查看: 17516|回复: 1
Consuming JSON Strings in SQL Server, 用JSON的兄弟有福了.
36 小时
发表于 2015-2-11 11:43:01 | 显示全部楼层 |阅读模式
IF OBJECT_ID (N'dbo.parseJSON') IS NOT NULL
   DROP FUNCTION dbo.parseJSON
GO
IF OBJECT_ID (N'dbo.ParseXML') IS NOT NULL
   DROP FUNCTION dbo.ParseXML
GO
IF OBJECT_ID (N'dbo.ToJSON') IS NOT NULL
   DROP FUNCTION dbo.ToJSON
GO
IF OBJECT_ID (N'dbo.ToXML') IS NOT NULL
   DROP FUNCTION dbo.ToXML
GO
IF OBJECT_ID (N'dbo.JSONEscaped') IS NOT NULL
   DROP FUNCTION dbo.JSONEscaped
GO
IF EXISTS (SELECT * FROM sys.types WHERE name LIKE 'Hierarchy')
  DROP TYPE dbo.Hierarchy
go
CREATE TYPE dbo.Hierarchy AS TABLE
/*Markup languages such as JSON and XML all represent object data as hierarchies. Although it looks very different to the entity-relational model, it isn't. It is rather more a different perspective on the same model. The first trick is to represent it as a Adjacency list hierarchy in a table, and then use the contents of this table to update the database. This Adjacency list is really the Database equivalent of any of the nested data structures that are used for the interchange of serialized information with the application, and can be used to create XML, OSX Property lists, Python nested structures or YAML as easily as JSON.
Adjacency list tables have the same structure whatever the data in them. This means that you can define a single Table-Valued  Type and pass data structures around between stored procedures. However, they are best held at arms-length from the data, since they are not relational tables, but something more like the dreaded EAV (Entity-Attribute-Value) tables. Converting the data from its Hierarchical table form will be different for each application, but is easy with a CTE. You can, alternatively, convert the hierarchical table into XML and interrogate that with XQuery
   element_id INT primary key, /* internal surrogate primary key gives the order of parsing and the list order */
   sequenceNo [int] NULL, /* the place in the sequence for the element */
   parent_ID INT,/* if the element has a parent then it is in this column. The document is the ultimate parent, so you can get the structure from recursing from the document */
   Object_ID INT,/* each list or object has an object id. This ties all elements to a parent. Lists are treated as objects here */
   NAME NVARCHAR(2000),/* the name of the object, null if it hasn't got one */
   StringValue NVARCHAR(MAX) NOT NULL,/*the string representation of the value of the element. */
   ValueType VARCHAR(10) NOT null /* the declared type of the value represented as a string in StringValue*/
go
CREATE FUNCTION dbo.JSONEscaped ( /* this is a simple utility function that takes a SQL String with all its clobber and outputs it as a sting with all the JSON escape sequences in it.*/
  @Unescaped NVARCHAR(MAX) --a string with maybe characters that will break json
RETURNS NVARCHAR(MAX)
AS
BEGIN
  SELECT  @Unescaped = REPLACE(@Unescaped, FROMString, TOString)
  FROM    (SELECT
            '\"' AS FromString, '"' AS ToString
           UNION ALL SELECT '\', '\\'
           UNION ALL SELECT '/', '\/'
           UNION ALL SELECT  CHAR(08),'\b'
           UNION ALL SELECT  CHAR(12),'\f'
           UNION ALL SELECT  CHAR(10),'\n'
           UNION ALL SELECT  CHAR(13),'\r'
           UNION ALL SELECT  CHAR(09),'\t'
          ) substitutions
RETURN @Unescaped
END
GO
CREATE FUNCTION ToJSON
      @Hierarchy Hierarchy READONLY
the function that takes a Hierarchy table and converts it to a JSON string
Author: Phil Factor
Revision: 1.5
date: 1 May 2014
why: Added a fix to add a name for a list.
