查看: 3733|回复: 0
[源码] 浅拷贝的一个简单例子
101 小时
发表于 2015-1-7 09:28:27 | 显示全部楼层 |阅读模式
class Program
        private static void Main(string[] args)
            var p = new Person()
                Name = "jxq",
                Age = 23
            var shallowCopy = Operator<Person>.ShallowCopy(p);
            shallowCopy.Name = "feichexia";
            Console.WriteLine(shallowCopy.Name);
            Console.WriteLine(p.Name);
            Console.ReadKey();
        public class Person
            public string Name { get; set; }
            public int Age { get; set; }
        public static class Operator<T>
            private static readonly Func<T, T> ShallowClone;
            public static T ShallowCopy(T sourcObj)
                return ShallowClone.Invoke(sourcObj);
            static Operator()
                var origParam = Expression.Parameter(typeof (T), "orig");
                // for each read/write property on T, create a  new binding
                // (for the object initializer) that copies the original's value into the new object
                var setProps = from prop in typeof (T).GetProperties(BindingFlags.Public | BindingFlags.Instance)
                    where prop.CanRead && prop.CanWrite
                    select (MemberBinding) Expression.Bind(prop, Expression.Property(origParam, prop));
                var body = Expression.MemberInit( // object initializer
                    Expression.New(typeof (T)), // ctor
                    setProps // property assignments
                ShallowClone = Expression.Lambda<Func<T, T>>(body, origParam).Compile();
GMT+8, 2025-4-20 21:40
