX: [Xshell] Cannot use Enter and Space keys in user key map
- FIX: [Xshell] Chinese resource translation error
- FIX: [Xshell] Custom user keymap not working properly
- FIX: [Xshell] Delay when opening the new session dialog box when large number of sessions exist
- FIX: [Xshell] If session file versions differ, password encryption is not handled properly
- FIX: [Xshell] Log does not start for duplicated sessions
- FIX: [Xshell] Single Enter key registers as two new lines in local shell
- FIX: [Xshell] Spanish translation for the New menu is in French
- FIX: [Xshell] Synchronous flag does not work in scripts
- FIX: [Xshell] URI strings is not highlighted correctly
- FIX: [Xshell] Wrong keyboard shortcut key used for User Key Manager
- FIX: [Xlpd] Cancelling a search causes the tab to disappear
- FIX: [Xlpd] Queues which have been renamed cannot be deleted from the context menu
- FIX: [Common] Local only option does not work for SSH tunneling
Xmanager Enterprise 5 Build 0706, Jul 28, 2015- ADD: Crash trace information
Xmanager Enterprise 5 Build 0687, Jul 08, 2015- ADD: [xshell] Delete scroll buffer after disconnection from a session
- ADD: [xshell] Reset scroll buffer and screen without resetting the terminal
- ADD: [xshell] Save multiple host keys at once
- ADD: [xshell] Triple click line select includes new line
- ADD: [Xftp] Added a Forward/Back Folder button to tab window
- MOD: [Xftp] View change icon moved to the Standard toolbar
- FIX: [Xmanager] Delay in Xterm menu appearance
- FIX: [xshell] Channel cloning option is enabled during connection
- FIX: [xshell] Character delimiter does not work when using selection with the Shift combination
- FIX: [xshell] Don't include this in the update history
- FIX: [xshell] In the Sessions dialog box, "Open in New Window" and "Open in Xftp" does not work
- FIX: [xshell] New line character inserted twice
- FIX: [xshell] New remote connection opens in the new tab
- FIX: [xshell] Only one session is opened in a new tab with the Open command
- FIX: [xshell] Running a script increases CPU usage
- FIX: [xshell] Shortcut keys not working when a tab is moved using the mouse
- FIX: [xshell] Slow terminal refresh rate when using VIM in multiple tab group mode
- FIX: [xshell] Tab name changes not functioning correctly
- FIX: [xshell] URL within parenthesis not recognized as hyperlinks
- FIX: [xshell] Xbrowser address bar does not reflect the contents of selected session
- FIX: [Xftp] In the Sessions dialog box, "Open in New Window" and "Open in Xshell" does not work
- FIX: [Xftp] Remote folder name in Korean displays incorrectly in the session dialog box
Xmanager Enterprise 5 Build 0662, Jun 19, 2015- ADD: [Xshell] Send character delay
- ADD: [Xshell] Run script files with Quick Command buttons
- ADD: [Xshell] Multiple selection while in the Tree view on the Sessions dialog box
- ADD: [Xshell] Single process mode
- MOD: [Xshell] Improved master password encryption strength indicator
- FIX: [Xmanager] Cannot recover crashed Xmanager process
- FIX: [Xshell] +(plus) button is not hidden when new tab exceeds the window width
- FIX: [Xshell] Cannot logout when using X11
- FIX: [Xshell] Xftp authentication dialog box opens even though Xshell is already logged in to the session
- FIX: [Xshell] Problem with log folder path when using StartFolder
- FIX: [Xshell] When using CMD on local shell, New Line is displayed twice
- FIX: [Xshell] Long single line logged a part of it.
- FIX: [Xshell] Fixedsys font is used for the History list
- FIX: [Xshell] When using Shift+INS in the Address bar and the Compose bar, it goes to terminal directly
- FIX: [Xshell] Border is not displayed correctly when dettaching in the maximized mode
- FIX: [Xftp] Cannot delete folders after transfer is completed
- FIX: [Xftp] Traverse up icon is disabled when session is disconnected
Xmanager Enterprise 5 Build 0648, Jun 04, 2015- FIX: [Xshell] Does not recognize hyper text link when the URI ends with `s`.