example:
Declare @XMLSample XML
Select @XMLSample='
  <glossary><title>example glossary</title>
  <GlossDiv><title>S</title>
   <GlossList>
    <GlossEntry ID="SGML" SortAs="SGML">
     <GlossTerm>Standard Generalized Markup Language</GlossTerm>
     <Acronym>SGML</Acronym>
     <Abbrev>ISO 8879:1986</Abbrev>
     <GlossDef>
      <para>A meta-markup language, used to create markup languages such as DocBook.</para>
      <GlossSeeAlso OtherTerm="GML" />
      <GlossSeeAlso OtherTerm="XML" />
     </GlossDef>
     <GlossSee OtherTerm="markup" />
    </GlossEntry>
   </GlossList>
  </GlossDiv>
</glossary>'
DECLARE @MyHierarchy Hierarchy -- to pass the hierarchy table around
insert into @MyHierarchy select * from dbo.ParseXML(@XMLSample)
SELECT dbo.ToJSON(@MyHierarchy)
RETURNS NVARCHAR(MAX)--JSON documents are always unicode.
AS
BEGIN
  DECLARE
    @JSON NVARCHAR(MAX),
    @NewJSON NVARCHAR(MAX),
    @Where INT,
    @ANumber INT,
    @notNumber INT,
    @indent INT,
    @ii int,
    @CrLf CHAR(2)--just a simple utility to save typing!
  --firstly get the root token into place
  SELECT @CrLf=CHAR(13)+CHAR(10),--just CHAR(10) in UNIX
         @JSON = CASE ValueType WHEN 'array' THEN
         +COALESCE('{'+@CrLf+'  "'+NAME+'" : ','')+'['
         ELSE '{' END
            +@CrLf
            + case when ValueType='array' and NAME is not null then '  ' else '' end
            + '@Object'+CONVERT(VARCHAR(5),OBJECT_ID)
            +@CrLf+CASE ValueType WHEN 'array' THEN
            case when NAME is null then ']' else '  ]'+@CrLf+'}'+@CrLf end
                ELSE '}' END
  FROM @Hierarchy
    WHERE parent_id IS NULL AND valueType IN ('object','document','array') --get the root element
/* now we simply iterat from the root token growing each branch and leaf in each iteration. This won't be enormously quick, but it is simple to do. All values, or name/value pairs withing a structure can be created in one SQL Statement*/
  Select @ii=1000
  WHILE @ii>0
    begin
    SELECT @where= PATINDEX('%[^[a-zA-Z0-9]@Object%',@json)--find NEXT token
    if @where=0 BREAK
    /* this is slightly painful. we get the indent of the object we've found by looking backwards up the string */
    SET @indent=CHARINDEX(char(10)+char(13),Reverse(LEFT(@json,@where))+char(10)+char(13))-1
    SET @NotNumber= PATINDEX('%[^0-9]%', RIGHT(@json,LEN(@JSON+'|')-@Where-8)+' ')--find NEXT token
    SET @NewJSON=NULL --this contains the structure in its JSON form
    SELECT
        @NewJSON=COALESCE(@NewJSON+','+@CrLf+SPACE(@indent),'')
        +case when parent.ValueType='array' then '' else COALESCE('"'+TheRow.NAME+'" : ','') end
        +CASE TheRow.valuetype
        WHEN 'array' THEN '  ['+@CrLf+SPACE(@indent+2)
           +'@Object'+CONVERT(VARCHAR(5),TheRow.[OBJECT_ID])+@CrLf+SPACE(@indent+2)+']'
        WHEN 'object' then '  {'+@CrLf+SPACE(@indent+2)
           +'@Object'+CONVERT(VARCHAR(5),TheRow.[OBJECT_ID])+@CrLf+SPACE(@indent+2)+'}'
        WHEN 'string' THEN '"'+dbo.JSONEscaped(TheRow.StringValue)+'"'
        ELSE TheRow.StringValue
       END
     FROM @Hierarchy TheRow
     inner join @hierarchy Parent
     on parent.element_ID=TheRow.parent_ID
      WHERE TheRow.parent_id= SUBSTRING(@JSON,@where+8, @Notnumber-1)
     /* basically, we just lookup the structure based on the ID that is appended to the @Object token. Simple eh? */
    --now we replace the token with the structure, maybe with more tokens in it.
