查看: 3317|回复: 1
Dev mvc对象强制转换错误
发表于 2014-11-27 10:57:55 | 显示全部楼层 |阅读模式
controller
//主视图
        public ActionResult spReport()
            spXtraReport xrpt1 = new spXtraReport(GetTempDataSet());
            xrpt1.DataSource = GetTempDataSet();
            ViewData["spReport"] = xrpt1;
            return View();
        //分布视图
        public ActionResult spReportViewerPartial()
            return View("spReportViewerPartial");
        //数据源
        private DataSet GetTempDataSet()
            DataSet ds = new DataSet();
            DataTable dt = new DataTable("tempTable");
            dt.Columns.Add("test1", Type.GetType("System.String"));
            dt.Columns.Add("test2", Type.GetType("System.String"));
            dt.Columns.Add("test3", Type.GetType("System.String"));
            dt.Columns.Add("test4", Type.GetType("System.String"));
            dt.Columns.Add("test5", Type.GetType("System.String"));
            dt.Columns.Add("test6", Type.GetType("System.String"));
            dt.Columns.Add("test7", Type.GetType("System.String"));
            DataRow tempRow;
            for (int i = 0; i < 7; i++)//i:Row
                tempRow = dt.NewRow();
                tempRow[0] = i.ToString();
                tempRow[1] = i.ToString();
                tempRow[2] = i.ToString();
                tempRow[3] = i.ToString();
                tempRow[4] = i.ToString();
                tempRow[5] = i.ToString();
                tempRow[6] = i.ToString();
                dt.Rows.Add(tempRow);
            ds.Tables.Add(dt);
            return ds;
设计code:
//主视图
            xrpt1.DataSource = GetTempDataSet();//绑定数据源是用这种还是用下面ViewData方式?
            return View();
        //分布视图
        //数据源
            DataRow tempRow;
            ds.Tables.Add(dt);
            return ds;
分布视图:
@Html.DevExpress().DocumentViewer(settings =>
   // The following settings are required for a ReportViewer.
   settings.Name = "documentViewer1";
   settings.Report = (spXtraReport)ViewData["spReport"];
   // Callback and export route values specify correspondingcontrollers and their actions.
   // These settings are required as well.
   settings.CallbackRouteValues = new { Controller = "spReport", Action = "spReportViewerPartial" };
   settings.ExportRouteValues = new { Controller = "spReport", Action = "ExportDocumentViewer" };
}).GetHtml()
我这样写在视图里面报:
无法将类型为“System.Web.Mvc.HtmlHelper`1[System.Object]”的对象强制转换为类型“System.Web.Mvc.HtmlHelper”。
 楼主| 发表于 2014-11-27 11:00:25 | 显示全部楼层
设计code:
public spXtraReport()
        InitializeComponent();
        // TODO: Add constructor logic here
    public spXtraReport(DataSet ds)//构造函数重载
        SetDataBind(ds);
    private void SetDataBind(DataSet ds)//绑定数据源
        DataSource = ds;
        this.xrTableCell1.DataBindings.Add("Text", DataSource, "test1");
        this.xrTableCell2.DataBindings.Add("Text", DataSource, "test1");
        this.xrTableCell3.DataBindings.Add("Text", DataSource, "test1");
GMT+8, 2025-4-20 21:38
