查看: 18006|回复: 3
SQLite.Developer.v3.9.7.522.Cracked
版主
1139 小时
发表于 2013-6-29 21:06:53 | 显示全部楼层 |阅读模式
由一蓑烟雨yoza[UpK]版主提供。
HP: http://www.sqlitedeveloper.com/
SharpPlus SQLite Developer, a powerful database manager that will manage sqlite3 database!
Features:
    Power SQL Editor
        Sqlite Sql Syntax Highlight
        Sql history
        Sql keyword autocomplete
        Parenthesis matching
        Table/View/Field Autocomplete
        Live Sql Syntax Check
        Unicode support
    SQL Formatter
    Supports ansi, unicode data encoding and decoding.
    Customizable Data Type Mapping.
    Execute multiple sql separated by semi colon.
    Execute sql script with parameters.
    Master Detail Browser.
    Test Data Generator
    Generate Database Schema Report
    SQL Monitor.
    Visual Query Builder.
    Visual tables ,views ,trigger, foreign key, check, unique check  and index management.
    View and edit field as Text , Hex , HTML or bmp, jpeg, gif.
    View and edit temporary tables, views and triggers.
    Memory Database support
    Query plan.
    LiveUpdate.
    Export data to sql,csv,excel, word, html, xml.
    Import / Export
        Import data from sql, csv, sqlite database and ado datasource.
        Extract db schema and data.
        Paste Data from Clipboard.(New)
        Backup/Restore Database.
    Output works seamlessly with any web hosting
    Treeview style db explorer with smart filter
    Attach and Detach databases
    support encrypt and decrypt database  (encrypted databases are compatible with System.Data.SQLite )
    RTree and ICU support
    Find in Database Schema
    Cancel long-time query
    Support loadable extension and virtual table
    Multi Languages support(English, Japanese, Simple Chinese)
What's New:
    [SQLite Engine] Updated:Added spellfix1 extension.
    [Data Editor] Fixed:Fix the paste records command short cut from ctrl+v to ctrl+alt+v to avoid conflicting with default paste command (regression of 3.67)
    [Data Editor] Updated:Add Clone Record command.
    [SQLite Engine] Updated:upgrade to sqlite 3.7.17
    [Data Editor] Updated:Show progress when pasting data from clipboard and allow user to cancel the operation.
    [Query Editor] Fixed:Sometimes auto complete popupped at wrong position.
    [SQLite Engine] Fixed:soundex function was not compiled.
http://pan.baidu.com/share/link? ... 5&uk=3677446874
90 小时
发表于 2013-6-30 12:33:04 | 显示全部楼层
此帖仅作者可见
发表于 2017-1-26 10:58:00 | 显示全部楼层
此帖仅作者可见
423 小时
发表于 2018-10-20 10:12:06 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-4-21 03:19