    Select @JSON=STUFF (@JSON, @where+1, 8+@NotNumber-1, @NewJSON),@ii=@ii-1
    end
  return @JSON
end
go
CREATE FUNCTION dbo.ParseXML( @XML_Result XML)
Returns a hierarchy table from an XML document.
Author: Phil Factor
Revision: 1.2
date: 1 May 2014
example:
INSERT INTO @myHierarchy
select * from dbo.ParseXML((Select * from adventureworks.person.contact where contactID in (123,124,125) FOR XML path('contact'), root('contacts')))
select * from dbo.ParseXML('<root><CSV><item Year="1997" Make="Ford" Model="E350" Description="ac, abs, moon" Price="3000.00" /><item Year="1999" Make="Chevy" Model="Venture &quot;Extended Edition&quot;" Description="" Price="4900.00" /><item Year="1999" Make="Chevy" Model="Venture &quot;Extended Edition, Very Large&quot;" Description="" Price="5000.00" /><item Year="1996" Make="Jeep" Model="Grand Cherokee" Description="MUST SELL!&#xD;&#xA;air, moon roof, loaded" Price="4799.00" /></CSV></root>')
RETURNS @Hierarchy TABLE
    Element_ID INT PRIMARY KEY, /* internal surrogate primary key gives the order of parsing and the list order */
    SequenceNo INT NULL, /* the sequence number in a list */
    Parent_ID INT,/* if the element has a parent then it is in this column. The document is the ultimate parent, so you can get the structure from recursing from the document */
    [Object_ID] INT,/* each list or object has an object id. This ties all elements to a parent. Lists are treated as objects here */
    [Name] NVARCHAR(2000),/* the name of the object */
    ValueType VARCHAR(10) NOT NULL /* the declared type of the value represented as a string in StringValue*/
   AS
BEGIN
DECLARE  @Insertions TABLE(
     Element_ID INT IDENTITY PRIMARY KEY,
     SequenceNo INT,
     TheLevel INT,
     Parent_ID INT,
     [Object_ID] INT,
     [Name] VARCHAR(50),
     StringValue VARCHAR(MAX),
     ValueType VARCHAR(10),
     TheNextLevel XML,
     ThisLevel XML)
DECLARE @RowCount INT, @ii INT
--get the
INSERT INTO @Insertions (TheLevel, Parent_ID, [Object_ID], [Name], StringValue, SequenceNo, TheNextLevel, ThisLevel)
  SELECT   1 AS TheLevel, NULL AS Parent_ID, NULL AS [Object_ID],
    FirstLevel.value('local-name(.)', 'varchar(255)') AS [Name], --the name of the element
    FirstLevel.value('text()[1]','varchar(max)') AS StringValue,-- its value as a string
    ROW_NUMBER() OVER(ORDER BY (SELECT 1)) AS SequenceNo,--the 'child number' (simple number here)
    FirstLevel.query('*'), --The 'inner XML' of the current child
    FirstLevel.query('.')  --the XML of the parent
  FROM @XML_Result.nodes('/*') a(FirstLevel) --get all nodes from the XML
SELECT @RowCount=@@RowCount
SELECT @ii=2
WHILE @RowCount>0 --while loop to avoid recursion.
  BEGIN
   SELECT --all the elements first
   @ii AS TheLevel,
     a.Element_ID,
     NULL,
     [then].value('local-name(.)', 'varchar(255)'),
     [then].value('text()[1]','varchar(max)'),
     ROW_NUMBER() OVER(PARTITION BY a.Element_ID ORDER BY (SELECT 1)),
     [then].query('*'),
     [then].query('.')