- FIX: [Xshell] Can't establish dynamic tunneling.
Xmanager Enterprise 5 Build 0640, Jun 01, 2015- ADD: [Xbrowser] Tab arange, host key & user key button in the toolbar
- ADD: [Xshell] %HOSTNAME variable in Quick Command button.
- ADD: [Xshell] Tab arange, new tab group button in the toolbar
- ADD: [Xshell] User can define KeX algorithms
- ADD: [Xshell] User confirmation when using agent forwarding
- MOD: [Xshell] Imporved master password reset procedure
- MOD: [Xshell] Master password length increased to 50 characters
- MOD: [Xshell] Properties with dropdown in the toolbar
- MOD: [Xshell] Use % for variable
- MOD: [Xshell] Use RSA host key fingerprint first
- MOD: [Xftp] Show transfer time
- MOD: [Xftp] Use full path for local folder path
- MOD: [common] 'Use the default Windows title bar and frame' as default of new installation.
- FIX: [Xshell] Beep sounds when coming back from locked mode
- FIX: [Xshell] Cannot open sessions in Korean when UTF-8 encoding is selected
- FIX: [Xshell] Cannot save passphrase when editing multiple sessions at once
- FIX: [Xshell] Cannot use %USERPROFILE% system variable for path
- FIX: [Xshell] Cannot use Meta key combination in the Address bar
- FIX: [Xshell] Cannot use port forwarding for different network devices
- FIX: [Xshell] Prompt is displayed again when making connection from local shell
- FIX: [Xshell] does not show user defined shortcuts in the menu
- FIX: [Xshell] Error when editing multiple sessions simultaneously
- FIX: [Xshell] Hyperlinks in parenthesis does not work
- FIX: [Xshell] Last pinned state is not rememebered when going in to the full screen mode
- FIX: [Xshell] Master password input dialog box opens multiple times when opening multiple sessions simultaneously
- FIX: [Xshell] New connections is made in the currently active local shell
- FIX: [Xshell] Open in New Window does not work in the Sessions dialog box
- FIX: [Xshell] Tab location error when using multiple monitors
- FIX: [Xftp] Drag and drop registration reboot required message error
- FIX: [Xftp] Permission display error of a new directory.
- FIX: [Xftp] Tooltip does not work
- FIX: [Xlpd] Program crashes when creating multiple queues simultaneously
- FIX: [common] Wrong error message disaplayed when update processed is broken during file download
- FIX: [common] Copyright error fixed
Xmanager Enterprise 5 Build 0576, Apr 15, 2015- ADD: [Xshell] Text based authentication mode
- ADD: [Xshell] User defined ftp port when using new file transfer
- FIX: [Xmanager] Opening Xmanager as a new tab displays the Splash image
- FIX: [Xmanager] XDMCP window or tab loses focus
- FIX: [Xshell] Cannot resize the Tunneling bar
- FIX: [Xshell] Cannot use ALT-backspace key
- FIX: [Xshell] Copy and Paste Selection menu is disabled in the context menu
- FIX: [Xshell] Hyperlink feature produces error dialog box over the European characters
- FIX: [Xshell] Master password does not work sometimes
- FIX: [Xshell] Problem displaying characters when using UTF-8 encoding on local shell
- FIX: [Xshell] Problem editing multiple sessions at once
- FIX: [Xshell] SHIFT-INS in the Address bar and the Compose bar, activates Paste in the terminal
- FIX: [Xshell] Solaris SSH agent-forwarding not working
- FIX: [Xshell] Tab color is not saved when editing multiple sessions
- FIX: [Xshell] When connecting to multiple servers via TELNET, local shell does not accept key input if connection fails
- FIX: [Xftp] Misspel in the Options window
- FIX: [Xftp] Xftp does not remember the last folder pane size
- FIX: [Xlpd] Problem editing the Queue properties
Xmanager Enterprise 5 Build 0547, Mar 21, 2015- FIX: [Xshell] Alt+Mouse selection issue(the same as build 0546)
- FIX: Package error of Build 0546
