查看: 6050|回复: 4
.NET Reactor v4.0.0.0 & Registration(注册机本地下载)
134 小时
发表于 2013-6-10 22:47:55 | 显示全部楼层 |阅读模式
帮忙搬运老论坛的贴子
官方:http://www.eziriz.com/
.NET Reactor is a powerful .NET code protection & licensing system which assists developers in
protecting their .NET software. Developers are able to protect their software in a safe and simple
way now. This way developers can focus more on development than on worrying how to protect
their intellectual property.
In contrast to obfuscators .NET Reactor completely stops any decompiling by mixing any pure .NET
assembly (written in C#, VB.NET, Delphi.NET, J#, MSIL...) with native machine code. In detail,
.NET Reactor builds a native wall between potential hackers and your .NET code. The result is a
standard Windows based, not MSIL compatible, file. The original .NET code remains intact, well protected
by native code and invisible for prying eyes. The original .NET code is not copied on harddisk at any time.
There is no tool which is able to decompile .NET Reactor protected assemblies.
Features
.NET code & resource protection
.NET code encryption
.NET 1.1, 2.0, 3.0, 3.5 & 4.0 (Beta) assembly support
.NET Compact Framework 1.0, 2.0 & 3.5 protection support
ASP.NET support
Anti ILDASM
Mono assembly support
Advanced licensing system
String encryption
Merge assemblies into one executable or library
Removes IL code
Native Exe file generation
Compression support for executable files
Protection against disassembling and hacking
Protects any kind of .NET assembly
ShareIt Module Generator
Command Line support
Intuitive GUI (Graphical User Interface)
.NET Reactor Registration v4.0.0.0 can only register .Net Reactor v4.0.0.0, other versions can not be registered.
Installation steps:
1)Download .Net Reactor v4.0.0.0, you can get it from the official site
2)Install .Net Reactor v4.0.0.0 and then install .NET Reactor Registration v4.0.0.0.
Notes:
1)The setup file of .NET Reactor Registration v4.0.0.0 doesn't modify any file of the original product.
2).NET Reactor Registration v4.0.0.0 conflicts with the following softwares released by me before 2009/10/15:
a)RedGate {smartassembly} Enterprise Version 4.1 (Build 39)
b)Xenocode Postbuild 2009 for .NET v7.1.343
c)Xenocode Virtual Application Studio 2009 ISV Edition v7.1.280
d)DevExpress Registration Add-In v9.1.x/v9.2.x/v9.2.6
You must install the cracked softwares according to their release dates, the latest one must be installed at last.
download:http://rapidshare.com/files/297165156/DotNetReactor.v4.0.0.0.rar
参与人数 1软币 +5 收起 理由
羽叶 + 5 感谢支持
134 小时
 楼主| 发表于 2013-6-10 22:50:08 | 显示全部楼层
134 小时
 楼主| 发表于 2013-6-10 22:51:07 | 显示全部楼层
前几天有人和我要这玩意,说新版本找不到破解,.NET Reactor我也没用过,就大概看了一下,他的保护和授权机制还不错,所以就写了这个注册机,安装后就可以注册.Net Reactor v4.0.0.0了。
官方网址:http://www.eziriz.com/
.NET Reactor Registration v4.0.0.0只能注册.Net Reactor v4.0.0.0,其他版本不支持。
安装步骤:
1)下载.Net Reactor v4.0.0.0,你可以到官方网站下载http://www.eziriz.com/
2)安装.Net Reactor v4.0.0.0,然后安装.NET Reactor Registration v4.0.0.0。
注意:
1).NET Reactor Registration v4.0.0.0安装程序不会修改原有的程序。
2).NET Reactor Registration v4.0.0.0和下面我在2009/10/15之前发布的破解软件有冲突:
请根据我的发布日期的先后来进行各个破解软件的安装,最新的发布请在最后安装。
1)注册后界面
2)增加了三个菜单项,分别是我的博客,smartsoft论坛和board4all论坛,点击即可访问
点击进入下载-DotNetReactor.v4.0.0.0.7z.001
点击进入下载-DotNetReactor.v4.0.0.0.7z.002
点击进入下载-DotNetReactor.v4.0.0.0.7z.003
点击进入下载-DotNetReactor.v4.0.0.0.7z.004
点击进入下载-DotNetReactor.v4.0.0.0.7z.005
我只是纯搬运,没用过。
62 小时
发表于 2013-6-15 13:17:05 | 显示全部楼层
.NET Reactor v4.6.0.0出来了,假如可以破解,那就好了!
265 小时
发表于 2013-6-19 00:34:23 | 显示全部楼层
我用这个东西加密程序,就是无法运行,看错误,说是调用的方法找不到,昏倒
GMT+8, 2025-4-20 16:18