   FROM   @Insertions a
     CROSS apply a.TheNextLevel.nodes('*') whatsNext([then])
   WHERE a.TheLevel = @ii - 1
  UNION ALL -- to pick out the attributes of the preceding level
  SELECT @ii AS TheLevel,
     a.Element_ID,
     NULL,
     [then].value('local-name(.)', 'varchar(255)') AS [name],
     [then].value('.','varchar(max)') AS [value],
    ORDER BY (
    SELECT 1)),
   FROM   @Insertions a
     CROSS apply a.ThisLevel.nodes('/*/@*') whatsNext([then])
   WHERE a.TheLevel = @ii - 1 OPTION (RECOMPILE)
  SELECT @RowCount=@@ROWCOUNT
  SELECT @ii=@ii+1
  END;
  --roughly type the datatypes (no XSD available here)
UPDATE @Insertions SET
    [Object_ID]=CASE WHEN StringValue IS NULL THEN Element_ID
  ELSE NULL END,
    ValueType = CASE
     WHEN StringValue IS NULL THEN 'object'
     WHEN  LEN(StringValue)=0 THEN 'string'
     WHEN StringValue LIKE '%[^0-9.-]%' THEN 'string'
     WHEN StringValue LIKE '[0-9]' THEN 'int'
     WHEN RIGHT(StringValue, LEN(StringValue)-1) LIKE'%[^0-9.]%' THEN 'string'
     WHEN  StringValue LIKE'%[0-9][.][0-9]%' THEN 'real'
     WHEN StringValue LIKE '%[^0-9]%' THEN 'string'
  ELSE 'int' END--and find the arrays
    ValueType='array'
  WHERE Element_ID IN(
  SELECT candidates.Parent_ID
   FROM
   SELECT Parent_ID, COUNT(*) AS SameName
    FROM @Insertions
    GROUP BY [Name],Parent_ID
    HAVING COUNT(*)>1) candidates
     INNER JOIN  @Insertions insertions
     ON candidates.Parent_ID= insertions.Parent_ID
   GROUP BY candidates.Parent_ID
   HAVING COUNT(*)=MIN(SameName))
INSERT INTO @Hierarchy (Element_ID,SequenceNo, Parent_ID, [Object_ID], [Name], StringValue,ValueType)
  SELECT Element_ID, SequenceNo, Parent_ID, [Object_ID], [Name], COALESCE(StringValue,''), ValueType
  FROM @Insertions
RETURN
END
GO
CREATE FUNCTION dbo.parseJSON( @JSON NVARCHAR(MAX))
RETURNS @hierarchy TABLE
   element_id INT IDENTITY(1, 1) NOT NULL, /* internal surrogate primary key gives the order of parsing and the list order */
   NAME NVARCHAR(2000),/* the name of the object */
AS
BEGIN
  DECLARE
    @FirstObject INT, --the index of the first open bracket found in the JSON string
    @OpenDelimiter INT,--the index of the next open bracket found in the JSON string
    @NextOpenDelimiter INT,--the index of subsequent open bracket found in the JSON string
    @NextCloseDelimiter INT,--the index of subsequent close bracket found in the JSON string
    @Type NVARCHAR(10),--whether it denotes an object or an array
    @NextCloseDelimiterChar CHAR(1),--either a '}' or a ']'
    @Contents NVARCHAR(MAX), --the unparsed contents of the bracketed expression
    @Start INT, --index of the start of the token that you are parsing
    @end INT,--index of the end of the token that you are parsing
    @param INT,--the parameter at the end of the next Object/Array token
    @EndOfName INT,--the index of the start of the parameter at end of Object/Array token
    @token NVARCHAR(200),--either a string or object
    @value NVARCHAR(MAX), -- the value as a string
    @SequenceNo int, -- the sequence number within a list
    @name NVARCHAR(200), --the name as a string
    @parent_ID INT,--the next parent ID to allocate
    @lenJSON INT,--the current length of the JSON String
    @characters NCHAR(36),--used to convert hex to decimal
    @result BIGINT,--the value of the hex symbol being parsed
    @index SMALLINT,--used for parsing the hex value
    @Escape INT --the index of the next escape character
  DECLARE @Strings TABLE /* in this temporary table we keep all strings, even the names of the elements, since they are 'escaped' in a different way, and may contain, unescaped, brackets denoting objects or lists. These are replaced in the JSON string by tokens representing the string */
     String_ID INT IDENTITY(1, 1),
  SELECT--initialise the characters to convert hex to ascii
    @characters='0123456789abcdefghijklmnopqrstuvwxyz',
    @SequenceNo=0, --set the sequence no. to something sensible.