Xmanager Enterprise 5 Build 0546, Mar 20, 2015- FIX: [Xshell] Alt+Mouse selection issue
Xmanager Enterprise 5 Build 0544, Mar 17, 2015- ADD: [Xftp] Create a file menu
- ADD: [Xftp] Transfer mode shortcut key
- ADD: [Xlpd] Use the system default printer
- ADD: [Xshell] Add timestamp to log
- ADD: [Xshell] Copy new line characters
- ADD: [Xshell] diffie-hellman-group-exchange-sha256 algorithm added
- ADD: [Xshell] Drag and drop file on terminal to show full path
- ADD: [Xshell] local shell command allows connecting to multiple hosts at once
- ADD: [Xshell] Reset master password
- ADD: [Xshell] Set local shell default directory
- ADD: [Xshell] Use paste while using the global input feature
- ADD: [Xmanager, Xftp, Xlpd] Use the Windows default frame option
- MOD: [Common] Use unified field for the product key input
- FIX: [Xlpd] Tabbed window size problem
- FIX: [Xmanager] Japanese keymap error
- FIX: [Xshell] Copied text is pasted only at the last duplicated session
- FIX: [Xshell] Alt-backspace sounds bell
- FIX: [Xshell] Authentication continues after canceling Xagent registration
- FIX: [Xshell] Closing a tab using serial connection goes to blue screen
- FIX: [Xshell] Exclude 'more' from logging
- FIX: [Xshell] Forwarding rule dialog box resizable
- FIX: [Xshell] Forwarding rules displays incorrect information on duplicated sessions
- FIX: [Xshell] Master password authentication dialog box opens multiple times
- FIX: [Xshell] New window duplicates the current session
- FIX: [Xshell] Paste selected text with mouse middle click
- FIX: [Xshell] Tab status icon shows alert icon when window size changes
- FIX: [Xshell] Unused regstry key
- FIX: [Xshell] Wrong compose bar size
- FIX: [Common] Show active tab when window loses focus
- FIX: [Common] UNICODE error while installing
- FIX: [Common] Restart needed message while checking for new updates
- FIX: [Common] Copyright year
Xmanager Enterprise 5 Build 0528, Feb 25, 2015- FIX: [Xmanager] Old style UI of Xstart
- FIX: [Common] "Setup Launcher Unicode has stopped working" error message
Xmanager Enterprise 5 Build 0517, Feb 16, 2015- ADD: [Xshell] support named pipe.
- ADD: [Xshell] Session filtering in the Session dialog.
- MOD: [Xshell] does not save some changed properties of a session when the session is opened.
- FIX: [Xmanager] Co-operational issue between Xbrowser and Xshell
- FIX: [Xshell] Cancelling Zmodem transfer leaves some characters on terminal
- FIX: [Xshell] conflict of mouse activity when using application mode.
- FIX: [Xshell] Crash when closing tab group.
- FIX: [Xshell] Ctrl+Backspace key does not delete character.
- FIX: [Xshell] display error of the full screen mode when using multiple tab groups.
- FIX: [Xshell] Focus problem when arranged tabs are closed.
- FIX: [Xshell] Messy title of long terminal title in title bar
- FIX: [Xshell] Messy window of the screen lock when using the default frame
- FIX: [Xshell] Minor bug fix.
- FIX: [Xshell] Omit fonts enlargement-
- FIX: [Xshell] Resources clean up
- FIX: [Xshell] Title bar displays ??? when selecting a folder or file with Cyrillic characters
- FIX: [Xshell] Title bar in the full screen mode moves down automatically.
- FIX: [Xshell] Transparent feature does not work
- FIX: [Xshell] Wrong format of network session folders
Xmanager Enterprise 5 Build 0488, Jan 14, 2015- ADD: [Xshell] an option of conversion tab character into soft tab
- ADD: [Xshell] Default log folder setting
- ADD: [Xshell] Evaluation expired message dialog.
- ADD: [Xshell] Import/export sessions as a text file
- ADD: [Xshell] Tab scrolling using mouse wheel
- ADD: [Xshell] Windows default frame is added.
- MOD: [Xshell] Tab size limitation
- MOD: [Xshell] The same IME status in terminals of the same window.
