查看: 5667|回复: 2
RichEditContol 多个文档合并
100 小时
发表于 2014-11-6 09:57:52 | 显示全部楼层 |阅读模式
 public static Document MergeDouments(List<DocPrintEntity> fileStrems, DocumentFormat docFormat, bool isReplaceSymbols)
            RichEditDocumentServer targetServer = new RichEditDocumentServer();
            RichEditDocumentServer sourceServer = new RichEditDocumentServer();
            Document targetDoc = targetServer.Document;
            Document sourceDoc = sourceServer.Document;
            for (int i = 0; i < fileStrems.Count; i++)
                sourceServer.LoadDocument(fileStrems[i].DocStream, docFormat);
                if (isReplaceSymbols)
                    ReplaceDoumentSymbols(sourceServer);
                if (i > 0 && fileStrems[i].isNewPage == "是")
                    targetDoc.AppendSection();
                targetDoc.Sections[targetDoc.Sections.Count - 1].UnlinkHeaderFromPrevious();
                targetDoc.Sections[targetDoc.Sections.Count - 1].UnlinkFooterFromPrevious();
                SectionsMerger.Append(sourceDoc, targetDoc);
                if (i == fileStrems.Count - 1)
                    return targetDoc;
            return targetDoc;
        public static void MergeDouments(RichEditControl docControl, List<DocPrintEntity> fileStrems, DocumentFormat docFormat, bool isReplaceSymbols)
            docControl.LoadDocument(fileStrems[0].DocStream, docFormat);
            for (int i = 1; i < fileStrems.Count; i++)
                if (fileStrems[i].isNewPage == "是")
                    docControl.Document.AppendSection();
                docControl.Document.AppendDocumentContent(fileStrems[i].DocStream, docFormat);
                ReplaceDoumentSymbols(docControl);
public class SectionsMerger
        public static void Append(Document source, Document target)
            int lastSectionIndexBeforeAppending = target.Sections.Count - 1;
            int sourceSectionCount = source.Sections.Count;
            MemoryStream ms = new MemoryStream();
            source.SaveDocument(ms, DocumentFormat.Doc);
            target.AppendDocumentContent(ms, DocumentFormat.Doc);
            for (int i = 0; i < sourceSectionCount; i++)
                Section sourceSection = source.Sections[i];
                Section targetSection = target.Sections[lastSectionIndexBeforeAppending + i];
                // Copy standard header/footer
                AppendHeader(sourceSection, targetSection, HeaderFooterType.Odd);
                AppendFooter(sourceSection, targetSection, HeaderFooterType.Odd);
        private static void AppendHeader(Section sourceSection, Section targetSection, HeaderFooterType headerFooterType)
            SubDocument source = sourceSection.BeginUpdateHeader(headerFooterType);
            SubDocument target = targetSection.BeginUpdateHeader(headerFooterType);
            target.Delete(target.Range);
            target.InsertDocumentContent(target.Range.Start, source.Range, InsertOptions.KeepSourceFormatting);
            // Delete empty paragraphs
            DocumentRange emptyParagraph = target.CreateRange(target.Range.End.ToInt() - 2, 2);
            target.Delete(emptyParagraph);
            sourceSection.EndUpdateHeader(source);
            targetSection.EndUpdateFooter(target);
        private static void AppendFooter(Section sourceSection, Section targetSection, HeaderFooterType headerFooterType)
            SubDocument source = sourceSection.BeginUpdateFooter(headerFooterType);
            SubDocument target = targetSection.BeginUpdateFooter(headerFooterType);
            sourceSection.EndUpdateFooter(source);
参与人数 4贡献 +3 赞扬 +4 收起 理由
a3398200 + 1 赞一个
982071787 + 1
嘿黑丶 + 1
羽叶 + 3 + 1 赞一个
4844 小时
黄马甲
发表于 2014-12-17 20:06:40 | 显示全部楼层
感谢楼主分享,帖子之前被系统自动判定为垃圾帖子放到回收站了。刚发现 抱歉抱歉~!
27 小时
发表于 2015-8-10 14:41:50 | 显示全部楼层
好帖,先收藏,留下坐标,以便之后需要参考
GMT+8, 2026-4-30 18:15
