用户名  找回密码
查看: 5713|回复: 2
Eziriz IntelliLock v1.8.0.0
141 小时
QQ
发表于 2013-6-27 17:34:22 | 显示全部楼层 |阅读模式
Software name : IntelliLock
Version       : 1.8.0.0
Release Type  : Full Version
Release Date  : 14 June 2013 - 2:41 AM
Pulished Date : 17 June 2013 - 9:25 AM
OS            : Windows XP, Windows 2003, Windows Vista, Windows 7, Windows 8 (x86/x64)
Developer     : Eziriz
Web-site      : http://www.eziriz.com/
WHAT'S NEW:
- [+] Added Floating License (Concurrent User) support
- [+] Added dialogs for 'Floating License'
- [+] Added 'Asynchronous License Check' option to check the license status in the background (prevents delay at startup)
- [+] Added new event (IntelliLock.Licensing.EvaluationMonitor.LicenseCheckFinished) to SDK. Event is raised after license check is finished.
- [+] New hardware ID algorithm which fixes problems with MAC and HDD. Old hardware IDs are still accepted/valid.
- [+] Added option to define a previous hardware ID algorithm -> used by IntelliLock.Licensing.HardwareID.GetHardwareID(...)
- [+] Added options 'As Trial Version' and 'As Full Version' to define if the generated license file should be recognized as full version or trial version
- [+] Added new license status (IntelliLock.Licensing. LicenseStatus.FullVersionExpired)
- [!] Fixed issue for 'Peridically' option ('Require License Server Validation')
- [!] Fixed issue for Silverlight 5 (referencing multiple versions of the same assembly)
- [!] Fixed IL Code Encryption issue
- [!] Fixed Visual Studio Add-in issue with merged assemblies
- [!] Fixed Inject Invalid Metadata issue on x86 assemblies
- [!] Fixed Compact Framework 3.5 issue
- [!] Fixed minor bugs
Eziriz IntelliLock v1.8.0.0.rar
参与人数 2贡献 +3 赞扬 +2 收起 理由
hangouts + 1 Thanks
羽叶 + 3 + 1 感谢分享
举报
4515 小时
黄马甲
发表于 2013-6-27 19:20:24 | 显示全部楼层
被系统扔到回收站了。。发帖最好写几个中文字,否则会被论坛自动屏蔽掉。
举报
版主
1139 小时
发表于 2013-6-28 13:59:55 | 显示全部楼层
这个不错,一蓑烟雨yoza的作品都是精品啊!
举报
GMT+8, 2025-4-13 23:23
