查看: 7421|回复: 1
gridcontrol怎么能让主从表的数据都导出或打印
发表于 2014-12-28 19:49:18 | 显示全部楼层 |阅读模式
导出:
SaveFileDialog saveFileDialog = new SaveFileDialog();
                saveFileDialog.Title = "导出Excel";
                saveFileDialog.Filter = "Excel文件(*.xlsx)|*.xlsx";
                DialogResult dialogResult = saveFileDialog.ShowDialog(this);
                if (dialogResult == DialogResult.OK)
                    DevExpress.XtraPrinting.XlsExportOptions options = new DevExpress.XtraPrinting.XlsExportOptions();
                    //gridControl1.ExportToXls(saveFileDialog.FileName, options);
                    gridControl1.ExportToXlsx(saveFileDialog.FileName);
                    DevExpress.XtraEditors.XtraMessageBox.Show("保存成功!", "提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
打印:
DevExpress.XtraPrinting.PrintingSystem print = new DevExpress.XtraPrinting.PrintingSystem();
            DevExpress.XtraPrinting.PrintableComponentLink link = new DevExpress.XtraPrinting.PrintableComponentLink(print);
            print.Links.Add(link);
            link.Component = gridControl1;//这里可以是可打印的部件
            string PrintHeader = "明细表";
            DevExpress.XtraPrinting.PageHeaderFooter phf = link.PageHeaderFooter as DevExpress.XtraPrinting.PageHeaderFooter;
            phf.Header.Content.Clear();
            phf.Header.Content.AddRange(new string[] { "", PrintHeader, "" });
            phf.Header.Font = new System.Drawing.Font("宋体", 10, System.Drawing.FontStyle.Regular);
            phf.Header.LineAlignment = DevExpress.XtraPrinting.BrickAlignment.Center;
            link.CreateDocument(); //建立文档
            print.PreviewFormEx.Show();//进行预览
我用上面的代码都只能导出或打印主表的数据,请问主从表的数据一起导出或打印,怎么做?
787 小时
发表于 2020-2-27 21:49:17 | 显示全部楼层
DevExpress GridControl 主从表导出问题解决
saveFileDialog.Filter = "文件格式(*.Xlsx)|*.xlsx";
if (saveFileDialog.ShowDialog() == DialogResult.OK)
     string name = saveFileDialog.FileName;
     this.dgvMain.OptionsPrint.ExpandAllDetails = true; //将 ExpandAllDetails 设置成true
     this.dgvMain.OptionsPrint.PrintDetails = true;   //将PrintDetails  设置成True
     this.dgvMain.BestFitColumns();
    this.dgvMain.ExportToXlsx(name);
GMT+8, 2025-2-23 13:55
