查看: 2820|回复: 0
asp.net mvc的视图中menu控件的文本如何更改
发表于 2014-12-15 12:41:44 | 显示全部楼层 |阅读模式
如果我想根据点击menu的某个item 让菜单头的文本进行变化 该如何实现?
例如:
@Html.DevExpress().Menu(settings =>
                                           settings.Name = "mOverview";
                                           settings.AllowSelectItem = true;
                                           settings.EnableHotTrack = true;
                                           settings.EnableAnimation = true;
                                           settings.AppearAfter = 300;
                                           settings.DisappearAfter = 500;
                                           settings.MaximumDisplayLevels = 0;
                                           settings.ShowPopOutImages = DefaultBoolean.True;
                                           settings.Enabled = true;
                                           settings.Orientation = System.Web.UI.WebControls.Orientation.Horizontal;
settings.Items.Add(item =>
                                                item.Name = "Language";
                                                item.Text = "简体中文";
                                                item.Items.Add("简体中文","chs","null");
                                                item.Items.Add("English", "eng", "null");
                                                item.Items.Add("繁体中文", "cht", "null");
                                                settings.ClientSideEvents.ItemClick = "MenuItemClick";
                                            }).GetHtml()</td>
        <script type="text/javascript">
            function MenuItemClick(s, e)
                var string = e.item.name;//text取不了!
                 //使用$("Language"). val/text/item.text之类都不能达到目的
                alert(e.item.name);//显示正常 但是item.text不行
            </script type="text/javascript">
GMT+8, 2025-4-2 02:41