  /* firstly we process all strings. This is done because [{} and ] aren't escaped in strings, which complicates an iterative parse. */
    @parent_ID=0;
  WHILE 1=1 --forever until there is nothing more to do
    BEGIN
      SELECT
        @start=PATINDEX('%[^a-zA-Z]["]%', @json collate SQL_Latin1_General_CP850_Bin);--next delimited string
      IF @start=0 BREAK --no more so drop through the WHILE loop
      IF SUBSTRING(@json, @start+1, 1)='"'
        BEGIN --Delimited Name
          SET @start=@Start+1;
          SET @end=PATINDEX('%[^\]["]%', RIGHT(@json, LEN(@json+'|')-@start) collate SQL_Latin1_General_CP850_Bin);
        END
      IF @end=0 --no end delimiter to last string
        BREAK --no more
      SELECT @token=SUBSTRING(@json, @start+1, @end-1)
      --now put in the escaped control characters
      SELECT @token=REPLACE(@token, FROMString, TOString)
      FROM
        (SELECT
         UNION ALL SELECT '\\', '\'
         UNION ALL SELECT '\/', '/'
         UNION ALL SELECT '\b', CHAR(08)
         UNION ALL SELECT '\f', CHAR(12)
         UNION ALL SELECT '\n', CHAR(10)
         UNION ALL SELECT '\r', CHAR(13)
         UNION ALL SELECT '\t', CHAR(09)
        ) substitutions
      SELECT @result=0, @escape=1
  --Begin to take out any hex escape codes
      WHILE @escape>0
        BEGIN
          SELECT @index=0,
          --find the next hex escape sequence
          @escape=PATINDEX('%\x[0-9a-f][0-9a-f][0-9a-f][0-9a-f]%', @token collate SQL_Latin1_General_CP850_Bin)
          IF @escape>0 --if there is one
            BEGIN
              WHILE @index<4 --there are always four digits to a \x sequence
                BEGIN
                  SELECT --determine its value
                    @result=@result+POWER(16, @index)
                    *(CHARINDEX(SUBSTRING(@token, @escape+2+3-@index, 1),
                                @characters)-1), @index=@index+1 ;
                END
                -- and replace the hex sequence by its unicode value
              SELECT @token=STUFF(@token, @escape, 6, NCHAR(@result))
            END
        END
      --now store the string away
      INSERT INTO @Strings (StringValue) SELECT @token
      -- and replace the string with a token
      SELECT @JSON=STUFF(@json, @start, @end+1,
                    '@string'+CONVERT(NVARCHAR(5), @@identity))
    END
  -- all strings are now removed. Now we find the first leaf.
  BEGIN
  SELECT @parent_ID=@parent_ID+1
  --find the first object or list by looking for the open bracket
  SELECT @FirstObject=PATINDEX('%[{[[]%', @json collate SQL_Latin1_General_CP850_Bin)--object or array
  IF @FirstObject = 0 BREAK
  IF (SUBSTRING(@json, @FirstObject, 1)='{')
    SELECT @NextCloseDelimiterChar='}', @type='object'
  ELSE
    SELECT @NextCloseDelimiterChar=']', @type='array'
  SELECT @OpenDelimiter=@firstObject
  WHILE 1=1 --find the innermost object or list...