- FIX: [Xmanager] Resource cleanup, minor bug fixes
- FIX: [Xmanager] Terminal fous issue when maximizing or minimizing window
- FIX: [Xshell] Crash when binary files are printed.
- FIX: [Xshell] Crash when Page Setup opens
- FIX: [Xshell] Focus issue
- FIX: [Xshell] Full screen at maximizing window status cannot cover task bar.
- FIX: [Xshell] Improved tab drop location
- FIX: [Xshell] Long password cannot be treated.
- FIX: [Xshell] Nonavailable folder names for Session folder path are allowed.
- FIX: [Xshell] Password characters are shown in a series of keyboard interactive authentication.
- FIX: [Xshell] Resource cleanup, minor bug fixes
- FIX: [Xshell] Tab detach and reattach crash issue
- FIX: [Xshell] The neighboring tabs of the same color are not distinguished.
- FIX: [Xshell] Tunneling pane turns unvisible after tab attach-detachment.
- FIX: [Xshell] XshellCore is registered in firewall rules of Windows.
- FIX: [Xftp] Resource cleanup, minor bug fixes
- FIX: [Xlpd] Wrong Xlpd viewer logo
- FIX: [Common] Live update window opens in the background
- FIX: [Common] Silent installation error.
Xmanager Enterprise 5 Build 0464, Dec 15, 2014- FIX: [Xmanager] Properties Windows do not show again in Cadence Virtuoso.
Xmanager Enterprise 5 Build 0459, Dec 11, 2014- ADD: [Xmanager] shows server profile at status bar
- ADD: [Xshell] Close tab shortcut key
- ADD: [Xshell] Highlight searched words
- ADD: [Xshell] Notification message when switching between remote and local shells
- ADD: [Xshell] Option for tab name after session disconnects
- ADD: [Xshell] reconnect, pwd, disconnect local shell commands
- ADD: [Xshell] Use Line character font option added
- MOD: [Xshell] Check for master password when program starts
- MOD: [Xshell] Make better use of 'ls' and 'dir' in local shell
- MOD: [Xshell] Tab name change upon disconnection
- FIX: [Xmanager] Live update window opens in the background
- FIX: [Xmanager] Problem with import
- FIX: [Xmanager] Support RandR in multiple window mode
- FIX: [Xshell] Close button going grey when returning from the full screen mode
- FIX: [Xshell] Display 2 byte characters on tab
- FIX: [Xshell] Icon not showing on the title bar
- FIX: [Xshell] Live update window opens in the background
- FIX: [Xshell] ls and open commands points to different current directory
- FIX: [Xshell] Proble using the -newtab option
- FIX: [Xshell] Problem arranging tabs
- FIX: [Xshell] Problem creating auto log when using IPv6
- FIX: [Xshell] Problem moving focus
- FIX: [Xshell] Problem processing 2 byte characters on the title bar
- FIX: [Xshell] Problem processing some line characters
- FIX: [Xshell] Problem selecting sessions from the Status bar
- FIX: [Xshell] Problem with displaying terminal title
- FIX: [Xshell] Problem with keyboard shortcut for some European languages
- FIX: [Xshell] Problem with resource conflict
- FIX: [Xshell] Problem with the Compose bar stealing focus
- FIX: [Xshell] Problem with the Show this dialog box at startup option
- FIX: [Xshell] Send Quick Command to all sessions
- FIX: [Xshell] Tab name changes even after cancel the Save as operation
- FIX: [Xshell] Terminal update problem when using screen
- FIX: [Xshell] Undesignated keys are trying when using Xagent
- FIX: [Xshell] Window list only displays Xshell 5
- FIX: [Common] Minor bug fix and resource clean up
Xmanager Enterprise 5 Build 0436, Nov 10, 2014- ADD: Xmanager Enterprise 5 OFFICIAL RELEASE
- FIX: Bug fixes and stability improvements
PS:低调使用,不要问是什么,不解释。
百度网盘下载地址:
Netsarang-Xmanager-Enterprise-v5-1243-Incl-Keygen-AMPED.txt.zip
(525 Bytes, 下载次数: 23, 售价: 1 贡献)