    BEGIN
      SELECT
        @lenJSON=LEN(@JSON+'|')-1
  --find the matching close-delimiter proceeding after the open-delimiter
      SELECT
        @NextCloseDelimiter=CHARINDEX(@NextCloseDelimiterChar, @json,
                                      @OpenDelimiter+1)
  --is there an intervening open-delimiter of either type
      SELECT @NextOpenDelimiter=PATINDEX('%[{[[]%',
             RIGHT(@json, @lenJSON-@OpenDelimiter)collate SQL_Latin1_General_CP850_Bin)--object
      IF @NextOpenDelimiter=0
        BREAK
      SELECT @NextOpenDelimiter=@NextOpenDelimiter+@OpenDelimiter
      IF @NextCloseDelimiter<@NextOpenDelimiter
        BREAK
      IF SUBSTRING(@json, @NextOpenDelimiter, 1)='{'
      ELSE
      SELECT @OpenDelimiter=@NextOpenDelimiter
    END
  ---and parse out the list or name/value pairs
  SELECT
    @contents=SUBSTRING(@json, @OpenDelimiter+1,
                        @NextCloseDelimiter-@OpenDelimiter-1)
  SELECT
    @JSON=STUFF(@json, @OpenDelimiter,
                @NextCloseDelimiter-@OpenDelimiter+1,
                '@'+@type+CONVERT(NVARCHAR(5), @parent_ID))
  WHILE (PATINDEX('%[A-Za-z0-9@+.e]%', @contents collate SQL_Latin1_General_CP850_Bin))<>0
    BEGIN
      IF @Type='Object' --it will be a 0-n list containing a string followed by a string, number,boolean, or null
        BEGIN
          SELECT
            @SequenceNo=0,@end=CHARINDEX(':', ' '+@contents)--if there is anything, it will be a string-based name.
          SELECT  @start=PATINDEX('%[^A-Za-z@][@]%', ' '+@contents collate SQL_Latin1_General_CP850_Bin)--AAAAAAAA
          SELECT @token=SUBSTRING(' '+@contents, @start+1, @End-@Start-1),
            @endofname=PATINDEX('%[0-9]%', @token collate SQL_Latin1_General_CP850_Bin),
            @param=RIGHT(@token, LEN(@token)-@endofname+1)
          SELECT
            @token=LEFT(@token, @endofname-1),
            @Contents=RIGHT(' '+@contents, LEN(' '+@contents+'|')-@end-1)
          SELECT  @name=stringvalue FROM @strings
            WHERE string_id=@param --fetch the name
        END
      ELSE
        SELECT @Name=null,@SequenceNo=@SequenceNo+1
      SELECT
        @end=CHARINDEX(',', @contents)-- a string-token, object-token, list-token, number,boolean, or null
      IF @end=0
        SELECT  @end=PATINDEX('%[A-Za-z0-9@+.e][^A-Za-z0-9@+.e]%', @Contents+' ' collate SQL_Latin1_General_CP850_Bin)
          +1
       SELECT
        @start=PATINDEX('%[^A-Za-z0-9@+.e][A-Za-z0-9@+.e]%', ' '+@contents collate SQL_Latin1_General_CP850_Bin)
      --select @start,@end, LEN(@contents+'|'), @contents
      SELECT
        @Value=RTRIM(SUBSTRING(@contents, @start, @End-@Start)),
        @Contents=RIGHT(@contents+' ', LEN(@contents+'|')-@end)
      IF SUBSTRING(@value, 1, 7)='@object'
        INSERT INTO @hierarchy
          (NAME, SequenceNo, parent_ID, StringValue, Object_ID, ValueType)
          SELECT @name, @SequenceNo, @parent_ID, SUBSTRING(@value, 8, 5),
            SUBSTRING(@value, 8, 5), 'object'
      ELSE
        IF SUBSTRING(@value, 1, 6)='@array'
            SELECT @name, @SequenceNo, @parent_ID, SUBSTRING(@value, 7, 5),
              SUBSTRING(@value, 7, 5), 'array'
        ELSE
          IF SUBSTRING(@value, 1, 7)='@string'
              (NAME, SequenceNo, parent_ID, StringValue, ValueType)
              SELECT @name, @SequenceNo, @parent_ID, stringvalue, 'string'
              FROM @strings
              WHERE string_id=SUBSTRING(@value, 8, 5)
          ELSE
            IF @value IN ('true', 'false')
                SELECT @name, @SequenceNo, @parent_ID, @value, 'boolean'
            ELSE
              IF @value='null'
                  SELECT @name, @SequenceNo, @parent_ID, @value, 'null'
              ELSE
                IF PATINDEX('%[^0-9]%', @value collate SQL_Latin1_General_CP850_Bin)>0
                    SELECT @name, @SequenceNo, @parent_ID, @value, 'real'
                ELSE
                    SELECT @name, @SequenceNo, @parent_ID, @value, 'int'
      if @Contents=' ' Select @SequenceNo=0
    END
  END
INSERT INTO @hierarchy (NAME, SequenceNo, parent_ID, StringValue, Object_ID, ValueType)
  SELECT '-',1, NULL, '', @parent_id-1, @type
   RETURN
END
GO
CREATE FUNCTION ToXML
/*this function converts a JSONhierarchy table into an XML document. This uses the same technique as the toJSON function, and uses the 'entities' form of XML syntax to give a compact rendering of the structure */
RETURNS NVARCHAR(MAX)--use unicode.
AS
BEGIN
  DECLARE
    @XMLAsString NVARCHAR(MAX),
    @NewXML NVARCHAR(MAX),
    @Entities NVARCHAR(MAX),
    @Objects NVARCHAR(MAX),
    @Name NVARCHAR(200),
    @Where INT,
    @ANumber INT,
    @notNumber INT,
    @indent INT,
         @XMLasString ='<?xml version="1.0" ?>
@Object'+CONVERT(VARCHAR(5),OBJECT_ID)+'
    FROM @hierarchy
    WHERE parent_id IS NULL AND valueType IN ('object','array') --get the root element
/* now we simply iterate from the root token growing each branch and leaf in each iteration. This won't be enormously quick, but it is simple to do. All values, or name/value pairs within a structure can be created in one SQL Statement*/
  WHILE 1=1
    begin
    SELECT @where= PATINDEX('%[^a-zA-Z0-9]@Object%',@XMLAsString)--find NEXT token
    if @where=0 BREAK
    SET @indent=CHARINDEX(char(10)+char(13),Reverse(LEFT(@XMLasString,@where))+char(10)+char(13))-1
    SET @NotNumber= PATINDEX('%[^0-9]%', RIGHT(@XMLasString,LEN(@XMLAsString+'|')-@Where-8)+' ')--find NEXT token
    SET @Entities=NULL --this contains the structure in its XML form
    SELECT @Entities=COALESCE(@Entities+' ',' ')+NAME+'="'
     +REPLACE(REPLACE(REPLACE(StringValue, '<', '&lt;'), '&', '&amp;'),'>', '&gt;')
       FROM @hierarchy
       WHERE parent_id= SUBSTRING(@XMLasString,@where+8, @Notnumber-1)
          AND ValueType NOT IN ('array', 'object')
    SELECT @Entities=COALESCE(@entities,''),@Objects='',@name=CASE WHEN Name='-' THEN 'root' ELSE NAME end
      FROM @hierarchy
      WHERE [Object_id]= SUBSTRING(@XMLasString,@where+8, @Notnumber-1)
    SELECT  @Objects=@Objects+@CrLf+SPACE(@indent+2)
           +'@Object'+CONVERT(VARCHAR(5),OBJECT_ID)
           --+@CrLf+SPACE(@indent+2)+''
      FROM @hierarchy
      AND ValueType IN ('array', 'object')
    IF @Objects='' --if it is a lef, we can do a more compact rendering
         SELECT @NewXML='<'+COALESCE(@name,'item')+@entities+' />'
    ELSE
        SELECT @NewXML='<'+COALESCE(@name,'item')+@entities+'>'
            +@Objects+@CrLf++SPACE(@indent)+'</'+COALESCE(@name,'item')+'>'
    Select @XMLasString=STUFF (@XMLasString, @where+1, 8+@NotNumber-1, @NewXML)
    end
  return @XMLasString
  end
83 小时
发表于 2015-2-16 18:16:09 | 显示全部楼层
楼主辛苦,但是感觉很少会在sql里面转json这样的事。
r_icky + 1 赞一个
GMT+8, 2026-4-26 09:58
